Error in bootstraping RTEMS
Eshan Dhawan eshandhawan51 at gmail.com
Sat Jul 4 19:21:46 UTC 2020
On Sun, Jul 5, 2020 at 12:50 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> Hello Eshan,
> Can you please try to re-run bootstrap? I think I faced similar error and
> bootstrapping again helped me
I tried It wont work :(
-Eshan
> Thanks,
> Mritunjay
> Get Outlook for iOS <https://aka.ms/o0ukef>
> *From:* devel <devel-bounces at rtems.org> on behalf of Eshan Dhawan <
> eshandhawan51 at gmail.com>
> *Sent:* Sunday, July 5, 2020 12:40:37 AM
> *To:* rtems-devel at rtems.org <devel at rtems.org>
> *Subject:* Error in bootstraping RTEMS
> hello everyone,
> I was bootstrapping my branch and got this error
> link to the branch : https://github.com/eshandhawan51/rtems/tree/ftw_test
> It has tests for FTW.H tests
> error :
> 120/121: autoreconf: testsuites/libtests/configure.ac
> Makefile.am:457: error: lib_tests must be set with '=' before using '+='
> Makefile.am:458: error: lib_screens must be set with '=' before using '+='
> Makefile.am:459: error: lib_docs must be set with '=' before using '+='
> Makefile.am:460: warning: variable 'tar01_SOURCES' is defined but no
> program or
> Makefile.am:460: library has 'tar01' as canonical name (possible typo)
> Makefile.am:465: warning: variable 'tar01_LDADD' is defined but no program
> or
> Makefile.am:465: library has 'tar01' as canonical name (possible typo)
> autoreconf: automake failed with exit status: 1
> error: error: autoreconf: autoreconf -i --no-recursive
> Bootstrap FAILED
> Thanks
> - Eshan
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200705/bd72b1ff/attachment.html>
