[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Tue Jul 7 19:42:14 UTC 2020
________________________________
Sent: Wednesday, July 8, 2020 1:05 AM
To: Mritunjay Sharma
Cc: Gedare Bloom; Joel Sherrill; Chris Johns; RTEMS Devel
Subject: Re: [GSoC 2020: Daily Update]: Building EPICS with RTEMS5
I’m away from my keyboard. If you use the epics Adaption to rtems from my github “playground?” and bsp’s with —enable-networks should compile.
Heinz
FHI, Heinz Junkes
Thank you Heinz, I was doing the same. I went to your GitHub and am experimenting with "playground" right now.
Thanks,
Mritunjay
On 7. Jul 2020, at 18:14, Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
[UPDATE]: I tried building EPICS with RTEMS5 for pc-386 and pc-386-qemu.
Everything worked fine while building the pc-386 with RTEMS5.
After this when I entered epics-base and made the following change:
epics-base/os/CONFIG_SITE.Common.RTEMS
RTEMS_VERSION = 5
RTEMS_BASE = /home/mritunjay/development/rtems_dev/$(RTEMS_VERSION)
As an experiment, I ran the make and as expected got the following error
Error:
```...de/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include -c ../rtems_init.c
../rtems_init.c:21:10: fatal error: sys/termios.h: No such file or directory
#include <sys/termios.h>
compilation terminated.
../../../../configure/RULES_BUILD:240: recipe for target 'rtems_init.o' failed
make[4]: *** [rtems_init.o] Error 1
make[4]: Leaving directory '/home/mritunjay/development/EPICS/epics-base/modules/libcom/RTEMS/O.RTEMS-pc386'
../../../configure/RULES_ARCHS:58: recipe for target 'install.RTEMS-pc386' failed
make[3]: *** [install.RTEMS-pc386] Error 2
make[3]: Leaving directory '/home/mritunjay/development/EPICS/epics-base/modules/libcom/RTEMS'
../../configure/RULES_DIRS:85: recipe for target 'RTEMS.install' failed
make[2]: *** [RTEMS.install] Error 2
make[2]: Leaving directory '/home/mritunjay/development/EPICS/epics-base/modules/libcom'
../configure/RULES_DIRS:85: recipe for target 'libcom.install' failed
make[1]: *** [libcom.install] Error 2
make[1]: Leaving directory '/home/mritunjay/development/EPICS/epics-base/modules'
configure/RULES_DIRS:85: recipe for target 'modules.install' failed
make: *** [modules.install] Error 2
I am trying to figure out the error and making the changes in code to debug it.
However, I will appreciate if Heinz and everyone else can help me a little, if they have an
idea of this error.
Thanks
Mritunjay
On Tue, Jul 7, 2020 at 7:30 PM Mritunjay Sharma <mritunjaysharma394 at gmail.com<mailto:mritunjaysharma394 at gmail.com>> wrote:
On Tue, Jul 7, 2020 at 5:33 AM Gedare Bloom <gedare at rtems.org<mailto:gedare at rtems.org>> wrote:
On Mon, Jul 6, 2020 at 5:49 PM Joel Sherrill <joel at rtems.org<mailto:joel at rtems.org>> wrote:
> On Mon, Jul 6, 2020, 6:14 PM Gedare Bloom <gedare at rtems.org<mailto:gedare at rtems.org>> wrote:
>> On Mon, Jul 6, 2020 at 10:12 AM Mritunjay Sharma
>> > Hello everyone,
>> > Thank you, Heinz, Gedare, Chris and Joel for your advice.
>> > If there are issues in making a buildset for 4.10
>> > then should I build EPICS with RTEMS 5 by hand first and note
>> > down the process and then proceed to make the buildset for it?
>> Yes.
> +1
> And by 5, we definitely mean the 5 branch for all rtems repo and the similarly named one for libbsd.
Excellent point. We want to add support for easy build (and eventually
test) of EPICS+RTEMS starting with 5.1 and moving forward, which means
also doing it for RTEMS 6, Mritunjay.
Sounds good, I have begun building it hand by today for RTEMS 5 branch and later on continue the
same for RTEMS6
Thank you so much Gedare and Joel.
Mritunjay
>> > Please suggest for the future steps.
>> > Thanks
>> > Mritunjay
>> > On Mon, Jul 6, 2020 at 5:38 AM Joel Sherrill <joel at rtems.org<mailto:joel at rtems.org>> wrote:
>> >> On Sun, Jul 5, 2020, 6:12 PM Chris Johns <chrisj at rtems.org<mailto:chrisj at rtems.org>> wrote:
>> >>> On 6/7/20 12:47 am, Heinz Junkes wrote:
>> >>> > Thank you, this is exactly where I was unsure.
>> >>> > @Chris: Can you give a recommendation here?
>> >>> > Danke Heinz
>> >>> > Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
>> >>> > Heinz Junkes | Fax (G3+G4): (+49 30) 8413-5900
>> >>> > Faradayweg 4-6 | VC: 102220181216 at bjn.vc<mailto:102220181216 at bjn.vc>
>> >>> > D - 14195 Berlin | E-Mail: junkes at fhi-berlin.mpg.de<mailto:junkes at fhi-berlin.mpg.de>
>> >>> >> On 5. Jul 2020, at 16:20, Gedare Bloom <gedare at rtems.org<mailto:gedare at rtems.org>> wrote:
>> >>> >> On Sat, Jul 4, 2020 at 1:18 PM Mritunjay Sharma
>> >>> >>> On Sun, Jul 5, 2020 at 12:28 AM Heinz Junkes <junkes at fhi-berlin.mpg.de<mailto:junkes at fhi-berlin.mpg.de>> wrote:
>> >>> >>>> Hello, Mritunjay,
>> >>> >>>> that's good news. Don't you want to try to develop a rsb-set for exactly this combination of RTEMS4.10 and EPICS7?
>> >>> >>> Sure, I am ready to do this and then do it with RTEMS5 in the same way. Please tell how to begin or some existing similar
>> >>> >>> work that can guide me how to proceed further in relation to rsb-set for RTEMS4.10 and EPICS7.
>> >>> >> I don't know if this is best. RSB didn't exist in 4.10. I haven't
>> >>> >> looked to see how well the rtems-source-builder/4.10 would support a
>> >>> >> package build. It should be discussed with Chris probably. A couple of
>> >>> >> packages were added in the 4.11 branch.
>> >>> I would leave 4.10 and move on. It may work but these things can expose issues
>> >>> that turn into distractions.
>> >>> Would making a script that does the build so we can document the steps be worth
>> >>> while
>> >> Yes. Emphatically yes. We need to make sure we know how it is best built by hand to automate it.
>> >> I firmly believe you should not attempt to automate something until doing it manually is well understood and documented.
>> >> After you have this down for one BSP, we need to ask questions like:
>> >> + Is there any per BSP tailoring beyond the obviod architecture and compilation settings?
>> >> + Any tweaks to settings users may want?
>> >> The manual process should include testing. The RSB is a great way to automate and ease building but it doesn't address testing the packages yet.
>> >> --joel
>> >>> Chris
>> >>> _______________________________________________
>> >>> devel mailing list
>> >>> devel at rtems.org<mailto:devel at rtems.org>
>> >>> http://lists.rtems.org/mailman/listinfo/devel
>> >> devel mailing list
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200707/e80b3091/attachment-0001.html>
