[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
    Chris Johns
    chrisj at rtems.org
    Tue Jul 14 03:53:20 UTC 2020
Could we please look at separate threads for these status posts, maybe one per
week or per topic or something else?
I do not think having mega-threads helps.
Thanks
On 12/7/20 4:04 am, Mritunjay Sharma wrote:
> On Sat, Jul 11, 2020 at 2:07 AM Gedare Bloom <gedare at rtems.org
> <mailto:gedare at rtems.org>> wrote:
>     On Fri, Jul 10, 2020 at 12:14 PM Mritunjay Sharma
>     <mritunjaysharma394 at gmail.com <mailto:mritunjaysharma394 at gmail.com>> wrote:
>     > Apologies for the delay in response,
>     > It’s an important update that I want to give to my mentors that my current
>     development laptop showed some problems yesterday and which worsened today.
>     > I have submitted my laptop for repair. The good thing is that I have the
>     backup of the work done till day and I have arranged a spare laptop as well
>     which will be available tomorrow.
>     > Configuring and setting up my laptop for the development may take a couple
>     of days and so I will like to request you all to kindly pardon my inactivity
>     for the next 2 days.
>     Meanwhile, you may also think about reading/writing some more
>     documentation, or planning out your next steps.
> Yes, Gedare, I did exactly the same today and wrote this beginner-friendly
> tutorial to
> introduce more beginners like me to RTEMS community.
> The link to blog
> is: https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
> The spare laptop is also arranged and almost configured. Only a few
> tweaks remaining.
> I will publish more blogs tomorrow related to EPICS+RTEMS and QEMU.
> I will certainly request Heinz, Chris and You to help me decide what should be
> my next steps now and
> what should be the goal for the following week.
> Thanks
> Mritunjay
>     > I hope to be back active on Monday with everything set up on the new laptop.
>     > Thanks
>     > Mritunjay
>     > Get Outlook for iOS
>     > ________________________________
>     > From: Jan.Sommer at dlr.de <mailto:Jan.Sommer at dlr.de> <Jan.Sommer at dlr.de
>     <mailto:Jan.Sommer at dlr.de>>
>     > Sent: Thursday, July 9, 2020 12:43:30 PM
>     > To: gedare at rtems.org <mailto:gedare at rtems.org> <gedare at rtems.org
>     <mailto:gedare at rtems.org>>; mritunjaysharma394 at gmail.com
>     <mailto:mritunjaysharma394 at gmail.com> <mritunjaysharma394 at gmail.com
>     > Cc: rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>
>     <rtems-devel at rtems.org <mailto:rtems-devel at rtems.org>>
>     > Subject: RE: [GSoC 2020: Daily Update]: Building EPICS with RTEMS5
>     > > -----Original Message-----
>     > > From: devel [mailto:devel-bounces at rtems.org
>     <mailto:devel-bounces at rtems.org>] On Behalf Of Gedare Bloom
>     > > Sent: Wednesday, July 8, 2020 9:45 PM
>     > > To: Mritunjay Sharma
>     > > Cc: RTEMS Devel
>     > > Subject: Re: [GSoC 2020: Daily Update]: Building EPICS with RTEMS5
>     > > On Wed, Jul 8, 2020 at 12:33 PM Mritunjay Sharma
>     > > > [UPDATE]: I tried to build the EPICS 7 with RTEMS 5 for pc386 with Heinz's
>     > > https://github.com/hjunkes/epicsBaseOwnPlayground
>     > > > while switching to Branch "7". The previous errors are gone but I am
>     facing
>     > > the following error:
>     > > > "../posix/rtems_init.c:38:10: fatal error: rtems/bsd/bsd.h: No such
>     file or
>     > > directory
>     > > >  #include <rtems/bsd/bsd.h>
>     > > This error indicates it is looking for an installed rtems-libbsd. My
>     > > guess is you need to build/install the rtems-libbsd to get this
>     > > playground to work.
>     > I did not read everything in this thread, so maybe I misunderstand something.
>     > If you want to build rtems-libbsd for a pc-based BSP, please be aware of
>     the following:
>     > - It should build fine if you use the 5-freebsd-12 branch.
>     > - With master branch is should build if you set the option "dev_nic_e1000"
>     to off in your buildset.ini. It should compile, but depending on your
>     network adapter there might be problems to actually use the network devices.
>     > Finishing a patchset for the master branch to fix that is on my todo list,
>     but I haven't come around to do it yet.
>     > > > compilation terminated.
>     > > /home/mritunjay/development/EPICS/epicsBaseOwnPlayground/configure/
>     > > RULES_BUILD:234: recipe for target 'rtems_init.o' failed
>     > > > make[4]: *** [rtems_init.o] Error 1
>     > > > make[4]: Leaving directory
>     > > '/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/modules/
>     > > libcom/RTEMS/O.RTEMS-pc386'
>     > > RULES_ARCHS:58: recipe for target 'install.RTEMS-pc386' failed
>     > > > make[3]: *** [install.RTEMS-pc386] Error 2
>     > > > make[3]: Leaving directory
>     > > libcom/RTEMS'
>     > > RULES_DIRS:84: recipe for target 'RTEMS.install' failed
>     > > > make[2]: *** [RTEMS.install] Error 2
>     > > > make[2]: Leaving directory
>     > > libcom'
>     > > > ../configure/RULES_DIRS:84: recipe for target 'libcom.install' failed
>     > > > make[1]: *** [libcom.install] Error 2
>     > > > make[1]: Leaving directory
>     > > '/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/modules'
>     > > > configure/RULES_DIRS:84: recipe for target 'modules.install' failed
>     > > > make: *** [modules.install] Error 2"
>     > > > Today's update is that I tried to fix the above error however I still
>     have not
>     > > been able to clear it.
>     > > > If anyone has idea, please do tell what can be done.
>     > > > Thanks
>     > > > Mritunjay
>     > > > On Wed, Jul 8, 2020 at 1:12 AM Mritunjay Sharma
>     > > >> From: Heinz Junkes <junkes at fhi-berlin.mpg.de
>     <mailto:junkes at fhi-berlin.mpg.de>>
>     > > >> Sent: Wednesday, July 8, 2020 1:05 AM
>     > > >> Cc: Gedare Bloom; Joel Sherrill; Chris Johns; RTEMS Devel
>     > > >> I’m away from my keyboard. If you use the epics Adaption to rtems from
>     > > my github “playground?” and bsp’s with —enable-networks should compile.
>     > > >> Heinz
>     > > >> FHI, Heinz Junkes
>     > > >> Thank you Heinz, I was doing the same. I went to your GitHub and am
>     > > experimenting with "playground" right now.
>     > > >> Thanks,
>     > > >> Mritunjay
>     > > >> On 7. Jul 2020, at 18:14, Mritunjay Sharma
>     > > >> [UPDATE]: I tried building EPICS with RTEMS5 for pc-386 and pc-386-qemu.
>     > > >> Everything worked fine while building the pc-386 with  RTEMS5.
>     > > >> After this when I entered epics-base and made the following change:
>     > > >> epics-base/os/CONFIG_SITE.Common.RTEMS
>     > > >> RTEMS_VERSION = 5
>     > > >> RTEMS_BASE =
>     > > /home/mritunjay/development/rtems_dev/$(RTEMS_VERSION)
>     > > >> As an experiment, I ran the make and as expected got the following error
>     > > >> Error:
>     > > >> ```...de/compiler/gcc -I../../../../include/os/RTEMS
>     -I../../../../include         -
>     > > c ../rtems_init.c
>     > > >> ../rtems_init.c:21:10: fatal error: sys/termios.h: No such file or
>     directory
>     > > >>  #include <sys/termios.h>
>     > > >> ../../../../configure/RULES_BUILD:240: recipe for target 'rtems_init.o'
>     > > failed
>     > > >> make[4]: Leaving directory '/home/mritunjay/development/EPICS/epics-
>     > > base/modules/libcom/RTEMS/O.RTEMS-pc386'
>     > > >> ../../../configure/RULES_ARCHS:58: recipe for target
>     > > failed
>     > > >> make[3]: Leaving directory '/home/mritunjay/development/EPICS/epics-
>     > > base/modules/libcom/RTEMS'
>     > > >> ../../configure/RULES_DIRS:85: recipe for target 'RTEMS.install' failed
>     > > >> make[2]: Leaving directory '/home/mritunjay/development/EPICS/epics-
>     > > base/modules/libcom'
>     > > >> ../configure/RULES_DIRS:85: recipe for target 'libcom.install' failed
>     > > >> make[1]: Leaving directory '/home/mritunjay/development/EPICS/epics-
>     > > base/modules'
>     > > >> configure/RULES_DIRS:85: recipe for target 'modules.install' failed
>     > > >> I am trying to figure out the error and making the changes in code to
>     > > debug it.
>     > > >> However, I will appreciate if Heinz and everyone else can help me a
>     little,
>     > > if they have an
>     > > >> idea of this error.
>     > > >> Thanks
>     > > >> Mritunjay
>     > > >> On Tue, Jul 7, 2020 at 7:30 PM Mritunjay Sharma
>     > > >>> On Tue, Jul 7, 2020 at 5:33 AM Gedare Bloom <gedare at rtems.org
>     > > wrote:
>     > > >>>> On Mon, Jul 6, 2020 at 5:49 PM Joel Sherrill <joel at rtems.org
>     <mailto:joel at rtems.org>> wrote:
>     > > >>>> > On Mon, Jul 6, 2020, 6:14 PM Gedare Bloom <gedare at rtems.org
>     > > wrote:
>     > > >>>> >> On Mon, Jul 6, 2020 at 10:12 AM Mritunjay Sharma
>     > > >>>> >> > Hello everyone,
>     > > >>>> >> > Thank you, Heinz, Gedare, Chris and Joel for your advice.
>     > > >>>> >> > If there are issues in making a buildset for 4.10
>     > > >>>> >> > then should I build EPICS with RTEMS 5 by hand first and note
>     > > >>>> >> > down the process and then proceed to make the buildset for it?
>     > > >>>> >> Yes.
>     > > >>>> > +1
>     > > >>>> > And by 5, we definitely mean the 5 branch for all rtems repo and the
>     > > similarly named one for libbsd.
>     > > >>>> Excellent point. We want to add support for easy build (and eventually
>     > > >>>> test) of EPICS+RTEMS starting with 5.1 and moving forward, which
>     > > means
>     > > >>>> also doing it for RTEMS 6, Mritunjay.
>     > > >>> Sounds good, I have begun building it hand by today for RTEMS 5 branch
>     > > and later on continue the
>     > > >>> same for RTEMS6
>     > > >>> Thank you so much Gedare and Joel.
>     > > >>> Mritunjay
>     > > >>>> >> > Please suggest for the future steps.
>     > > >>>> >> > Thanks
>     > > >>>> >> > Mritunjay
>     > > >>>> >> > On Mon, Jul 6, 2020 at 5:38 AM Joel Sherrill <joel at rtems.org
>     > > wrote:
>     > > >>>> >> >> On Sun, Jul 5, 2020, 6:12 PM Chris Johns <chrisj at rtems.org
>     <mailto:chrisj at rtems.org>>
>     > > wrote:
>     > > >>>> >> >>> On 6/7/20 12:47 am, Heinz Junkes wrote:
>     > > >>>> >> >>> > Thank you, this is exactly where I was unsure.
>     > > >>>> >> >>> > @Chris: Can you give a recommendation here?
>     > > >>>> >> >>> > Danke Heinz
>     > > >>>> >> >>> > Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
>     > > >>>> >> >>> > Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
>     > > >>>> >> >>> > Faradayweg 4-6        | VC: 102220181216 at bjn.vc
>     <mailto:102220181216 at bjn.vc>
>     > > >>>> >> >>> > D - 14195 Berlin        | E-Mail:
>     junkes at fhi-berlin.mpg.de <mailto:junkes at fhi-berlin.mpg.de>
>     > > >>>> >> >>> >> On 5. Jul 2020, at 16:20, Gedare Bloom <gedare at rtems.org
>     > > wrote:
>     > > >>>> >> >>> >> On Sat, Jul 4, 2020 at 1:18 PM Mritunjay Sharma
>     > > >>>> >> >>> >>> On Sun, Jul 5, 2020 at 12:28 AM Heinz Junkes <junkes at fhi-
>     > > berlin.mpg.de <http://berlin.mpg.de>> wrote:
>     > > >>>> >> >>> >>>> Hello, Mritunjay,
>     > > >>>> >> >>> >>>> that's good news. Don't you want to try to develop a rsb-
>     > > set for exactly this combination of RTEMS4.10 and EPICS7?
>     > > >>>> >> >>> >>> Sure, I am ready to do this and then do it with RTEMS5 in
>     > > the same way. Please tell how to begin or some existing similar
>     > > >>>> >> >>> >>> work that can guide me how to proceed further in relation
>     > > to rsb-set for  RTEMS4.10 and EPICS7.
>     > > >>>> >> >>> >> I don't know if this is best. RSB didn't exist in 4.10. I
>     haven't
>     > > >>>> >> >>> >> looked to see how well the rtems-source-builder/4.10 would
>     > > support a
>     > > >>>> >> >>> >> package build. It should be discussed with Chris probably. A
>     > > couple of
>     > > >>>> >> >>> >> packages were added in the 4.11 branch.
>     > > >>>> >> >>> I would leave 4.10 and move on. It may work but these things
>     > > can expose issues
>     > > >>>> >> >>> that turn into distractions.
>     > > >>>> >> >>> Would making a script that does the build so we can document
>     > > the steps be worth
>     > > >>>> >> >>> while
>     > > >>>> >> >> Yes. Emphatically yes. We need to make sure we know how it is
>     > > best built by hand to automate it.
>     > > >>>> >> >> I firmly believe you should not attempt to automate something
>     > > until doing it manually is well understood and documented.
>     > > >>>> >> >> After you have this down for one BSP, we need to ask questions
>     > > like:
>     > > >>>> >> >> + Is there any per BSP tailoring beyond the obviod architecture
>     > > and compilation settings?
>     > > >>>> >> >> + Any tweaks to settings users may want?
>     > > >>>> >> >> The manual process should include testing. The RSB is a great
>     > > way to automate and ease building but it doesn't address testing the
>     > > packages yet.
>     > > >>>> >> >> --joel
>     > > >>>> >> >>> Chris
>     > > >>>> >> >>> _______________________________________________
>     > > >>>> >> >>> devel mailing list
>     > > >>>> >> >>> devel at rtems.org <mailto:devel at rtems.org>
>     > > >>>> >> >>> http://lists.rtems.org/mailman/listinfo/devel
>     > > >>>> >> >> devel mailing list
>     > > devel mailing list
