Error in bootstraping RTEMS
Vijay Kumar Banerjee
vijay at rtems.org
Sun Jul 5 12:49:55 UTC 2020
On Sun, Jul 5, 2020 at 12:40 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
> hello everyone,
> I was bootstrapping my branch and got this error
> link to the branch : https://github.com/eshandhawan51/rtems/tree/ftw_test
> It has tests for FTW.H tests
> error :
> 120/121: autoreconf: testsuites/libtests/configure.ac
> Makefile.am:457: error: lib_tests must be set with '=' before using '+='
Hi Eshan,
In line 457 of psxtests/Makefile.am [1] you have added psxftw01 to
lib_tests, it should be added in psx_tests instead. You can look at
the other tests added in the same Makefile.am as a reference.
Best regards,
Vijay
[1]: https://github.com/eshandhawan51/rtems/blob/ftw_test/testsuites/psxtests/Makefile.am#L457
> Makefile.am:458: error: lib_screens must be set with '=' before using '+='
> Makefile.am:459: error: lib_docs must be set with '=' before using '+='
> Makefile.am:460: warning: variable 'tar01_SOURCES' is defined but no program or
> Makefile.am:460: library has 'tar01' as canonical name (possible typo)
> Makefile.am:465: warning: variable 'tar01_LDADD' is defined but no program or
> Makefile.am:465: library has 'tar01' as canonical name (possible typo)
> autoreconf: automake failed with exit status: 1
> error: error: autoreconf: autoreconf -i --no-recursive
> Bootstrap FAILED
> Thanks
> - Eshan
> devel mailing list
> devel at rtems.org
