Error in bootstraping RTEMS
Eshan Dhawan eshandhawan51 at gmail.com
Sun Jul 5 16:35:39 UTC 2020
Sent from my iPhone
> On 05-Jul-2020, at 6:20 PM, Vijay Kumar Banerjee <vijay at rtems.org> wrote:
> On Sun, Jul 5, 2020 at 12:40 AM Eshan Dhawan <eshandhawan51 at gmail.com> wrote:
>> hello everyone,
>> I was bootstrapping my branch and got this error
>> link to the branch : https://github.com/eshandhawan51/rtems/tree/ftw_test
>> It has tests for FTW.H tests
>> error :
>> 120/121: autoreconf: testsuites/libtests/configure.ac
>> Makefile.am:457: error: lib_tests must be set with '=' before using '+='
> Hi Eshan,
> In line 457 of psxtests/Makefile.am [1] you have added psxftw01 to
> lib_tests, it should be added in psx_tests instead. You can look at
> the other tests added in the same Makefile.am as a reference.
Thanks Vijay for the help :)
-Eshan
> Best regards,
> Vijay
> [1]: https://github.com/eshandhawan51/rtems/blob/ftw_test/testsuites/psxtests/Makefile.am#L457
>> Makefile.am:458: error: lib_screens must be set with '=' before using '+='
>> Makefile.am:459: error: lib_docs must be set with '=' before using '+='
>> Makefile.am:460: warning: variable 'tar01_SOURCES' is defined but no program or
>> Makefile.am:460: library has 'tar01' as canonical name (possible typo)
>> Makefile.am:465: warning: variable 'tar01_LDADD' is defined but no program or
>> Makefile.am:465: library has 'tar01' as canonical name (possible typo)
>> autoreconf: automake failed with exit status: 1
>> error: error: autoreconf: autoreconf -i --no-recursive
>> Bootstrap FAILED
>> Thanks
>> - Eshan
>> devel mailing list
>> devel at rtems.org
