Error in bootstraping RTEMS
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Sat Jul 4 19:20:21 UTC 2020
Hello Eshan,
Can you please try to re-run bootstrap? I think I faced similar error and bootstrapping again helped me
Thanks,
Mritunjay
Get Outlook for iOS<https://aka.ms/o0ukef>
________________________________
From: devel <devel-bounces at rtems.org> on behalf of Eshan Dhawan <eshandhawan51 at gmail.com>
Sent: Sunday, July 5, 2020 12:40:37 AM
To: rtems-devel at rtems.org <devel at rtems.org>
Subject: Error in bootstraping RTEMS
hello everyone,
I was bootstrapping my branch and got this error
link to the branch : https://github.com/eshandhawan51/rtems/tree/ftw_test
It has tests for FTW.H tests
error :
120/121: autoreconf: testsuites/libtests/configure.ac<http://configure.ac>
Makefile.am:457: error: lib_tests must be set with '=' before using '+='
Makefile.am:458: error: lib_screens must be set with '=' before using '+='
Makefile.am:459: error: lib_docs must be set with '=' before using '+='
Makefile.am:460: warning: variable 'tar01_SOURCES' is defined but no program or
Makefile.am:460: library has 'tar01' as canonical name (possible typo)
Makefile.am:465: warning: variable 'tar01_LDADD' is defined but no program or
Makefile.am:465: library has 'tar01' as canonical name (possible typo)
autoreconf: automake failed with exit status: 1
error: error: autoreconf: autoreconf -i --no-recursive
Bootstrap FAILED
Thanks
- Eshan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200704/cc8e2f38/attachment-0001.html>
