[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
    Mritunjay Sharma
    mritunjaysharma394 at gmail.com
    Fri Jul  3 21:56:18 UTC 2020
[UPDATE]: After using --enable-posix, the 'make' in epics-base worked
successfully.
With all of yours support, there are no errors. Everything seems to be
in order.
Heinz, as you suggested, now I have built EPICS with RTEMS 4.10 for pc-386
and as advised that after this
we can take care of RTEMS5 (or 6?) and libbsd as I have learnt now how to
build EPICS and I think we can develop
a first rsb-set for it.
Please advise on what to begin with next.
Thanks
Mritunjay
On Sat, Jul 4, 2020 at 3:02 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> Thank you so much Gedare, I will do it and revert back to you.
> Thanks
> Mritunjay
> On Sat, Jul 4, 2020 at 3:01 AM Gedare Bloom <gedare at rtems.org> wrote:
>> On Fri, Jul 3, 2020 at 3:07 PM Mritunjay Sharma
>> <mritunjaysharma394 at gmail.com> wrote:
>> > On Fri, Jul 3, 2020 at 10:53 PM Mritunjay Sharma <
>> >> ________________________________
>> >> From: Gedare Bloom <gedare at rtems.org>
>> >> Sent: Friday, July 3, 2020 9:42 PM
>> >> To: Mritunjay Sharma
>> >> Cc: Heinz Junkes; Chris Johns; RTEMS Devel
>> >> Subject: Re: [GSoC 2020: Daily Update]: Building EPICS with RTEMS5
>> >> On Fri, Jul 3, 2020 at 9:17 AM Mritunjay Sharma
>> >> > Hello Heinz and everyone,
>> >> > Thank you so much, with this email, I will try to clear all the
>> things, and what is the status for now.
>> >> > First. let me tell you the current status: Vijay helped me last
>> night in an offlist discussion to clear the confusions which
>> >> > I was having (I will mention them below) due to which I was able to
>> build and install RTEMS 4.10 for pc386 successfully.
>> >> > With that, all my previous errors were resolved. Below is the detail
>> of all the steps, I followed.
>> >> > Let me tell that my development environment was earlier set up for
>> RTEMS5. For building EPICS with RTEMS,
>> >> > I thought it will be right to first build RTEMS 4.10 for pc386.
>> >> > In order to do that, I made the directory
>> >> > i) $HOME/development/rtems_dev
>> >> > ii) I extracted rtems-4.10.2 from here
>> https://ftp.rtems.org/pub/rtems/releases/4.10/4.10.2/
>> >> > iii)I created another directory rtems_dev/src
>> >> > iv)Inside src, I cloned rsb and moved to 4.10 branch.
>> >> > v) After performing checks, I entered to rsb/rtems and used this
>> command:
>> >> > '../source-builder/sb-set-builder
>> --prefix=/home/mritunjay/development/rtems_dev/rtems-4.10.2 4.10/rtems-i386'
>> >> > Even though the build completed successfully, this was the point
>> where I made the error. I used the RTEMS source as the prefix which
>> >> > was causing all the problems.
>> >> > vi) After the discussion with Vijay and getting cleared, I deleted
>> everything except the RTEMS RSB and restarted the process with prefix and
>> source
>> >> > different this time and rebuilt the compiler tools using RSB.
>> >> > vii) Now the directory structure under $HOME/development/rtems_dev/
>> looked like:
>> >> >       | rtems-4.10.2
>> >> >       | 4.10
>> >> >       | src/rsb
>> >> >       | kernel/pc386
>> >> > I also used this command: "export
>> PATH=$HOME/development/rtems_dev/4.10/bin:$PATH"
>> >> > vi) Then I went to rtems_dev/rtems-4.10.2 and used this command:
>> >> > "./bootstrap -c &&
>> $HOME/development/rtems_dev/src/rsb/source-builder/sb-bootstrap"
>> >> > vi) After this I went insid directory
>> $HOME/development/rtems_dev/kernel/pc-386
>> >> > vii) Inside pc-386, I used the following command:
>> >> > ''$HOME/development/rtems_dev/rtems-4.10.2/configure
>> --target=i386-rtems4.10 --disable-posix  --enable-rtemsbsp=pc386
>> --enable-tests=samples --prefix=/home/development/rtems_dev/rtems-4.10.2
>> --enable-cxx"
>> You need to --enable-posix
>> >> > viii) Then I entered the make command which ran successfully and the
>> make install was also successful.
>> >> > So all the errors were resolved and I moved on to build EPICS now
>> for RTEMS 4.10.
>> >> > '''export
>> RTEMS_MAKEFILE_PATH=$HOME/development/rtems_dev/4.10/i386-rtems4.10/pc386''
>> >> > Location of epics-base in my system is as follows:
>> >> > "$HOME/development/EPICS/epics-base"
>> >> > After this, I followed the tutorial you sent to build EPICS for
>> rterms-4.10 for pc-386 which is:
>> >> >> Very roughly:
>> >> >> git clone —recursive epics-base
>> >> >> in epics-base/configure/CONFIG_SITE
>> >> >> set
>> >> >> CROSS_COMPILER_TARGET_ARCHS=
>> >> >    What I entered:
>> >> >    CROSS_COMPILER_TARGET_ARCHS=  RTEMS-pc386
>> >> >> e.g. RTEMS-pc386
>> >> >> or RTEMS-xilinx_zynq_a9_qemu
>> >> >> in epics-base/configure/os there must be a file for the target used,
>> >> >> e.g.
>> >> >> CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
>> >> >> or
>> >> >> CONFIG.Common.RTEMS-pc386
>> >> > Checked.  CONFIG.Common.RTEMS-pc386 was there
>> >> >> Then you have to set in configure/os/CONFIG_SITE.Common.RTEMS
>> >> >> where to find RTEMS:
>> >> >> # Where to find RTEMS
>> >> >> # APS:
>> >> >> #RTEMS_VERSION = 4.10.2
>> >> >> #RTEMS_BASE = /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)
>> >> > In my system, I entered this:
>> >> > #APS
>> >> > RTEMS_BASE = /home/mritunjay/development/rtems_dev/$(RTEMS_VERSION)
>> >> > I followed the above instructions and used the 'make' command.
>> >> > While the earlier errors are resolved, The latest error that I have
>> encountered is this after using make command.:
>> >> > ".......Info':
>> /home/mritunjay/development/EPICS/epics-base/modules/libcom/src/O.RTEMS-pc386/../osi/os/RTEMS/osdThread.c:747:
>> undefined reference to `pthread_getschedparam'
>> >> > collect2: ld returned 1 exit status
>> >> > ../../../../configure/RULES_BUILD:212: recipe for target
>> 'libComTestHarness' failed
>> >> > make[4]: *** [libComTestHarness] Error 1
>> >> > make[4]: Leaving directory
>> '/home/mritunjay/development/EPICS/epics-base/modules/libcom/test/O.RTEMS-pc386'
>> >> > ../../../configure/RULES_ARCHS:58: recipe for target
>> 'install.RTEMS-pc386' failed
>> >> > make[3]: *** [install.RTEMS-pc386] Error 2
>> >> > make[3]: Leaving directory
>> '/home/mritunjay/development/EPICS/epics-base/modules/libcom/test'
>> >> > ../../configure/RULES_DIRS:85: recipe for target 'test.install'
>> failed
>> >> > make[2]: *** [test.install] Error 2
>> >> > make[2]: Leaving directory
>> '/home/mritunjay/development/EPICS/epics-base/modules/libcom'
>> >> > ../configure/RULES_DIRS:85: recipe for target 'libcom.install' failed
>> >> > make[1]: *** [libcom.install] Error 2
>> >> > make[1]: Leaving directory
>> '/home/mritunjay/development/EPICS/epics-base/modules'
>> >> > configure/RULES_DIRS:85: recipe for target 'modules.install' failed
>> >> > make: *** [modules.install] Error 2"
>> >> > I hope this time I was explicit in writing what I did and what error
>> I am facing as of now. It would be kind
>> >> > of you to guide where I am going wrong.
>> >> Probably the current epics-base is not working with 4.10.2 any longer?
>> >> The pthread_getschedparam() was introduced to allow epics-base to
>> >> compile properly with the 4.10 HEAD (pending 4.10.3 release). Use the
>> >> 4.10 HEAD instead of 4.10.2 release/tag and see how the process goes
>> >> instead.
>> >> Thank you so much Gedare, I will check and revert as soon as possible.
>> > I used the 4.10 HEAD as suggested by you and I cross-checked it using
>> ` cat .git/HEAD`
>> > which showed the following result: `ref: refs/heads/4.10`. I did the
>> entire process again with 4.10 ahead but I got the
>> > same error again after using 'make' in epics-base.
>> > Thanks,
>> > Mritunjay
>> >> Mritunjay.
>> >> > Thanks,
>> >> > Mritunjay
>> >> > On Fri, Jul 3, 2020 at 9:03 AM Heinz Junkes <
>> junkes at fhi-berlin.mpg.de> wrote:
>> >> >> Hello, Mritunjay,
>> >> >> unfortunately i still miss a transcript in which the things you do
>> are listed in detail.
>> >> >> Then we could really help you better.
>> >> >> Heinz
>> >> >> > On 3. Jul 2020, at 04:14, Chris Johns <chrisj at rtems.org> wrote:
>> >> >> > On 3/7/20 9:01 am, Mritunjay Sharma wrote:
>> >> >> >> Thank you so much Gedare, I think the problem was with confusion
>> related to
>> >> >> >> prefix and source being the same which created a lot of problems.
>> >> >> >> I just had an offlist discussion with Vijay and he has cleared
>> all my doubts and
>> >> >> >> the mistakes I was making. The problem as of now seems to be
>> resolved.
>> >> >> > Vijay, thanks for helping and Mritunjay thank you for letting us
>> know.
>> >> >> > Chris
>> >> >> > _______________________________________________
>> >> >> > devel mailing list
>> >> >> > devel at rtems.org
>> >> >> > http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200704/25e8a642/attachment.html>
