[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
    Heinz Junkes
    junkes at fhi-berlin.mpg.de
    Sat Jul  4 18:58:46 UTC 2020
Hello, Mritunjay,
that's good news. Don't you want to try to develop a rsb-set for exactly this combination of RTEMS4.10 and EPICS7?
Then it should be no problem to do it with RTEMS5 in the same way.
Did you also run the tests on Epics and also tried the pc386-qemu?
Greetings Heinz
> On 3. Jul 2020, at 23:56, Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
> [UPDATE]: After using --enable-posix, the 'make' in epics-base worked successfully.
> With all of yours support, there are no errors. Everything seems to be in order.
> Heinz, as you suggested, now I have built EPICS with RTEMS 4.10 for pc-386 and as advised that after this
> we can take care of RTEMS5 (or 6?) and libbsd as I have learnt now how to build EPICS and I think we can develop
> a first rsb-set for it.
> Please advise on what to begin with next.
> Thanks
> Mritunjay
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200704/ee8fecd3/attachment.bin>
