NEW BUILD SYSTEM: Cannot build rtems-libbsd
Niteesh G. S.
niteesh.gs at gmail.com
Mon Jul 6 18:09:37 UTC 2020
Hello all,
This thread has lost activity for quite some time.
Can someone please provide a solution to this. This is blocking me from
testing my patches with libbsd.
Thanks,
Niteesh.
On Tue, Jun 30, 2020 at 1:12 AM Christian Mauderer <oss at c-mauderer.de>
wrote:
> Hello,
> On 29/06/2020 21:39, Niteesh G. S. wrote:
> > Hello,
> > I tried compiling RTEMS-libBSD with RTEMS6 toolchain and the new build
> > system
> > but failed. I get errors when compiling RTEMS-libBSD
> > The new build system is pulled from Sebastian's branch
> > HEAD: e4c193ddc163d6adb1b003254af9cc6b5d174a6f
> > RTEMS was configured with the following options:
> > 1) ./waf bsp_defaults --rtems-bsps=arm/beagleboneblack > config.ini
> > 2) Enabled posix since libBSD complained about it during configuration.
> > 3) ./waf configure --prefix=$HOME/development/rtems/6
> > 4) ./waf -j32
> > 5) ./waf install
> > RTEMS-libBSD was configured with the following options:
> > 1) ./waf configure --prefix=$HOME/development/rtems/6
> > --rtems-bsps=arm/beagleboneblack --buildset=buildset/minimal.ini
> > --rtems-version=6
> > 2) ./waf -j16
> > I have attached the error log file.
> > Thanks,
> > Niteesh
> I assume that for some reason the linker flags are not set correctly. It
> seems that -ffunction-sections -fdata-sections isn't set. Sebastian: Is
> there some adaption to libbsd necessary to work with the new build
> system in RTEMS?
> Best regards
> Christian
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200706/c0364f43/attachment.html>
