NEW BUILD SYSTEM: Cannot build rtems-libbsd
Wed Jul 8 09:18:55 UTC 2020
On 08/07/2020 11:11, Niteesh G. S. wrote:
>     Could you please use the 5-freebsd-12 branch with the default
>     build set.
>     This is what I use normally.
> I was able to build libbsd on 5-freebsd-12 branch with the default
> build set
> though using minimal build set doesn't work. I have attached the
> output file.
Did you delete the build tree before you changed the build set?
This patch should fix the build issues on the master branch with the new
build system:
https://lists.rtems.org/pipermail/devel/2020-July/060530.html
