[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Wed Jul 8 18:33:02 UTC 2020
[UPDATE]: I tried to build the EPICS 7 with RTEMS 5 for pc386 with Heinz's
https://github.com/hjunkes/epicsBaseOwnPlayground
while switching to Branch "7". The previous errors are gone but I am facing
the following error:
"../posix/rtems_init.c:38:10: fatal error: rtems/bsd/bsd.h: No such file or
directory
#include <rtems/bsd/bsd.h>
compilation terminated.
/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/configure/RULES_BUILD:234:
recipe for target 'rtems_init.o' failed
make[4]: *** [rtems_init.o] Error 1
make[4]: Leaving directory
'/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/modules/libcom/RTEMS/O.RTEMS-pc386'
/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/configure/RULES_ARCHS:58:
recipe for target 'install.RTEMS-pc386' failed
make[3]: *** [install.RTEMS-pc386] Error 2
make[3]: Leaving directory
'/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/modules/libcom/RTEMS'
/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/configure/RULES_DIRS:84:
recipe for target 'RTEMS.install' failed
make[2]: *** [RTEMS.install] Error 2
make[2]: Leaving directory
'/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/modules/libcom'
../configure/RULES_DIRS:84: recipe for target 'libcom.install' failed
make[1]: *** [libcom.install] Error 2
make[1]: Leaving directory
'/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/modules'
configure/RULES_DIRS:84: recipe for target 'modules.install' failed
make: *** [modules.install] Error 2"
Today's update is that I tried to fix the above error however I still have
not been able to clear it.
If anyone has idea, please do tell what can be done.
Thanks
Mritunjay
On Wed, Jul 8, 2020 at 1:12 AM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> *From:* Heinz Junkes <junkes at fhi-berlin.mpg.de>
> *Sent:* Wednesday, July 8, 2020 1:05 AM
> *To:* Mritunjay Sharma
> *Cc:* Gedare Bloom; Joel Sherrill; Chris Johns; RTEMS Devel
> *Subject:* Re: [GSoC 2020: Daily Update]: Building EPICS with RTEMS5
> I’m away from my keyboard. If you use the epics Adaption to rtems from my
> github “playground?” and bsp’s with —enable-networks should compile.
> Heinz
> FHI, Heinz Junkes
> Thank you Heinz, I was doing the same. I went to your GitHub and am
> experimenting with "playground" right now.
> Thanks,
> Mritunjay
> On 7. Jul 2020, at 18:14, Mritunjay Sharma <mritunjaysharma394 at gmail.com>
> wrote:
> [UPDATE]: I tried building EPICS with RTEMS5 for pc-386 and pc-386-qemu.
> Everything worked fine while building the pc-386 with RTEMS5.
> After this when I entered epics-base and made the following change:
> epics-base/os/CONFIG_SITE.Common.RTEMS
> RTEMS_VERSION = 5
> RTEMS_BASE = /home/mritunjay/development/rtems_dev/$(RTEMS_VERSION)
> As an experiment, I ran the make and as expected got the following error
> Error:
> ```...de/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include
> -c ../rtems_init.c
> ../rtems_init.c:21:10: fatal error: sys/termios.h: No such file or
> directory
> #include <sys/termios.h>
> ../../../../configure/RULES_BUILD:240: recipe for target 'rtems_init.o'
> failed
> '/home/mritunjay/development/EPICS/epics-base/modules/libcom/RTEMS/O.RTEMS-pc386'
> ../../../configure/RULES_ARCHS:58: recipe for target 'install.RTEMS-pc386'
> failed
> '/home/mritunjay/development/EPICS/epics-base/modules/libcom/RTEMS'
> ../../configure/RULES_DIRS:85: recipe for target 'RTEMS.install' failed
> '/home/mritunjay/development/EPICS/epics-base/modules/libcom'
> ../configure/RULES_DIRS:85: recipe for target 'libcom.install' failed
> '/home/mritunjay/development/EPICS/epics-base/modules'
> configure/RULES_DIRS:85: recipe for target 'modules.install' failed
> I am trying to figure out the error and making the changes in code to
> debug it.
> However, I will appreciate if Heinz and everyone else can help me a
> little, if they have an
> idea of this error.
> Thanks
> Mritunjay
> On Tue, Jul 7, 2020 at 7:30 PM Mritunjay Sharma <
>> On Tue, Jul 7, 2020 at 5:33 AM Gedare Bloom <gedare at rtems.org> wrote:
>>> On Mon, Jul 6, 2020 at 5:49 PM Joel Sherrill <joel at rtems.org> wrote:
>>> > On Mon, Jul 6, 2020, 6:14 PM Gedare Bloom <gedare at rtems.org> wrote:
>>> >> On Mon, Jul 6, 2020 at 10:12 AM Mritunjay Sharma
>>> >> <mritunjaysharma394 at gmail.com> wrote:
>>> >> > Hello everyone,
>>> >> > Thank you, Heinz, Gedare, Chris and Joel for your advice.
>>> >> > If there are issues in making a buildset for 4.10
>>> >> > then should I build EPICS with RTEMS 5 by hand first and note
>>> >> > down the process and then proceed to make the buildset for it?
>>> >> Yes.
>>> > +1
>>> > And by 5, we definitely mean the 5 branch for all rtems repo and the
>>> similarly named one for libbsd.
>>> Excellent point. We want to add support for easy build (and eventually
>>> test) of EPICS+RTEMS starting with 5.1 and moving forward, which means
>>> also doing it for RTEMS 6, Mritunjay.
>>> Sounds good, I have begun building it hand by today for RTEMS 5 branch
>> and later on continue the
>> same for RTEMS6
>> Thank you so much Gedare and Joel.
>> Mritunjay
>>> >> > Please suggest for the future steps.
>>> >> > Thanks
>>> >> > Mritunjay
>>> >> > On Mon, Jul 6, 2020 at 5:38 AM Joel Sherrill <joel at rtems.org>
>>> wrote:
>>> >> >> On Sun, Jul 5, 2020, 6:12 PM Chris Johns <chrisj at rtems.org> wrote:
>>> >> >>> On 6/7/20 12:47 am, Heinz Junkes wrote:
>>> >> >>> > Thank you, this is exactly where I was unsure.
>>> >> >>> > @Chris: Can you give a recommendation here?
>>> >> >>> > Danke Heinz
>>> >> >>> > Fritz-Haber-Institut | Phone: (+49 30) 8413-4270
>>> >> >>> > Heinz Junkes | Fax (G3+G4): (+49 30) 8413-5900
>>> >> >>> > Faradayweg 4-6 | VC: 102220181216 at bjn.vc
>>> >> >>> > D - 14195 Berlin | E-Mail:
>>> >> >>> >> On 5. Jul 2020, at 16:20, Gedare Bloom <gedare at rtems.org>
>>> wrote:
>>> >> >>> >> On Sat, Jul 4, 2020 at 1:18 PM Mritunjay Sharma
>>> >> >>> >>> On Sun, Jul 5, 2020 at 12:28 AM Heinz Junkes <
>>> junkes at fhi-berlin.mpg.de> wrote:
>>> >> >>> >>>> Hello, Mritunjay,
>>> >> >>> >>>> that's good news. Don't you want to try to develop a rsb-set
>>> for exactly this combination of RTEMS4.10 and EPICS7?
>>> >> >>> >>> Sure, I am ready to do this and then do it with RTEMS5 in the
>>> same way. Please tell how to begin or some existing similar
>>> >> >>> >>> work that can guide me how to proceed further in relation to
>>> rsb-set for RTEMS4.10 and EPICS7.
>>> >> >>> >> I don't know if this is best. RSB didn't exist in 4.10. I
>>> haven't
>>> >> >>> >> looked to see how well the rtems-source-builder/4.10 would
>>> support a
>>> >> >>> >> package build. It should be discussed with Chris probably. A
>>> couple of
>>> >> >>> >> packages were added in the 4.11 branch.
>>> >> >>> I would leave 4.10 and move on. It may work but these things can
>>> expose issues
>>> >> >>> that turn into distractions.
>>> >> >>> Would making a script that does the build so we can document the
>>> steps be worth
>>> >> >>> while
>>> >> >> Yes. Emphatically yes. We need to make sure we know how it is best
>>> built by hand to automate it.
>>> >> >> I firmly believe you should not attempt to automate something
>>> until doing it manually is well understood and documented.
>>> >> >> After you have this down for one BSP, we need to ask questions
>>> like:
>>> >> >> + Is there any per BSP tailoring beyond the obviod architecture
>>> and compilation settings?
>>> >> >> + Any tweaks to settings users may want?
>>> >> >> The manual process should include testing. The RSB is a great way
>>> to automate and ease building but it doesn't address testing the packages
>>> yet.
>>> >> >> --joel
>>> >> >>> Chris
>>> >> >>> _______________________________________________
>>> >> >>> devel mailing list
>>> >> >>> devel at rtems.org
>>> >> >>> http://lists.rtems.org/mailman/listinfo/devel
>>> >> >> devel mailing list
>>> >> >> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200709/f1445152/attachment-0001.html>
