NEW BUILD SYSTEM: Cannot build rtems-libbsd
Niteesh G. S. niteesh.gs at gmail.com
Wed Jul 8 09:45:35 UTC 2020
On Wed, Jul 8, 2020 at 2:48 PM Sebastian Huber <
> On 08/07/2020 11:11, Niteesh G. S. wrote:
> >     Could you please use the 5-freebsd-12 branch with the default
> >     build set.
> >     This is what I use normally.
> > I was able to build libbsd on 5-freebsd-12 branch with the default
> > build set
> > though using minimal build set doesn't work. I have attached the
> > output file.
> Did you delete the build tree before you changed the build set?
It works after deleting the build tree. May I please know why ./waf clean
doesn't work.
This patch should fix the build issues on the master branch with the new
> build system:
> https://lists.rtems.org/pipermail/devel/2020-July/060530.html
Thank you for the patch. I applied it locally and it works.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200708/54c17cc8/attachment.html>
