[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
    Mritunjay Sharma
    mritunjaysharma394 at gmail.com
    Sat Jul  4 21:03:36 UTC 2020
On Sun, Jul 5, 2020 at 12:48 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> On Sun, Jul 5, 2020 at 12:28 AM Heinz Junkes <junkes at fhi-berlin.mpg.de>
> wrote:
>> Hello, Mritunjay,
>> that's good news. Don't you want to try to develop a rsb-set for exactly
>> this combination of RTEMS4.10 and EPICS7?
> Sure, I am ready to do this and then do it with RTEMS5 in the same way.
> Please tell how to begin or some existing similar
> work that can guide me how to proceed further in relation to rsb-set for
> RTEMS4.10 and EPICS7.
> Then it should be no problem to do it with RTEMS5 in the same way.
>> Did you also run the tests on Epics and also tried the pc386-qemu?
[UPDATE]: I just finished trying pc386-qemu. The 'make' in epics-base ran
successfully.
After which I ran the Ran the EPICS test suites for RTEMS in QEMU using the
following command:
```qemu-system-i386 -no-reboot -m 128 -boot n -serial stdio  -net nic -net
user,tftp=$PWD,bootfile=bin/RTEMS-pc386-qemu/dbTestHarness```
The QEMU emulator successfully opened then and it showed that all the tests
passed.
I am attaching the screenshot as well.
Please check and tell if I have done things correctly.
Thanks
Mritunjay
> I did the following steps after the build:
> i) Created a new directory to hold the application source and then `cd' to
> that directory.
> ii) Run the makeBaseApp.pl program to create the example application:
> iii) makeBaseApp.pl -t example test
> iv) makeBaseApp.pl -i -t example -a RTEMS-pc386 test
> I then Built the example application by running
> 'make'
> All the steps ran without error.
> I didn't test further after this. I haven't tried for pc396-qemu yet,
> I will try though today.
> Thanks
> Mritunjay.
> Greetings Heinz
>> > On 3. Jul 2020, at 23:56, Mritunjay Sharma <
>> > [UPDATE]: After using --enable-posix, the 'make' in epics-base worked
>> successfully.
>> > With all of yours support, there are no errors. Everything seems to be
>> in order.
>> > Heinz, as you suggested, now I have built EPICS with RTEMS 4.10 for
>> pc-386 and as advised that after this
>> > we can take care of RTEMS5 (or 6?) and libbsd as I have learnt now how
>> to build EPICS and I think we can develop
>> > a first rsb-set for it.
>> > Please advise on what to begin with next.
>> > Thanks
>> > Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200705/d52f1027/attachment-0001.html>
Name: Screenshot from 2020-07-05 02-26-55.png
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200705/d52f1027/attachment-0001.png>
