[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
Sun Jul 5 23:12:06 UTC 2020
On 6/7/20 12:47 am, Heinz Junkes wrote:
> Thank you, this is exactly where I was unsure.
> @Chris: Can you give a recommendation here?
> Danke Heinz
> Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
> Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
> Faradayweg 4-6        | VC: 102220181216 at bjn.vc
> D - 14195 Berlin        | E-Mail:        junkes at fhi-berlin.mpg.de
>> On 5. Jul 2020, at 16:20, Gedare Bloom <gedare at rtems.org> wrote:
>> On Sat, Jul 4, 2020 at 1:18 PM Mritunjay Sharma
>> <mritunjaysharma394 at gmail.com> wrote:
>>> On Sun, Jul 5, 2020 at 12:28 AM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
>>>> Hello, Mritunjay,
>>>> that's good news. Don't you want to try to develop a rsb-set for exactly this combination of RTEMS4.10 and EPICS7?
>>> Sure, I am ready to do this and then do it with RTEMS5 in the same way. Please tell how to begin or some existing similar
>>> work that can guide me how to proceed further in relation to rsb-set for  RTEMS4.10 and EPICS7.
>> I don't know if this is best. RSB didn't exist in 4.10. I haven't
>> looked to see how well the rtems-source-builder/4.10 would support a
>> package build. It should be discussed with Chris probably. A couple of
>> packages were added in the 4.11 branch.
I would leave 4.10 and move on. It may work but these things can expose issues
that turn into distractions.
Would making a script that does the build so we can document the steps be worth
while?
