[PATCH 1/1] Document application configuration options
Tue Jul 7 11:25:04 UTC 2020
Add a new directory for Doxygen-specific documentation content.  Add a
Doxygen only header file containing documentation of the application
configuration options.  The header file is generated from specification
items.
Update #3994.
 cpukit/doxygen/appl-config.h | 4125 ++++++++++++++++++++++++++++++++++
 1 file changed, 4125 insertions(+)
 create mode 100644 cpukit/doxygen/appl-config.h
diff --git a/cpukit/doxygen/appl-config.h b/cpukit/doxygen/appl-config.h
new file mode 100644
index 0000000000..0544356c92
--- /dev/null
+++ b/cpukit/doxygen/appl-config.h
@@ -0,0 +1,4125 @@
+ * Copyright (C) 2019, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2010 Gedare Bloom
+ * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
+ * are met:
+ * @defgroup RTEMSApplConfig Application Configuration Options
+ * @ingroup RTEMSAPI
+ * @defgroup RTEMSApplConfigBlockDeviceCacheConfiguration Block Device Cache Configuration
+ * @ingroup RTEMSApplConfig
+ * This section describes configuration options related to the Block Device
+ * Cache (bdbuf).
+ * @brief This configuration option is a boolean feature define.
+ * In case this configuration option is defined, then the Block Device Cache is
+ * initialized during system initialization.
+ * @par Default Configuration
+ * If this configuration option is undefined, then the described feature is not
+ * enabled.
+ * @par Notes
+ * Each option of the Block Device Cache (bdbuf) configuration can be
+ * explicitly set by the user with the configuration options below.  The Block
+ * Device Cache is used for example by the RFS and DOSFS filesystems.
+#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
+ * @brief This configuration option is an integer define.
+ * The value of this configuration option defines the maximum size of a buffer
+ * in bytes.
+ * @par Default Value
+ * The default value is 4096.
+ * @par Value Constraints
+ * @parblock
+ * The value of this configuration option shall satisfy all of the following
+ * constraints:
+ * * It shall be greater than or equal to 0.
+ * * It shall be an integral multiple of #CONFIGURE_BDBUF_BUFFER_MIN_SIZE.
+ * @endparblock
+#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE
+ * The value of this configuration option defines the minimum size of a buffer
+ * in bytes.
+ * The default value is 512.
+ * The value of this configuration option shall be greater than or equal to 0
+ * and less than or equal to ``UINT32_MAX``.
+#define CONFIGURE_BDBUF_BUFFER_MIN_SIZE
+ * The value of this configuration option defines the size of the cache memory
+ * in bytes.
+ * The default value is 32768.
+ * and less than or equal to ``SIZE_MAX``.
+#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
+ * The value of this configuration option defines the maximum blocks per
+ * read-ahead request.
+ * The default value is 0.
+ * @par Notes
+ * A value of 0 disables the read-ahead task (default).  The read-ahead task
+ * will issue speculative read transfers if a sequential access pattern is
+ * detected.  This can improve the performance on some systems.
+#define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
+ * The value of this configuration option defines the maximum blocks per write
+ * request.
+ * The default value is 16.
+#define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
+ * The value of this configuration option defines the read-ahead task priority.
+ * The default value is 15.
+ * The value of this configuration option shall be a valid Classic API task
+ * priority.  The set of valid task priorities is scheduler-specific.
+#define CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
+ * The value of this configuration option defines the task stack size of the
+ * Block Device Cache tasks in bytes.
+ * The default value is ``RTEMS_MINIMUM_STACK_SIZE``.
+ * @parblock
+ * constraints:
+ * * It shall be greater than or equal to #CONFIGURE_MINIMUM_TASK_STACK_SIZE.
+ * * It shall be less than or equal to a BSP-specific and application-specific
+ *   value which depends on the size of the memory available to the
+ *   application.
+ * * It shall be small enough so that the task stack space calculation carried
+ *   out by ``<rtems/confdefs.h>`` does not overflow an integer of type
+ *   ``uintptr_t``.
+ * @endparblock
+#define CONFIGURE_BDBUF_TASK_STACK_SIZE
+ * The value of this configuration option defines the swapout task maximum
+ * block hold time in milliseconds.
+ * The default value is 1000.
+#define CONFIGURE_SWAPOUT_BLOCK_HOLD
+ * The value of this configuration option defines the swapout task swap period
+ * in milliseconds.
+ * The default value is 250.
+#define CONFIGURE_SWAPOUT_SWAP_PERIOD
+ * The value of this configuration option defines the swapout task priority.
+#define CONFIGURE_SWAPOUT_TASK_PRIORITY
+ * The value of this configuration option defines the swapout worker task
+ * count.
+#define CONFIGURE_SWAPOUT_WORKER_TASKS
+ * priority.
+#define CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
+ * @defgroup RTEMSApplConfigBSPRelatedConfigurationOptions BSP Related Configuration Options
+ * This section describes configuration options related to the BSP.  Some
+ * configuration options may have a BSP-specific setting which is defined by
+ * ``<bsp.h>``.  The BSP-specific settings can be disabled by the
+ * #CONFIGURE_DISABLE_BSP_SETTINGS configuration option.
+ * @brief This configuration option is an initializer define.
+ * If
+ * * this configuration option is defined by the BSP
+ * * and #CONFIGURE_DISABLE_BSP_SETTINGS is undefined,
+ * then the value of this configuration option defines the default value of
+ * #CONFIGURE_IDLE_TASK_BODY.
+ * The default value is BSP-specific.
+ * The value of this configuration option shall be defined to a valid function
+ * pointer of the type ``void *( *idle_body )( uintptr_t )``.
+ * @par Notes
+ * As it has knowledge of the specific CPU model, system controller logic, and
+ * peripheral buses, a BSP-specific IDLE task may be capable of turning
+ * components off to save power during extended periods of no task activity.
+#define BSP_IDLE_TASK_BODY
+ * If
+ * #CONFIGURE_IDLE_TASK_STACK_SIZE.
+ * @parblock
+ * constraints:
+ * * It shall be greater than or equal to a BSP-specific and
+ *   application-specific minimum value.
+ * * It shall be small enough so that the IDLE task stack area calculation
+ *   carried out by ``<rtems/confdefs.h>`` does not overflow an integer of type
+ *   ``size_t``.
+ * @endparblock
+#define BSP_IDLE_TASK_STACK_SIZE
+ * If
+ * then the value of this configuration option is used to initialize the table
+ * of initial user extensions.
+ * The value of this configuration option shall be a list of initializers for
+ * structures of type ::rtems_extensions_table.
+ * @par Notes
+ * The value of this configuration option is placed after the entries of all
+ * other initial user extensions.
+#define BSP_INITIAL_EXTENSION
+ * If
+ * #CONFIGURE_INTERRUPT_STACK_SIZE.
+ * @parblock
+ * constraints:
+ * * It shall be small enough so that the interrupt stack area calculation
+ *   ``size_t``.
+ * * It shall be aligned according to ``CPU_INTERRUPT_STACK_ALIGNMENT``.
+ * @endparblock
+#define BSP_INTERRUPT_STACK_SIZE
+ * If
+ * @par Notes
+ * The value of this configuration option is placed before the entries of all
+ * other initial user extensions (including
+ * #CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS).
+#define CONFIGURE_BSP_PREREQUISITE_DRIVERS
+ * In case this configuration option is defined, then the following BSP related
+ * configuration options are undefined:
+ * * #BSP_IDLE_TASK_BODY
+ * * #BSP_IDLE_TASK_STACK_SIZE
+ * * #BSP_INITIAL_EXTENSION
+ * * #BSP_INTERRUPT_STACK_SIZE
+ * * #CONFIGURE_BSP_PREREQUISITE_DRIVERS
+ * * #CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
+ * enabled.
+#define CONFIGURE_DISABLE_BSP_SETTINGS
+ * If
+ * then not all memory is made available to the C Program Heap immediately at
+ * system initialization time.  When ``malloc()`` or other standard memory
+ * allocation functions are unable to allocate memory, they will call the BSP
+ * supplied ``sbrk()`` function to obtain more memory.
+ * enabled.
+ * @par Notes
+ * This option should not be defined by the application. Only the BSP knows how
+ * it allocates memory to the C Program Heap.
+#define CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK
+ * @defgroup RTEMSApplConfigClassicAPIConfiguration Classic API Configuration
+ * This section describes configuration options related to the Classic API.
+ * The value of this configuration option defines the maximum number of Classic
+ * API Barriers that can be concurrently active.
+ * @parblock
+ * constraints:
+ * * It shall be less than or equal to 65535.
+ *   application.
+ * * It may be defined through rtems_resource_unlimited() the enable unlimited
+ *   objects for this object class, if the value passed to
+ *   rtems_resource_unlimited() satisfies all other constraints of this
+ *   configuration option.
+ * @endparblock
+ * @par Notes
+ * This object class can be configured in unlimited allocation mode, see <a
+ * href=https://docs.rtems.org/branches/master/c-user/config/intro.html#unlimited-objects>Unlimited
+ * Objects</a>.
+#define CONFIGURE_MAXIMUM_BARRIERS
+ * API Message Queues that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * Objects</a>.  You have to account for the memory used to store the messages
+ * of each message queue, see #CONFIGURE_MESSAGE_BUFFER_MEMORY.
+#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES
+ * API Partitions that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * Objects</a>.
+#define CONFIGURE_MAXIMUM_PARTITIONS
+ * API Periods that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * Objects</a>.
+#define CONFIGURE_MAXIMUM_PERIODS
+ * API Ports that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * Objects</a>.
+#define CONFIGURE_MAXIMUM_PORTS
+ * API Regions that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * Objects</a>.
+#define CONFIGURE_MAXIMUM_REGIONS
+ * API Semaphore that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * Objects</a>.
+ * In SMP configurations, the size of a Semaphore Control Block depends on the
+ * scheduler count (see <a
+ * href=https://docs.rtems.org/branches/master/c-user/config/scheduler-clustered.html#configuration-step-3-scheduler-table>Configuration
+ * Step 3 - Scheduler Table</a>).  The semaphores using the <a
+ * href=https://docs.rtems.org/branches/master/c-user/key_concepts.html#multiprocessor-resource-sharing-protocol-mrsp>Multiprocessor
+ * Resource Sharing Protocol (MrsP)</a> need a ceiling priority per scheduler.
+ * @endparblock
+#define CONFIGURE_MAXIMUM_SEMAPHORES
+ * API Tasks that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ *   ``uintptr_t``.
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * Objects</a>.
+ * The calculations for the required memory in the RTEMS Workspace for tasks
+ * assume that each task has a minimum stack size and has floating point
+ * support enabled.  The configuration option #CONFIGURE_EXTRA_TASK_STACKS is
+ * used to specify task stack requirements *above* the minimum size required.
+ * The maximum number of POSIX threads is specified by
+ * #CONFIGURE_MAXIMUM_POSIX_THREADS.
+ * A future enhancement to ``<rtems/confdefs.h>`` could be to eliminate the
+ * assumption that all tasks have floating point enabled. This would require
+ * the addition of a new configuration parameter to specify the number of tasks
+ * which enable floating point support.
+ * @endparblock
+#define CONFIGURE_MAXIMUM_TASKS
+ * API Timers that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * Objects</a>.
+#define CONFIGURE_MAXIMUM_TIMERS
+ * API User Extensions that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * This object class cannot be configured in unlimited allocation mode.
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS
+ * @defgroup RTEMSApplConfigClassicAPIInitializationTaskConfiguration Classic API Initialization Task Configuration
+ * initialization task.
+ * The value of this configuration option defines task argument of the Classic
+ * API initialization task.
+ * The value of this configuration option shall be a valid integer of type
+ * ``rtems_task_argument``.
+#define CONFIGURE_INIT_TASK_ARGUMENTS
+ * The value of this configuration option defines the task attributes of the
+ * Classic API initialization task.
+ * The default value is ``RTEMS_DEFAULT_ATTRIBUTES``.
+ * The value of this configuration option shall be a valid task attribute set.
+#define CONFIGURE_INIT_TASK_ATTRIBUTES
+ * The value of this configuration option initializes the entry point of the
+ * The default value is ``Init``.
+ * pointer of the type ``void ( *entry_point )( rtems_task_argument )``.
+ * @par Notes
+ * The application shall provide the function referenced by this configuration
+ * option.
+#define CONFIGURE_INIT_TASK_ENTRY_POINT
+ * The value of this configuration option defines the initial execution mode of
+ * the Classic API initialization task.
+ * In SMP  configurations, the default value is ``RTEMS_DEFAULT_MODES``,
+ * otherwise the default value is ``RTEMS_NO_PREEMPT``.
+ * The value of this configuration option shall be a valid task mode set.
+#define CONFIGURE_INIT_TASK_INITIAL_MODES
+ * The value of this configuration option defines the name of the Classic API
+ * The default value is ``rtems_build_name( 'U', 'I', '1', ' ' )``.
+ * ::rtems_name.
+ * @par Notes
+ * Use rtems_build_name() to define the task name.
+#define CONFIGURE_INIT_TASK_NAME
+ * The value of this configuration option defines the initial priority of the
+ * The default value is 1.
+#define CONFIGURE_INIT_TASK_PRIORITY
+ * The default value is #CONFIGURE_MINIMUM_TASK_STACK_SIZE.
+ * @parblock
+ * constraints:
+ *   ``uintptr_t``.
+ * @endparblock
+#define CONFIGURE_INIT_TASK_STACK_SIZE
+ * In case this configuration option is defined, then exactly one Classic API
+ * initialization task is configured.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * The application shall define exactly one of the following configuration
+ * options
+ * * `CONFIGURE_RTEMS_INIT_TASKS_TABLE`,
+ * * #CONFIGURE_POSIX_INIT_THREAD_TABLE, or
+ * * #CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
+ * otherwise a compile time error in the configuration file will occur.
+ * @endparblock
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+ * @defgroup RTEMSApplConfigDeviceDriverConfiguration Device Driver Configuration
+ * This section describes configuration options related to the device drivers.
+ * Note that network device drivers are not covered by the following options.
+ * In case this configuration option is defined, then **no** Clock Driver is
+ * If this configuration option is undefined, then a Clock Driver may be
+ * @par Notes
+ * @parblock
+ * This configuration parameter is intended to prevent the common user error of
+ * using the Hello World example as the baseline for an application and leaving
+ * out a clock tick source.
+ * options
+ * * #CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER,
+ * * `CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER`, or
+ * * #CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER,
+ * @endparblock
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+ * The value of this configuration option is used to initialize the Device
+ * Driver Table.
+ * The default value is the empty list.
+ * structures of type ::rtems_driver_address_table.
+ * @par Notes
+ * @parblock
+ * The value of this configuration option is placed after the entries of other
+ * device driver configuration options.
+ * See #CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS for an alternative placement
+ * of application device driver initializers.
+ * @endparblock
+#define CONFIGURE_APPLICATION_EXTRA_DRIVERS
+ * In case this configuration option is defined, then the ATA Driver is
+ * enabled.
+ * @par Notes
+ * @parblock
+ * Most BSPs do not include support for an ATA Driver.
+ * If this option is defined and the BSP does not have this device driver, then
+ * the user will get a link time error for an undefined symbol.
+ * @endparblock
+#define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
+ * In case this configuration option is defined, then the Clock Driver is
+ * enabled.
+ * @par Notes
+ * @parblock
+ * The Clock Driver is responsible for providing a regular interrupt which
+ * invokes a clock tick directive.
+ * options
+ * * `CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER`,
+ * * #CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER, or
+ * @endparblock
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+ * In case this configuration option is defined, then the Console Driver is
+ * enabled.
+ * @par Notes
+ * @parblock
+ * The Console Driver is responsible for providing the ``/dev/console`` device
+ * file.  This device is used to initialize the standard input, output, and
+ * error file descriptors.
+ * BSPs should be constructed in a manner that allows ``printk()`` to work
+ * properly without the need for the Console Driver to be configured.
+ * The
+ * * #CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER,
+ * * #CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER, and
+ * * #CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
+ * configuration options are mutually exclusive.
+ * @endparblock
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+ * In case this configuration option is defined, then the Frame Buffer Driver
+ * is initialized during system initialization.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * Most BSPs do not include support for a Frame Buffer Driver. This is because
+ * many boards do not include the required hardware.
+ * @endparblock
+#define CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
+ * In case this configuration option is defined, then the IDE Driver is
+ * enabled.
+ * @par Notes
+ * @parblock
+ * Most BSPs do not include support for an IDE Driver.
+ * @endparblock
+#define CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
+ * In case this configuration option is defined, then the ``/dev/null`` Driver
+ * enabled.
+ * @par Notes
+ * This device driver is supported by all BSPs.
+#define CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
+ * In case this configuration option is defined, then the Real-Time Clock
+ * Driver is initialized during system initialization.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * Most BSPs do not include support for a real-time clock (RTC). This is
+ * because many boards do not include the required hardware.
+ * If this is defined and the BSP does not have this device driver, then the
+ * user will get a link time error for an undefined symbol.
+ * @endparblock
+#define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
+ * In case this configuration option is defined, then the Simple Console Driver
+ * enabled.
+ * @par Notes
+ * @parblock
+ * This device driver is responsible for providing the ``/dev/console`` device
+ * This device driver reads via ``getchark()``.
+ * This device driver writes via ``rtems_putc()``.
+ * The Termios framework is not used.  There is no support to change device
+ * settings, e.g. baud, stop bits, parity, etc.
+ * The
+ * @endparblock
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+ * In case this configuration option is defined, then the Simple Task Console
+ * enabled.
+ * @par Notes
+ * @parblock
+ * This device driver writes into a write buffer.  The count of characters
+ * written into the write buffer is returned.  It might be less than the
+ * requested count, in case the write buffer is full.  The write is
+ * non-blocking and may be called from interrupt context.  A dedicated task
+ * reads from the write buffer and outputs the characters via ``rtems_putc()``.
+ * This task runs with the least important priority. The write buffer size is
+ * 2047 characters and it is not configurable.
+ * Use ``fsync( STDOUT_FILENO )`` or ``fdatasync( STDOUT_FILENO )`` to drain
+ * the write buffer.
+ * The
+ * @endparblock
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
+ * In case this configuration option is defined, then the Stub Driver is
+ * enabled.
+ * @par Notes
+ * This device driver simply provides entry points that return successful and
+ * is primarily a test fixture. It is supported by all BSPs.
+#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
+ * In case this configuration option is defined, then the Benchmark Timer
+ * enabled.
+ * @par Notes
+ * @parblock
+ * The Benchmark Timer Driver is intended for the benchmark tests of the RTEMS
+ * Testsuite.  Applications should not use this driver.
+ * options
+ * * `CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER`,
+ * otherwise a compile time error will occur.
+ * @endparblock
+#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
+ * In case this configuration option is defined, then the Watchdog Driver is
+ * enabled.
+ * @par Notes
+ * @parblock
+ * Most BSPs do not include support for a watchdog device driver. This is
+ * @endparblock
+#define CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
+ * In case this configuration option is defined, then the ``/dev/zero`` Driver
+ * enabled.
+ * @par Notes
+#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
+ * Driver Table.
+ * @par Notes
+ * @parblock
+ * The value of this configuration option is placed after the entries defined
+ * by #CONFIGURE_BSP_PREREQUISITE_DRIVERS and before all other device driver
+ * configuration options.
+ * See #CONFIGURE_APPLICATION_EXTRA_DRIVERS for an alternative placement of
+ * application device driver initializers.
+ * @endparblock
+#define CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
+ * The value of this configuration option defines the ATA task priority.
+ * The default value is 140.
+ * @par Notes
+ * This configuration option is only evaluated if the configuration option
+ * #CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER is defined.
+#define CONFIGURE_ATA_DRIVER_TASK_PRIORITY
+ * The value of this configuration option defines the number of device drivers.
+ * This is computed by default, and is set to the number of device drivers
+ * configured using the ``CONFIGURE_APPLICATIONS_NEEDS_XXX_DRIVER``
+ * @parblock
+ * constraints:
+ * * It shall be less than or equal to ``SIZE_MAX``.
+ * * It shall be greater than or equal than the number of statically configured
+ *   device drivers.
+ *   application.
+ * @endparblock
+ * @par Notes
+ * If the application will dynamically install device drivers, then this
+ * configuration parameter shall be larger than the number of statically
+ * configured device drivers. Drivers configured using the
+ * ``CONFIGURE_APPLICATIONS_NEEDS_XXX_DRIVER`` configuration options are
+ * statically installed.
+#define CONFIGURE_MAXIMUM_DRIVERS
+ * @defgroup RTEMSApplConfigEventRecordingConfiguration Event Recording Configuration
+ * This section describes configuration options related to the event recording.
+ * In case
+ * * and #CONFIGURE_RECORD_PER_PROCESSOR_ITEMS is properly defined,
+ * then the event record extensions are enabled.
+ * enabled.
+ * @par Notes
+ * The record extensions capture thread create, start, restart, delete, switch,
+ * begin, exitted and terminate events.
+#define CONFIGURE_RECORD_EXTENSIONS_ENABLED
+ * In case
+ * * and #CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB is undefined,
+ * then the event records are dumped in Base64 encoding in a fatal error
+ * extension (see <a
+ * href=https://docs.rtems.org/branches/master/c-user/fatal_error.html#announcing-a-fatal-error>Announcing
+ * a Fatal Error</a>).
+ * enabled.
+ * @par Notes
+ * This extension can be used to produce crash dumps.
+#define CONFIGURE_RECORD_FATAL_DUMP_BASE64
+ * In case
+ * then the event records are compressed by zlib and dumped in Base64 encoding
+ * in a fatal error extension (see <a
+ * enabled.
+ * @par Notes
+ * The zlib compression needs about 512KiB of RAM.  This extension can be used
+ * to produce crash dumps.
+#define CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
+ * The value of this configuration option defines the event record item count
+ * per processor.
+ * @parblock
+ * constraints:
+ * * It shall be greater than or equal to 16.
+ * * It shall be a power of two.
+ *   application.
+ * @endparblock
+ * @par Notes
+ * The event record buffers are statically allocated for each configured
+ * processor (#CONFIGURE_MAXIMUM_PROCESSORS).  If the value of this
+ * configuration option is zero, then nothing is allocated.
+#define CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
+ * @defgroup RTEMSApplConfigFilesystemConfiguration Filesystem Configuration
+ * This section describes configuration options related to filesytems. By
+ * default, the In-Memory Filesystem (IMFS) is used as the base filesystem
+ * (also known as root filesystem).  In order to save some memory for your
+ * application, you can disable the filesystem support with the
+ * #CONFIGURE_APPLICATION_DISABLE_FILESYSTEM configuration option.
+ * Alternatively, you can strip down the features of the base filesystem with
+ * the #CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM and
+ * #CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM configuration options.  These three
+ * configuration options are mutually exclusive.  They are intended for an
+ * advanced application configuration.
+ * Features of the IMFS can be disabled and enabled with the following
+ * configuration options:
+ * * #CONFIGURE_IMFS_DISABLE_CHMOD
+ * * #CONFIGURE_IMFS_DISABLE_CHOWN
+ * * #CONFIGURE_IMFS_DISABLE_LINK
+ * * #CONFIGURE_IMFS_DISABLE_MKNOD
+ * * #CONFIGURE_IMFS_DISABLE_MKNOD_FILE
+ * * #CONFIGURE_IMFS_DISABLE_MOUNT
+ * * #CONFIGURE_IMFS_DISABLE_READDIR
+ * * #CONFIGURE_IMFS_DISABLE_READLINK
+ * * #CONFIGURE_IMFS_DISABLE_RENAME
+ * * #CONFIGURE_IMFS_DISABLE_RMNOD
+ * * #CONFIGURE_IMFS_DISABLE_SYMLINK
+ * * #CONFIGURE_IMFS_DISABLE_UNMOUNT
+ * * #CONFIGURE_IMFS_DISABLE_UTIME
+ * * #CONFIGURE_IMFS_ENABLE_MKFIFO
+ * In case this configuration option is defined, then **no** base filesystem is
+ * initialized during system initialization and **no** filesystems are
+ * configured.
+ * If this configuration option is undefined, then a base filesystem and the
+ * configured filesystems are initialized during system initialization.
+ * @par Notes
+ * Filesystems shall be initialized to support file descriptor based device
+ * drivers and basic input/output functions such as ``printf()``. Filesystems
+ * can be disabled to reduce the memory footprint of an application.
+#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+ * configuration options will be defined as well
+ * * #CONFIGURE_FILESYSTEM_DOSFS,
+ * * #CONFIGURE_FILESYSTEM_FTPFS,
+ * * #CONFIGURE_FILESYSTEM_IMFS,
+ * * #CONFIGURE_FILESYSTEM_JFFS2,
+ * * #CONFIGURE_FILESYSTEM_NFS,
+ * * #CONFIGURE_FILESYSTEM_RFS, and
+ * * #CONFIGURE_FILESYSTEM_TFTPFS.
+ * enabled.
+#define CONFIGURE_FILESYSTEM_ALL
+ * In case this configuration option is defined, then the DOS (FAT) filesystem
+ * is registered, so that instances of this filesystem can be mounted by the
+ * application.
+ * enabled.
+ * @par Notes
+ * This filesystem requires a Block Device Cache configuration, see
+ * #CONFIGURE_APPLICATION_NEEDS_LIBBLOCK.
+#define CONFIGURE_FILESYSTEM_DOSFS
+ * In case this configuration option is defined, then the FTP filesystem (FTP
+ * client) is registered, so that instances of this filesystem can be mounted
+ * by the application.
+ * enabled.
+#define CONFIGURE_FILESYSTEM_FTPFS
+ * In case this configuration option is defined, then the In-Memory Filesystem
+ * (IMFS) is registered, so that instances of this filesystem can be mounted by
+ * the application.
+ * enabled.
+ * @par Notes
+ * Applications will rarely need this configuration option.  This configuration
+ * option is intended for test programs.  You do not need to define this
+ * configuration option for the base filesystem (also known as root
+ * filesystem).
+#define CONFIGURE_FILESYSTEM_IMFS
+ * In case this configuration option is defined, then the JFFS2 filesystem is
+ * registered, so that instances of this filesystem can be mounted by the
+ * application.
+ * enabled.
+#define CONFIGURE_FILESYSTEM_JFFS2
+ * In case this configuration option is defined, then the Network Filesystem
+ * (NFS) client is registered, so that instances of this filesystem can be
+ * mounted by the application.
+ * enabled.
+#define CONFIGURE_FILESYSTEM_NFS
+ * In case this configuration option is defined, then the RTEMS Filesystem
+ * (RFS) is registered, so that instances of this filesystem can be mounted by
+ * enabled.
+ * @par Notes
+#define CONFIGURE_FILESYSTEM_RFS
+ * In case this configuration option is defined, then the TFTP filesystem (TFTP
+ * enabled.
+#define CONFIGURE_FILESYSTEM_TFTPFS
+ * In case this configuration option is defined, then the root IMFS does not
+ * support changing the mode of files (no support for ``chmod()``).
+ * If this configuration option is undefined, then the root IMFS supports
+ * changing the mode of files.
+#define CONFIGURE_IMFS_DISABLE_CHMOD
+ * support changing the ownership of files (no support for ``chown()``).
+ * changing the ownership of files.
+#define CONFIGURE_IMFS_DISABLE_CHOWN
+ * support hard links (no support for ``link()``).
+ * If this configuration option is undefined, then the root IMFS supports hard
+ * links.
+#define CONFIGURE_IMFS_DISABLE_LINK
+ * support making files (no support for ``mknod()``).
+ * making files.
+#define CONFIGURE_IMFS_DISABLE_MKNOD
+ * support making device files.
+ * making device files.
+#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
+ * support making regular files.
+ * making regular files.
+#define CONFIGURE_IMFS_DISABLE_MKNOD_FILE
+ * support mounting other filesystems (no support for ``mount()``).
+ * mounting other filesystems.
+#define CONFIGURE_IMFS_DISABLE_MOUNT
+ * support reading directories (no support for ``readdir()``).  It is still
+ * possible to open files in a directory.
+ * reading directories.
+#define CONFIGURE_IMFS_DISABLE_READDIR
+ * support reading symbolic links (no support for ``readlink()``).
+ * reading symbolic links.
+#define CONFIGURE_IMFS_DISABLE_READLINK
+ * support renaming files (no support for ``rename()``).
+ * renaming files.
+#define CONFIGURE_IMFS_DISABLE_RENAME
+ * support removing files (no support for ``rmnod()``).
+ * removing files.
+#define CONFIGURE_IMFS_DISABLE_RMNOD
+ * support creating symbolic links (no support for ``symlink()``).
+ * creating symbolic links.
+#define CONFIGURE_IMFS_DISABLE_SYMLINK
+ * support unmounting other filesystems (no support for ``unmount()``).
+ * unmounting other filesystems.
+#define CONFIGURE_IMFS_DISABLE_UNMOUNT
+ * support changing file times (no support for ``utime()``).
+ * changing file times.
+#define CONFIGURE_IMFS_DISABLE_UTIME
+ * In case this configuration option is defined, then the root IMFS supports
+ * making FIFOs.
+ * If this configuration option is undefined, then the root IMFS does not
+ * support making FIFOs (no support for ``mkfifo()``).
+#define CONFIGURE_IMFS_ENABLE_MKFIFO
+ * The value of this configuration option defines the block size for in-memory
+ * files managed by the IMFS.
+ * The default value is 128.
+ * The value of this configuration option shall be an element of {16, 32, 64,
+ * 128, 256, 512}.
+ * @par Notes
+ * @parblock
+ * The configured block size has two impacts. The first is the average amount
+ * of unused memory in the last block of each file.  For example, when the
+ * block size is 512, on average one-half of the last block of each file will
+ * remain unused and the memory is wasted. In contrast, when the block size is
+ * 16, the average unused memory per file is only 8 bytes. However, it requires
+ * more allocations for the same size file and thus more overhead per block for
+ * the dynamic memory management.
+ * Second, the block size has an impact on the maximum size file that can be
+ * stored in the IMFS. With smaller block size, the maximum file size is
+ * correspondingly smaller. The following shows the maximum file size possible
+ * based on the configured block size:
+ * * when the block size is 16 bytes, the maximum file size is 1,328 bytes.
+ * * when the block size is 32 bytes, the maximum file size is 18,656 bytes.
+ * * when the block size is 64 bytes, the maximum file size is 279,488 bytes.
+ * * when the block size is 128 bytes, the maximum file size is 4,329,344
+ *   bytes.
+ * * when the block size is 256 bytes, the maximum file size is 68,173,568
+ *   bytes.
+ * * when the block size is 512 bytes, the maximum file size is 1,082,195,456
+ *   bytes.
+ * @endparblock
+#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
+ * In case this configuration option is defined, then an IMFS with a reduced
+ * feature set will be the base filesystem (also known as root filesystem).
+ * enabled.
+ * @par Notes
+ * @parblock
+ * * #CONFIGURE_IMFS_DISABLE_CHMOD,
+ * * #CONFIGURE_IMFS_DISABLE_CHOWN,
+ * * #CONFIGURE_IMFS_DISABLE_LINK,
+ * * #CONFIGURE_IMFS_DISABLE_MKNOD_FILE,
+ * * #CONFIGURE_IMFS_DISABLE_MOUNT,
+ * * #CONFIGURE_IMFS_DISABLE_READDIR,
+ * * #CONFIGURE_IMFS_DISABLE_READLINK,
+ * * #CONFIGURE_IMFS_DISABLE_RENAME,
+ * * #CONFIGURE_IMFS_DISABLE_RMNOD,
+ * * #CONFIGURE_IMFS_DISABLE_SYMLINK,
+ * * #CONFIGURE_IMFS_DISABLE_UTIME, and
+ * * #CONFIGURE_IMFS_DISABLE_UNMOUNT.
+ * In addition, a simplified path evaluation is enabled.  It allows only a look
+ * up of absolute paths.
+ * This configuration of the IMFS is basically a device-only filesystem.  It is
+ * comparable in functionality to the pseudo-filesystem name space provided
+ * before RTEMS release 4.5.0.
+ * @endparblock
+#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
+ * enabled.
+ * @par Notes
+ * @parblock
+ * @endparblock
+#define CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
+ * @defgroup RTEMSApplConfigGeneralSystemConfiguration General System Configuration
+ * This section describes general system configuration options.
+ * In case this configuration option is defined, then the memory areas used for
+ * the RTEMS Workspace and the C Program Heap are dirtied with a ``0xCF`` byte
+ * pattern during system initialization.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * Dirtying memory can add significantly to system initialization time.  It may
+ * assist in finding code that incorrectly assumes the contents of free memory
+ * areas is cleared to zero during system initialization.  In case
+ * #CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is also defined, then the memory is
+ * first dirtied and then zeroed.
+ * See also #CONFIGURE_MALLOC_DIRTY.
+ * @endparblock
+#define CONFIGURE_DIRTY_MEMORY
+ * In case this configuration option is defined, then the Newlib reentrancy
+ * support per thread is disabled and a global reentrancy structure is used.
+ * enabled.
+ * @par Notes
+ * You can enable this option to reduce the size of the :term:`TCB`.  Use this
+ * option with care, since it can lead to race conditions and undefined system
+ * behaviour.  For example, ``errno`` is no longer a thread-local variable if
+ * this option is enabled.
+#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
+ * The value of this configuration option defines the RTEMS Workspace size in
+ * bytes.
+ * If this configuration option is undefined, then the RTEMS Workspace and task
+ * stack space size is calculated by ``<rtems/confdefs.h>`` based on the values
+ * @parblock
+ * constraints:
+ * * It shall be less than or equal to ``UINTPTR_MAX``.
+ *   application.
+ * @endparblock
+ * @par Notes
+ * This is an advanced configuration option.  Use it only if you know exactly
+ * what you are doing.
+#define CONFIGURE_EXECUTIVE_RAM_SIZE
+ * The value of this configuration option defines the number of bytes the
+ * applications wishes to add to the task stack requirements calculated by
+ * ``<rtems/confdefs.h>``.
+ * @parblock
+ * constraints:
+ *   ``uintptr_t``.
+ * @endparblock
+ * @par Notes
+ * This parameter is very important.  If the application creates tasks with
+ * stacks larger then the minimum, then that memory is **not** accounted for by
+#define CONFIGURE_EXTRA_TASK_STACKS
+ * The value of this configuration option is used to initialize the table of
+ * initial user extensions.
+ * @par Notes
+ * #BSP_INITIAL_EXTENSION and after the entries of all other initial user
+ * extensions.
+#define CONFIGURE_INITIAL_EXTENSIONS
+ * The value of this configuration option defines the size of an interrupt
+ * stack in bytes.
+ * The default value is #BSP_INTERRUPT_STACK_SIZE in case it is defined,
+ * otherwise the default value is ``CPU_STACK_MINIMUM_SIZE``.
+ * @parblock
+ * constraints:
+ *   ``size_t``.
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * There is one interrupt stack available for each configured processor
+ * (#CONFIGURE_MAXIMUM_PROCESSORS).  The interrupt stack areas are statically
+ * allocated in a special linker section (``.rtemsstack.interrupt``). The
+ * placement of this linker section is BSP-specific.
+ * Some BSPs use the interrupt stack as the initialization stack which is used
+ * to perform the sequential system initialization before the multithreading is
+ * started.
+ * The interrupt stacks are covered by the stack checker, see
+ * #CONFIGURE_STACK_CHECKER_ENABLED.  However, using a too small interrupt
+ * stack size may still result in undefined behaviour.
+ * In releases before RTEMS 5.1 the default value was
+ * #CONFIGURE_MINIMUM_TASK_STACK_SIZE instead of ``CPU_STACK_MINIMUM_SIZE``.
+ * @endparblock
+#define CONFIGURE_INTERRUPT_STACK_SIZE
+ * In case this configuration option is defined, then each memory area returned
+ * by C Program Heap allocator functions such as ``malloc()`` is dirtied with a
+ * ``0xCF`` byte pattern before it is handed over to the application.
+ * enabled.
+ * @par Notes
+ * The dirtying performed by this option is carried out for each successful
+ * memory allocation from the C Program Heap in contrast to
+ * #CONFIGURE_DIRTY_MEMORY which dirties the memory only once during the system
+ * initialization.
+#define CONFIGURE_MALLOC_DIRTY
+ * The value of this configuration option defines the maximum number of file
+ * like objects that can be concurrently open.
+ * The default value is 3.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * The default value of three file descriptors allows RTEMS to support standard
+ * input, output, and error I/O streams on ``/dev/console``.
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
+ * processors an application intends to use.  The number of actually available
+ * processors depends on the hardware and may be less.  It is recommended to
+ * use the smallest value suitable for the application in order to save memory.
+ * Each processor needs an IDLE task stack and interrupt stack for example.
+ * The value of this configuration option shall be greater than or equal to 1
+ * and less than or equal to ``CPU_MAXIMUM_PROCESSORS``.
+ * @par Notes
+ * @parblock
+ * If there are more processors available than configured, the rest will be
+ * ignored.
+ * This configuration option is only evaluated in SMP configurations (e.g.
+ * RTEMS was built with the ``--enable-smp`` build configuration option).  In
+ * all other configurations it has no effect.
+ * @endparblock
+#define CONFIGURE_MAXIMUM_PROCESSORS
+ * The value of this configuration option defines the maximum thread name size
+ * including the terminating ``NUL`` character.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * The default value was chosen for Linux compatibility, see <a
+ * href=http://man7.org/linux/man-pages/man3/pthread_setname_np.3.html>PTHREAD_SETNAME_NP(3)</a>.
+ * The size of the thread control block is increased by the maximum thread name
+ * size.
+ * This configuration option is available since RTEMS 5.1.
+ * @endparblock
+#define CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
+ * The value of this configuration option defines the number of kilobytes the
+ * application wishes to add to the RTEMS Workspace size calculated by
+ * @parblock
+ * constraints:
+ *   application.
+ * * It shall be small enough so that the RTEMS Workspace size calculation
+ *   ``uintptr_t``.
+ * @endparblock
+ * @par Notes
+ * This configuration option should only be used when it is suspected that a
+ * bug in ``<rtems/confdefs.h>`` has resulted in an underestimation.  Typically
+ * the memory allocation will be too low when an application does not account
+ * for all message queue buffers or task stacks, see
+ * #CONFIGURE_MESSAGE_BUFFER_MEMORY.
+#define CONFIGURE_MEMORY_OVERHEAD
+ * The value of this configuration option defines the number of bytes reserved
+ * for message queue buffers in the RTEMS Workspace.
+ * @parblock
+ * constraints:
+ *   application.
+ *   ``uintptr_t``.
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * The configuration options #CONFIGURE_MAXIMUM_MESSAGE_QUEUES and
+ * #CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES define only how many message queues
+ * can be created by the application.  The memory for the message buffers is
+ * configured by this option.  For each message queue you have to reserve some
+ * memory for the message buffers.  The size dependes on the maximum number of
+ * pending messages and the maximum size of the messages of a message queue.
+ * Use the ``CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE()`` macro to specify the
+ * message buffer memory for each message queue and sum them up to define the
+ * value for ``CONFIGURE_MAXIMUM_MESSAGE_QUEUES``.
+ * The interface for the ``CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE()`` help macro
+ * is as follows:
+ * @code
+ * CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( max_messages, max_msg_size )
+ * @endcode
+ * Where ``max_messages`` is the maximum number of pending messages and
+ * ``max_msg_size`` is the maximum size in bytes of the messages of the
+ * corresponding message queue.  Both parameters shall be compile time
+ * constants.  Not using this help macro (e.g. just using ``max_messages *
+ * max_msg_size``) may result in an underestimate of the RTEMS Workspace size.
+ * The following example illustrates how the
+ * `CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE()` help macro can be used to assist in
+ * calculating the message buffer memory required.  In this example, there are
+ * two message queues used in this application.  The first message queue has a
+ * maximum of 24 pending messages with the message structure defined by the
+ * type ``one_message_type``.  The other message queue has a maximum of 500
+ * pending messages with the message structure defined by the type
+ * ``other_message_type``.
+ * @code
+ * #define CONFIGURE_MESSAGE_BUFFER_MEMORY ( \
+ *     CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( \
+ *       24, \
+ *       sizeof( one_message_type ) \
+ *     + CONFIGURE_MESSAGE_BUFFERS_FOR_QUEUE( \
+ *       500, \
+ *       sizeof( other_message_type ) \
+ * @endcode
+ * @endparblock
+#define CONFIGURE_MESSAGE_BUFFER_MEMORY
+ * The value of this configuration option defines the length of time in
+ * microseconds between clock ticks (clock tick quantum).
+ * When the clock tick quantum value is too low, the system will spend so much
+ * time processing clock ticks that it does not have processing time available
+ * to perform application work. In this case, the system will become
+ * unresponsive.
+ * The lowest practical time quantum varies widely based upon the speed of the
+ * target hardware and the architectural overhead associated with interrupts.
+ * In general terms, you do not want to configure it lower than is needed for
+ * The clock tick quantum should be selected such that it all blocking and
+ * delay times in the application are evenly divisible by it. Otherwise,
+ * rounding errors will be introduced which may negatively impact the
+ * application.
+ * The default value is 10000.
+ * @parblock
+ * constraints:
+ * * It shall be greater than or equal to a Clock Driver specific value.
+ * * It shall be less than or equal to a Clock Driver specific value.
+ * * The resulting clock ticks per second should be an integer.
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * This configuration option has no impact if the Clock Driver is not
+ * configured, see #CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER.
+ * There may be Clock Driver specific limits on the resolution or maximum value
+ * of a clock tick quantum.
+ * @endparblock
+#define CONFIGURE_MICROSECONDS_PER_TICK
+ * The value of this configuration option defines the minimum stack size in
+ * bytes for every user task or thread in the system.
+ * The default value is ``CPU_STACK_MINIMUM_SIZE``.
+ * @parblock
+ * constraints:
+ *   ``uintptr_t``.
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * Adjusting this parameter should be done with caution.  Examining the actual
+ * stack usage using the stack checker usage reporting facility is recommended
+ * (see also #CONFIGURE_STACK_CHECKER_ENABLED).
+ * This parameter can be used to lower the minimum from that recommended. This
+ * can be used in low memory systems to reduce memory consumption for stacks.
+ * However, this shall be done with caution as it could increase the
+ * possibility of a blown task stack.
+ * This parameter can be used to increase the minimum from that recommended.
+ * This can be used in higher memory systems to reduce the risk of stack
+ * overflow without performing analysis on actual consumption.
+ * By default, this configuration parameter defines also the minimum stack size
+ * of POSIX threads.  This can be changed with the
+ * #CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE configuration option.
+ * In releases before RTEMS 5.1 the ``CONFIGURE_MINIMUM_TASK_STACK_SIZE`` was
+ * used to define the default value of #CONFIGURE_INTERRUPT_STACK_SIZE.
+ * @endparblock
+#define CONFIGURE_MINIMUM_TASK_STACK_SIZE
+ * In case this configuration option is defined, then the stack checker is
+ * enabled.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * The stack checker performs run-time stack bounds checking.  This increases
+ * the time required to create tasks as well as adding overhead to each context
+ * switch.
+ * In 4.9 and older, this configuration option was named ``STACK_CHECKER_ON``.
+ * @endparblock
+#define CONFIGURE_STACK_CHECKER_ENABLED
+ * The value of this configuration option defines the length of the timeslice
+ * quantum in ticks for each task.
+ * The default value is 50.
+ * @par Notes
+#define CONFIGURE_TICKS_PER_TIMESLICE
+ * In case this configuration option is defined, then the RTEMS Workspace and
+ * the C Program Heap will be one pool of memory.
+ * If this configuration option is undefined, then there will be separate
+ * memory pools for the RTEMS Workspace and C Program Heap.
+ * @par Notes
+ * @parblock
+ * Having separate pools does have some advantages in the event a task blows a
+ * stack or writes outside its memory area. However, in low memory systems the
+ * overhead of the two pools plus the potential for unused memory in either
+ * pool is very undesirable.
+ * In high memory environments, this is desirable when you want to use the <a
+ * Objects</a> option.  You will be able to create objects until you run out of
+ * all available memory rather then just until you run out of RTEMS Workspace.
+ * @endparblock
+#define CONFIGURE_UNIFIED_WORK_AREAS
+ * If #CONFIGURE_UNLIMITED_OBJECTS is defined, then the value of this
+ * configuration option defines the default objects maximum of all object
+ * classes supporting <a
+ * Objects</a> to ``rtems_resource_unlimited(
+ * CONFIGURE_UNLIMITED_ALLOCATION_SIZE )``.
+ * The default value is 8.
+ * The value of this configuration option shall meet the constraints of all
+ * object classes to which it is applied.
+ * @par Notes
+ * @parblock
+ * By allowing users to declare all resources as being unlimited the user can
+ * avoid identifying and limiting the resources used.
+ * The object maximum of each class can be configured also individually using
+ * the rtems_resource_unlimited() macro.
+ * @endparblock
+#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE
+ * In case this configuration option is defined, then unlimited objects are
+ * used by default.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * When using unlimited objects, it is common practice to also specify
+ * #CONFIGURE_UNIFIED_WORK_AREAS so the system operates with a single pool of
+ * memory for both RTEMS Workspace and C Program Heap.
+ * This option does not override an explicit configuration for a particular
+ * object class by the user.
+ * See also #CONFIGURE_UNLIMITED_ALLOCATION_SIZE.
+ * @endparblock
+#define CONFIGURE_UNLIMITED_OBJECTS
+ * In case this configuration option is defined, then the system initialization
+ * is verbose.
+ * enabled.
+ * @par Notes
+ * You may use this feature to debug system initialization issues.  The
+ * ``printk()`` function is used to print the information.
+#define CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION
+ * the RTEMS Workspace and the C Program Heap are zeroed with a ``0x00`` byte
+ * enabled.
+ * @par Notes
+ * Zeroing memory can add significantly to the system initialization time. It
+ * is not necessary for RTEMS but is often assumed by support libraries.  In
+ * case #CONFIGURE_DIRTY_MEMORY is also defined, then the memory is first
+ * dirtied and then zeroed.
+#define CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
+ * @defgroup RTEMSApplConfigIdleTaskConfiguration Idle Task Configuration
+ * This section describes configuration options related to the idle tasks.
+ * The value of this configuration option initializes the IDLE thread body.
+ * If #BSP_IDLE_TASK_BODY is defined, then this will be the default value,
+ * otherwise the default value is ``_CPU_Thread_Idle_body``.
+ * @par Notes
+ * @parblock
+ * IDLE threads shall not block.  A blocking IDLE thread results in undefined
+ * system behaviour because the scheduler assume that at least one ready thread
+ * exists.
+ * IDLE threads can be used to initialize the application, see configuration
+ * option #CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION.
+ * @endparblock
+#define CONFIGURE_IDLE_TASK_BODY
+ * This configuration option is defined to indicate that the user has
+ * configured **no** user initialization tasks or threads and that the user
+ * provided IDLE task will perform application initialization and then
+ * transform itself into an IDLE task.
+ * If this configuration option is undefined, then the user is assumed to
+ * provide one or more initialization tasks.
+ * @par Notes
+ * @parblock
+ * If you use this option be careful, the user IDLE task **cannot** block at
+ * all during the initialization sequence.  Further, once application
+ * initialization is complete, it shall make itself preemptible and enter an
+ * idle body loop.
+ * The IDLE task shall run at the lowest priority of all tasks in the system.
+ * If this configuration option is defined, then it is mandatory to configure a
+ * user IDLE task with the #CONFIGURE_IDLE_TASK_BODY configuration option,
+ * options
+ * * #CONFIGURE_RTEMS_INIT_TASKS_TABLE,
+ * * `CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION`
+ * @endparblock
+#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
+ * The value of this configuration option defines the task stack size for an
+ * IDLE task.
+ * @parblock
+ * constraints:
+ *   ``size_t``.
+ * @endparblock
+ * @par Notes
+ * In SMP configurations, there is one IDLE task per configured processor, see
+ * #CONFIGURE_MAXIMUM_PROCESSORS.
+#define CONFIGURE_IDLE_TASK_STACK_SIZE
+ * @defgroup RTEMSApplConfigMultiprocessingConfiguration Multiprocessing Configuration
+ * This section describes multiprocessing related configuration options.  The
+ * options are only used if RTEMS was built with the
+ * ``--enable-multiprocessing`` build configuration option.  Additionally, this
+ * class of configuration options are only applicable if the configuration
+ * option #CONFIGURE_MP_APPLICATION is defined.  The multiprocessing (MPCI)
+ * support must not be confused with the SMP support.
+ * applications wishes to add to the MPCI task stack on top of
+ * #CONFIGURE_MINIMUM_TASK_STACK_SIZE.
+ * @parblock
+ * constraints:
+ * * It shall be less than or equal to ``UINT32_MAX``.
+ * * It shall be small enough so that the MPCI receive server stack area
+ *   calculation carried out by ``<rtems/confdefs.h>`` does not overflow an
+ *   integer of type ``size_t``.
+ * @endparblock
+ * @par Notes
+ * This configuration option is only evaluated if #CONFIGURE_MP_APPLICATION is
+ * defined.
+#define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
+ * This configuration option is defined to indicate that the application
+ * intends to be part of a multiprocessing configuration.  Additional
+ * configuration options are assumed to be provided.
+ * If this configuration option is undefined, then the multiprocessing services
+ * are not initialized.
+ * @par Notes
+ * This configuration option shall be undefined if the multiprocessing support
+ * is not enabled (e.g. RTEMS was built without the
+ * ``--enable-multiprocessing`` build configuration option).  Otherwise a
+ * compile time error in the configuration file will occur.
+#define CONFIGURE_MP_APPLICATION
+ * concurrently active global objects in a multiprocessor system.
+ * The default value is 32.
+ * @par Notes
+ * @parblock
+ * This value corresponds to the total number of objects which can be created
+ * with the ``RTEMS_GLOBAL`` attribute.
+ * defined.
+ * @endparblock
+#define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
+ * The value of this configuration option defines the maximum number of nodes
+ * in a multiprocessor system.
+ * The default value is 2.
+ * @par Notes
+ * defined.
+#define CONFIGURE_MP_MAXIMUM_NODES
+ * concurrently active thread/task proxies on this node in a multiprocessor
+ * system.
+ * @par Notes
+ * @parblock
+ * Since a proxy is used to represent a remote task/thread which is blocking on
+ * this node. This configuration parameter reflects the maximum number of
+ * remote tasks/threads which can be blocked on objects on this node, see <a
+ * href=https://docs.rtems.org/branches/master/c-user/multiprocessing.html#proxies>Proxies</a>.
+ * defined.
+ * @endparblock
+#define CONFIGURE_MP_MAXIMUM_PROXIES
+ * The value of this configuration option initializes the MPCI Configuration
+ * Table.
+ * The default value is ``&MPCI_table``.
+ * The value of this configuration option shall be a pointer to
+ * ::rtems_mpci_table.
+ * @par Notes
+ * @parblock
+ * RTEMS provides a Shared Memory MPCI Device Driver which can be used on any
+ * Multiprocessor System assuming the BSP provides the proper set of supporting
+ * methods.
+ * defined.
+ * @endparblock
+#define CONFIGURE_MP_MPCI_TABLE_POINTER
+ * The value of this configuration option defines the node number of this node
+ * The default value is ``NODE_NUMBER``.
+ * @par Notes
+ * @parblock
+ * In the RTEMS Multiprocessing Test Suite, the node number is derived from the
+ * Makefile variable ``NODE_NUMBER``. The same code is compiled with the
+ * ``NODE_NUMBER`` set to different values. The test programs behave
+ * differently based upon their node number.
+ * defined.
+ * @endparblock
+#define CONFIGURE_MP_NODE_NUMBER
+ * @defgroup RTEMSApplConfigPOSIXAPIConfiguration POSIX API Configuration
+ * This section describes configuration options related to the POSIX API.  Most
+ * POSIX API objects are available by default since RTEMS 5.1.  The queued
+ * signals and timers are only available if RTEMS was built with the
+ * ``--enable-posix`` build configuration option.
+ * The value of this configuration option defines the maximum number of POSIX
+ * API Keys that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * Objects</a>.
+#define CONFIGURE_MAXIMUM_POSIX_KEYS
+ * The value of this configuration option defines the maximum number of key
+ * value pairs used by POSIX API Keys that can be concurrently active.
+ * The default value is #CONFIGURE_MAXIMUM_POSIX_KEYS *
+ * #CONFIGURE_MAXIMUM_TASKS + #CONFIGURE_MAXIMUM_POSIX_THREADS.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * Objects</a>.
+ * A key value pair is created by ``pthread_setspecific()`` if the value is not
+ * NULL, otherwise it is deleted.
+ * @endparblock
+#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
+ * @parblock
+ * constraints:
+ *   application.
+ *   ``uintptr_t``.
+ * @endparblock
+ * @par Notes
+#define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
+ * API Queued Signals that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ *   ``uintptr_t``.
+ * * It shall be zero if the POSIX API is not enabled (e.g. RTEMS was built
+ *   without the ``--enable-posix`` build configuration option).  Otherwise a
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * Unlimited objects are not available for queued signals.
+ * Queued signals are only available if RTEMS was built with the
+ * @endparblock
+#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
+ * API Named Semaphores that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ *   ``uintptr_t``.
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * Objects</a>.
+ * Named semaphores are created with ``sem_open()``.  Semaphores initialized
+ * with ``sem_init()`` are not affected by this configuration option since the
+ * storage space for these semaphores is user-provided.
+ * @endparblock
+#define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
+ * API Shared Memory objects that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ *   ``uintptr_t``.
+ * @endparblock
+ * @par Notes
+ * Objects</a>.
+#define CONFIGURE_MAXIMUM_POSIX_SHMS
+ * API Threads that can be concurrently active.
+ * @parblock
+ * constraints:
+ *   application.
+ *   ``uintptr_t``.
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * Objects</a>.
+ * This calculations for the required memory in the RTEMS Workspace for threads
+ * assume that each thread has a minimum stack size and has floating point
+ * used to specify thread stack requirements **above** the minimum size
+ * required.
+ * The maximum number of Classic API Tasks is specified by
+ * #CONFIGURE_MAXIMUM_TASKS.
+ * All POSIX threads have floating point enabled.
+ * @endparblock
+#define CONFIGURE_MAXIMUM_POSIX_THREADS
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * Objects</a>.
+ * Timers are only available if RTEMS was built with the ``--enable-posix``
+ * build configuration option.
+ * @endparblock
+#define CONFIGURE_MAXIMUM_POSIX_TIMERS
+ * bytes for every POSIX thread in the system.
+ * The default value is two times the value of
+ * @parblock
+ * constraints:
+ *   ``uintptr_t``.
+ * @endparblock
+#define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
+ * @defgroup RTEMSApplConfigPOSIXInitializationThreadConfiguration POSIX Initialization Thread Configuration
+ * initialization thread.
+ * POSIX API initialization thread.
+ * The default value is ``POSIX_Init``.
+ * pointer of the type ``void *( *entry_point )( void * )``.
+ * @par Notes
+ * option.
+#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
+ * The value of this configuration option defines the thread stack size of the
+ * The default value is #CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE.
+ * @parblock
+ * constraints:
+ *   ``uintptr_t``.
+ * @endparblock
+#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
+ * In case this configuration option is defined, then exactly one POSIX
+ * initialization thread is configured.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * options
+ * * `CONFIGURE_POSIX_INIT_THREAD_TABLE`, or
+ * @endparblock
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+ * @defgroup RTEMSApplConfigGeneralSchedulerConfiguration General Scheduler Configuration
+ * This section describes configuration options related to selecting a
+ * scheduling algorithm for an application.  A scheduler configuration is
+ * optional and only necessary in very specific circumstances.  A normal
+ * application configuration does not need any of the configuration options
+ * described in this section.
+ * By default, the <a
+ * href=https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#deterministic-priority-scheduler>Deterministic
+ * Priority Scheduler</a> algorithm is used in uniprocessor configurations.  In
+ * case SMP is enabled and the configured maximum processors
+ * (#CONFIGURE_MAXIMUM_PROCESSORS) is greater than one, then the <a
+ * href=https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#earliest-deadline-first-smp-scheduler>Earliest
+ * Deadline First SMP Scheduler</a> is selected as the default scheduler
+ * algorithm.
+ * For the schedulers provided by RTEMS (see <a
+ * href=https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html>Scheduling
+ * Concepts</a>), the configuration is straightforward.  All that is required
+ * is to define the configuration option which specifies which scheduler you
+ * want for in your application.
+ * The pluggable scheduler interface also enables the user to provide their own
+ * scheduling algorithm.  If you choose to do this, you must define multiple
+ * The value of this configuration option defines the maximum number Constant
+ * Bandwidth Servers that can be concurrently active.
+ * The default value is #CONFIGURE_MAXIMUM_TASKS.
+ * @parblock
+ * constraints:
+ *   application.
+ * @endparblock
+ * @par Notes
+ * #CONFIGURE_SCHEDULER_CBS is defined.
+#define CONFIGURE_CBS_MAXIMUM_SERVERS
+ * @brief This configuration option is an integer define.
+ * For the following schedulers
+ * * <a
+ *   Priority Scheduler</a>, which is the default in uniprocessor
+ *   configurations and can be configured through the
+ *   #CONFIGURE_SCHEDULER_PRIORITY configuration option,
+ * * <a
+ *   href=https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#deterministic-priority-smp-scheduler>Deterministic
+ *   Priority SMP Scheduler</a> which can be configured through the
+ *   #CONFIGURE_SCHEDULER_PRIORITY_SMP configuration option, and
+ * * <a
+ *   href=https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#arbitrary-processor-affinity-priority-smp-scheduler>Arbitrary
+ *   Processor Affinity Priority SMP Scheduler</a> which can be configured
+ *   through the #CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP configuration
+ *   option
+ * this configuration option specifies the maximum numeric priority of any task
+ * for these schedulers and one less that the number of priority levels for
+ * these schedulers.  For all other schedulers provided by RTEMS, this
+ * configuration option has no effect.
+ * @par Default Value
+ * The default value is 255.
+ * @par Value Constraints
+ * The value of this configuration option shall be an element of {3, 7, 31, 63,
+ * 127, 255}.
+ * @par Notes
+ * @parblock
+ * The numerically greatest priority is the logically lowest priority in the
+ * system and will thus be used by the IDLE task.
+ * Priority zero is reserved for internal use by RTEMS and is not available to
+ * applications.
+ * Reducing the number of priorities through this configuration option reduces
+ * the amount of memory allocated by the schedulers listed above.  These
+ * schedulers use a chain control structure per priority and this structure
+ * consists of three pointers.  On a 32-bit architecture, the allocated memory
+ * is 12 bytes * (``CONFIGURE_MAXIMUM_PRIORITY`` + 1), e.g. 3072 bytes for 256
+ * priority levels (default), 48 bytes for 4 priority levels
+ * (``CONFIGURE_MAXIMUM_PRIORITY == 3``).
+ * The default value is 255, because RTEMS shall support 256 priority levels to
+ * be compliant with various standards.  These priorities range from 0 to 255.
+ * @endparblock
+#define CONFIGURE_MAXIMUM_PRIORITY
+ * The value of this configuration option is used to initialize the initial
+ * scheduler to processor assignments.
+ * The default value of this configuration option is computed so that the
+ * default scheduler is assigned to each configured processor (up to 32).
+ * @parblock
+ * The value of this configuration option shall satisfy all of the following
+ * constraints:
+ * * It shall be a list of the following macros:
+ *   * ``RTEMS_SCHEDULER_ASSIGN( processor_index, attributes )``
+ *   * ``RTEMS_SCHEDULER_ASSIGN_NO_SCHEDULER``
+ * * It shall be a list of exactly #CONFIGURE_MAXIMUM_PROCESSORS elements.
+ * @endparblock
+ * @par Notes
+ * @parblock
+ * This configuration option is only evaluated in SMP configurations.
+ * This is an advanced configuration option, see <a
+ * href=https://docs.rtems.org/branches/master/c-user/config/scheduler-clustered.html>Clustered
+ * Scheduler Configuration</a>.
+ * @endparblock
+#define CONFIGURE_SCHEDULER_ASSIGNMENTS
+ * @brief This configuration option is a boolean feature define.
+ * In case this configuration option is defined, then <a
+ * href=https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#constant-bandwidth-server-scheduling-cbs>Constant
+ * Bandwidth Server Scheduling (CBS)</a> algorithm is made available to the
+ * application.
+ * @par Default Configuration
+ * If this configuration option is undefined, then the described feature is not
+ * enabled.
+ * @par Notes
+ * @parblock
+ * This scheduler configuration option is an advanced configuration option.
+ * Think twice before you use it.
+ * In case no explicit <a
+ * Scheduler Configuration</a> is present, then it is used as the scheduler for
+ * exactly one processor.
+ * @endparblock
+#define CONFIGURE_SCHEDULER_CBS
+ * href=https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#earliest-deadline-first-scheduler>Earliest
+ * Deadline First Scheduler</a> algorithm is made available to the application.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * @endparblock
+#define CONFIGURE_SCHEDULER_EDF
+ * Deadline First SMP Scheduler</a> algorithm is made available to the
+ * application.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * This scheduler algorithm is only available when RTEMS is built with SMP
+ * up to 32 processors.
+ * This scheduler algorithm is the default in SMP configurations if
+ * #CONFIGURE_MAXIMUM_PROCESSORS is greater than one.
+ * @endparblock
+#define CONFIGURE_SCHEDULER_EDF_SMP
+ * The value of this configuration option defines the name of the default
+ * scheduler.
+ * @parblock
+ * * ``"MEDF"`` for the <a
+ *   Deadline First SMP Scheduler</a>,
+ * * ``"MPA "`` for the <a
+ *   Processor Affinity Priority SMP Scheduler</a>,
+ * * ``"MPD "`` for the <a
+ *   Priority SMP Scheduler</a>,
+ * * ``"MPS "`` for the <a
+ *   href=https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#simple-priority-smp-scheduler>Simple
+ * * ``"UCBS"`` for the <a
+ *   Bandwidth Server Scheduling (CBS)</a>,
+ * * ``"UEDF"`` for the <a
+ *   Deadline First Scheduler</a>,
+ * * ``"UPD "`` for the <a
+ *   Priority Scheduler</a>, and
+ * * ``"UPS "`` for the <a
+ *   href=https://docs.rtems.org/branches/master/c-user/scheduling_concepts.html#simple-priority-scheduler>Simple
+ *   Priority Scheduler</a>.
+ * @endparblock
+ * ``rtems_name``.
+ * @par Notes
+ * @parblock
+ * Schedulers can be identified via rtems_scheduler_ident().
+ * Use rtems_build_name() to define the scheduler name.
+ * @endparblock
+#define CONFIGURE_SCHEDULER_NAME
+ * Priority Scheduler</a> algorithm is made available to the application.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * This scheduler algorithm is the default when #CONFIGURE_MAXIMUM_PROCESSORS
+ * is exactly one.
+ * The memory allocated for this scheduler depends on the
+ * #CONFIGURE_MAXIMUM_PRIORITY configuration option.
+ * @endparblock
+#define CONFIGURE_SCHEDULER_PRIORITY
+ * Processor Affinity Priority SMP Scheduler</a> algorithm is made available to
+ * enabled.
+ * @par Notes
+ * @parblock
+ * @endparblock
+#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
+ * Priority SMP Scheduler</a> algorithm is made available to the application.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * @endparblock
+#define CONFIGURE_SCHEDULER_PRIORITY_SMP
+ * enabled.
+ * @par Notes
+ * @parblock
+ * @endparblock
+#define CONFIGURE_SCHEDULER_SIMPLE
+ * application.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * @endparblock
+#define CONFIGURE_SCHEDULER_SIMPLE_SMP
+ * In case this configuration option is defined, then Strong APA algorithm is
+ * made available to the application.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * This scheduler algorithm is not correctly implemented.  Do not use it.
+ * @endparblock
+#define CONFIGURE_SCHEDULER_STRONG_APA
+ * In case this configuration option is defined, then the user shall provide a
+ * scheduler algorithm to the application.
+ * enabled.
+ * @par Notes
+ * @parblock
+ * RTEMS allows the application to provide its own task/thread scheduling
+ * algorithm. In order to do this, one shall define
+ * ``CONFIGURE_SCHEDULER_USER`` to indicate the application provides its own
+ * scheduling algorithm. If ``CONFIGURE_SCHEDULER_USER`` is defined then the
+ * following additional macros shall be defined:
+ * * ``CONFIGURE_SCHEDULER`` shall be defined to a static definition of the
+ *   scheduler data structures of the user scheduler.
+ * * ``CONFIGURE_SCHEDULER_TABLE_ENTRIES`` shall be defined to a scheduler
+ *   table entry initializer for the user scheduler.
+ * * ``CONFIGURE_SCHEDULER_USER_PER_THREAD`` shall be defined to the type of
+ *   the per-thread information of the user scheduler.
+ * At this time, the mechanics and requirements for writing a new scheduler are
+ * evolving and not fully documented.  It is recommended that you look at the
+ * existing Deterministic Priority Scheduler in
+ * ``cpukit/score/src/schedulerpriority*.c`` for guidance.  For guidance on the
+ * configuration macros, please examine ``cpukit/sapi/include/confdefs.h`` for
+ * how these are defined for the Deterministic Priority Scheduler.
+ * @endparblock
+#define CONFIGURE_SCHEDULER_USER
+ * @defgroup RTEMSApplConfigTaskStackAllocatorConfiguration Task Stack Allocator Configuration
+ * @ingroup RTEMSApplConfig
+ * This section describes configuration options related to the task stack
+ * allocator.  RTEMS allows the application or BSP to define its own allocation
+ * and deallocation methods for task stacks. This can be used to place task
+ * stacks in special areas of memory or to utilize a Memory Management Unit so
+ * that stack overflows are detected in hardware.
+ * @brief This configuration option is an initializer define.
+ * The value of this configuration option initializes the stack allocator
+ * allocate handler.
+ * The default value is ``_Workspace_Allocate``, which indicates that task
+ * stacks will be allocated from the RTEMS Workspace.
+ * The value of this configuration option shall be defined to a valid function
+ * pointer of the type ``void *( *allocate )( size_t )``.
+ * @par Notes
+ * @parblock
+ * A correctly configured system shall configure the following to be
+ * consistent:
+ * * #CONFIGURE_TASK_STACK_ALLOCATOR_INIT
+ * * `CONFIGURE_TASK_STACK_ALLOCATOR`
+ * * #CONFIGURE_TASK_STACK_DEALLOCATOR
+ * @endparblock
+#define CONFIGURE_TASK_STACK_ALLOCATOR
+ * In case this configuration option is defined, then the system is informed
+ * that the task stack allocator does not use the RTEMS Workspace.
+ * enabled.
+ * @par Notes
+ * This configuration option may be used if a custom task stack allocator is
+ * configured, see #CONFIGURE_TASK_STACK_ALLOCATOR.
+#define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
+ * initialization handler.
+ * The default value is ``NULL``.
+ * pointer of the type ``void ( *initialize )( size_t )`` or to ``NULL``.
+ * @par Notes
+ * @parblock
+ * consistent:
+ * * `CONFIGURE_TASK_STACK_ALLOCATOR_INIT`
+ * @endparblock
+#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT
+ * deallocate handler.
+ * The default value is ``_Workspace_Free``, which indicates that task stacks
+ * will be allocated from the RTEMS Workspace.
+ * pointer of the type ``void ( *deallocate )( void * )``.
+ * @par Notes
+ * @parblock
+ * consistent:
+ * * `CONFIGURE_TASK_STACK_DEALLOCATOR`
+ * @endparblock
+#define CONFIGURE_TASK_STACK_DEALLOCATOR
+ * The value of this configuration option is used to calculate the task stack
+ * space size.
+ * The default value is a macro which supports the system heap allocator.
+ * The value of this configuration option shall be defined to a macro which
+ * accepts exactly one parameter and returns an unsigned integer.  The
+ * parameter will be an allocation size and the macro shall return this size
+ * plus the overhead of the allocator to manage an allocation request for this
+ * size.
+ * @par Notes
+#define CONFIGURE_TASK_STACK_FROM_ALLOCATOR
2.26.2
