build error in testsuites libtests
Kuan-Hsun Chen c0066c at gmail.com
Wed Jul 1 15:53:21 UTC 2020
Hello all,
I answer myself... my path was polluted unintendedly by 4.11 toolchains :/
With the latest RSB and the latest RTEMS 6 source code, everything goes
well for realview_pbx_a9_qemu_smp.
Best,
Kuan-Hsun
On Wed, Jul 1, 2020 at 3:24 PM Kuan-Hsun Chen <c0066c at gmail.com> wrote:
> Hello all,
> I tried to build RTEMS 5 and RTEMS 6 via RSB on Debian. It seems to me
> that libtests in testsuites use rtems-bin2c with option "-N" which is not
> supported anymore:
> rtems-bin2c -N dl06_tar -C dl06-pre.tar dl06-pre-tar.c
> usage: bin2c [-csvzCH] <input_file> <output_file>
>   <input_file> is the binary file to convert
>   <output_file> should not have a .c or .h extension
> The bsp target I use is realview_pbx_a9_qemu and I use the following flags:
> ../rtems/configure --target=arm-rtems5
> --enable-rtemsbsp=realview_pbx_a9_qemu_smp --enable-smp --enable-tests=yes
> Is there a remedy for this already?
> Best,
> Kuan-Hsun
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200701/f2bb047a/attachment.html>
