Application configuration option documentation license change
Sebastian Huber
Fri Jul 3 19:34:34 UTC 2020
Hello,
for your information, I carried out the license change of the
application configuration options documentation. They are now under a
dual CC-BY-SA-4.0 or BSD-2-Clause license.
https://git.rtems.org/sebh/rtems-qual.git/commit/?id=c116767b19e109f007d683e477481af67d603816
This allows generation of documentation sources under CC-BY-SA-4.0
license and Doxygen markup under BSD-2-Clause license.
I work currently on a generation of the Doxygen markup. This allows to
easily reference configuration options in the Doxygen documentation. For
example, this can be used to improve documentation for configuration
defined data structures such as:
* @brief Registered schedulers.
* Application provided via <rtems/confdefs.h>.
* @see _Scheduler_Count.
extern const Scheduler_Control _Scheduler_Table[];
