[PATCH 0/1] Generate application configuration option documentation
Sebastian Huber
Tue Jul 7 11:25:03 UTC 2020
This patch adds the application configuration option documentation generated
from specification items:
https://git.rtems.org/sebh/rtems-qual.git/tree/spec/if/acfg
The header file is generated by the following script and module:
https://git.rtems.org/sebh/rtems-qual.git/tree/spec2doc.py
https://git.rtems.org/sebh/rtems-qual.git/tree/rtemsqual/applconfig.py
The module uses currently a hack to resolve references external to specification
items, e.g. sections in the RTEMS Classic API Guide or URLs. I think we need
specialized specification items for these external references.
Sebastian Huber (1):
Document application configuration options
cpukit/doxygen/appl-config.h | 4133 ++++++++++++++++++++++++++++++++++
1 file changed, 4133 insertions(+)
create mode 100644 cpukit/doxygen/appl-config.h
2.26.2
