[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
Mritunjay Sharma mritunjaysharma394 at gmail.com
Mon Jul 6 16:12:43 UTC 2020
Hello everyone,
Thank you, Heinz, Gedare, Chris and Joel for your advice.
If there are issues in making a buildset for 4.10
then should I build EPICS with RTEMS 5 by hand first and note
down the process and then proceed to make the buildset for it?
Please suggest for the future steps.
Thanks
Mritunjay
On Mon, Jul 6, 2020 at 5:38 AM Joel Sherrill <joel at rtems.org> wrote:
> On Sun, Jul 5, 2020, 6:12 PM Chris Johns <chrisj at rtems.org> wrote:
>> On 6/7/20 12:47 am, Heinz Junkes wrote:
>> > Thank you, this is exactly where I was unsure.
>> > @Chris: Can you give a recommendation here?
>> > Danke Heinz
>> > Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
>> > Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
>> > Faradayweg 4-6        | VC: 102220181216 at bjn.vc
>> > D - 14195 Berlin        | E-Mail:        junkes at fhi-berlin.mpg.de
>> >> On 5. Jul 2020, at 16:20, Gedare Bloom <gedare at rtems.org> wrote:
>> >> On Sat, Jul 4, 2020 at 1:18 PM Mritunjay Sharma
>> >> <mritunjaysharma394 at gmail.com> wrote:
>> >>> On Sun, Jul 5, 2020 at 12:28 AM Heinz Junkes <
>> junkes at fhi-berlin.mpg.de> wrote:
>> >>>> Hello, Mritunjay,
>> >>>> that's good news. Don't you want to try to develop a rsb-set for
>> exactly this combination of RTEMS4.10 and EPICS7?
>> >>> Sure, I am ready to do this and then do it with RTEMS5 in the same
>> way. Please tell how to begin or some existing similar
>> >>> work that can guide me how to proceed further in relation to rsb-set
>> for  RTEMS4.10 and EPICS7.
>> >> I don't know if this is best. RSB didn't exist in 4.10. I haven't
>> >> looked to see how well the rtems-source-builder/4.10 would support a
>> >> package build. It should be discussed with Chris probably. A couple of
>> >> packages were added in the 4.11 branch.
>> I would leave 4.10 and move on. It may work but these things can expose
>> issues
>> that turn into distractions.
>> Would making a script that does the build so we can document the steps be
>> worth
>> while
> Yes. Emphatically yes. We need to make sure we know how it is best built
> by hand to automate it.
> I firmly believe you should not attempt to automate something until doing
> it manually is well understood and documented.
> After you have this down for one BSP, we need to ask questions like:
> + Is there any per BSP tailoring beyond the obviod architecture and
> compilation settings?
> + Any tweaks to settings users may want?
> The manual process should include testing. The RSB is a great way to
> automate and ease building but it doesn't address testing the packages yet.
> --joel
>> Chris
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200706/968bdfc1/attachment.html>
