[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
Wed Jul 8 19:44:35 UTC 2020
On Wed, Jul 8, 2020 at 12:33 PM Mritunjay Sharma
<mritunjaysharma394 at gmail.com> wrote:
> [UPDATE]: I tried to build the EPICS 7 with RTEMS 5 for pc386 with Heinz's https://github.com/hjunkes/epicsBaseOwnPlayground
> while switching to Branch "7". The previous errors are gone but I am facing the following error:
> "../posix/rtems_init.c:38:10: fatal error: rtems/bsd/bsd.h: No such file or directory
>  #include <rtems/bsd/bsd.h>
This error indicates it is looking for an installed rtems-libbsd. My
guess is you need to build/install the rtems-libbsd to get this
playground to work.
> compilation terminated.
> /home/mritunjay/development/EPICS/epicsBaseOwnPlayground/configure/RULES_BUILD:234: recipe for target 'rtems_init.o' failed
> make[4]: *** [rtems_init.o] Error 1
> make[4]: Leaving directory '/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/modules/libcom/RTEMS/O.RTEMS-pc386'
> /home/mritunjay/development/EPICS/epicsBaseOwnPlayground/configure/RULES_ARCHS:58: recipe for target 'install.RTEMS-pc386' failed
> make[3]: *** [install.RTEMS-pc386] Error 2
> make[3]: Leaving directory '/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/modules/libcom/RTEMS'
> /home/mritunjay/development/EPICS/epicsBaseOwnPlayground/configure/RULES_DIRS:84: recipe for target 'RTEMS.install' failed
> make[2]: *** [RTEMS.install] Error 2
> make[2]: Leaving directory '/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/modules/libcom'
> ../configure/RULES_DIRS:84: recipe for target 'libcom.install' failed
> make[1]: *** [libcom.install] Error 2
> make[1]: Leaving directory '/home/mritunjay/development/EPICS/epicsBaseOwnPlayground/modules'
> configure/RULES_DIRS:84: recipe for target 'modules.install' failed
> make: *** [modules.install] Error 2"
> Today's update is that I tried to fix the above error however I still have not been able to clear it.
> If anyone has idea, please do tell what can be done.
> Thanks
> Mritunjay
> On Wed, Jul 8, 2020 at 1:12 AM Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
>> ________________________________
>> From: Heinz Junkes <junkes at fhi-berlin.mpg.de>
>> Sent: Wednesday, July 8, 2020 1:05 AM
>> To: Mritunjay Sharma
>> Cc: Gedare Bloom; Joel Sherrill; Chris Johns; RTEMS Devel
>> Subject: Re: [GSoC 2020: Daily Update]: Building EPICS with RTEMS5
>> I’m away from my keyboard. If you use the epics Adaption to rtems from my github “playground?” and bsp’s with —enable-networks should compile.
>> Heinz
>> FHI, Heinz Junkes
>> Thank you Heinz, I was doing the same. I went to your GitHub and am experimenting with "playground" right now.
>> Thanks,
>> Mritunjay
>> On 7. Jul 2020, at 18:14, Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
>> [UPDATE]: I tried building EPICS with RTEMS5 for pc-386 and pc-386-qemu.
>> Everything worked fine while building the pc-386 with  RTEMS5.
>> After this when I entered epics-base and made the following change:
>> epics-base/os/CONFIG_SITE.Common.RTEMS
>> RTEMS_VERSION = 5
>> RTEMS_BASE = /home/mritunjay/development/rtems_dev/$(RTEMS_VERSION)
>> As an experiment, I ran the make and as expected got the following error
>> Error:
>> ```...de/compiler/gcc -I../../../../include/os/RTEMS -I../../../../include         -c ../rtems_init.c
>> ../rtems_init.c:21:10: fatal error: sys/termios.h: No such file or directory
>>  #include <sys/termios.h>
>> ../../../../configure/RULES_BUILD:240: recipe for target 'rtems_init.o' failed
>> make[4]: Leaving directory '/home/mritunjay/development/EPICS/epics-base/modules/libcom/RTEMS/O.RTEMS-pc386'
>> ../../../configure/RULES_ARCHS:58: recipe for target 'install.RTEMS-pc386' failed
>> make[3]: Leaving directory '/home/mritunjay/development/EPICS/epics-base/modules/libcom/RTEMS'
>> ../../configure/RULES_DIRS:85: recipe for target 'RTEMS.install' failed
>> make[2]: Leaving directory '/home/mritunjay/development/EPICS/epics-base/modules/libcom'
>> ../configure/RULES_DIRS:85: recipe for target 'libcom.install' failed
>> make[1]: Leaving directory '/home/mritunjay/development/EPICS/epics-base/modules'
>> configure/RULES_DIRS:85: recipe for target 'modules.install' failed
>> I am trying to figure out the error and making the changes in code to debug it.
>> However, I will appreciate if Heinz and everyone else can help me a little, if they have an
>> idea of this error.
>> Thanks
>> Mritunjay
>> On Tue, Jul 7, 2020 at 7:30 PM Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
>>> On Tue, Jul 7, 2020 at 5:33 AM Gedare Bloom <gedare at rtems.org> wrote:
>>>> On Mon, Jul 6, 2020 at 5:49 PM Joel Sherrill <joel at rtems.org> wrote:
>>>> > On Mon, Jul 6, 2020, 6:14 PM Gedare Bloom <gedare at rtems.org> wrote:
>>>> >> On Mon, Jul 6, 2020 at 10:12 AM Mritunjay Sharma
>>>> >> > Hello everyone,
>>>> >> > Thank you, Heinz, Gedare, Chris and Joel for your advice.
>>>> >> > If there are issues in making a buildset for 4.10
>>>> >> > then should I build EPICS with RTEMS 5 by hand first and note
>>>> >> > down the process and then proceed to make the buildset for it?
>>>> >> Yes.
>>>> > +1
>>>> > And by 5, we definitely mean the 5 branch for all rtems repo and the similarly named one for libbsd.
>>>> Excellent point. We want to add support for easy build (and eventually
>>>> test) of EPICS+RTEMS starting with 5.1 and moving forward, which means
>>>> also doing it for RTEMS 6, Mritunjay.
>>> Sounds good, I have begun building it hand by today for RTEMS 5 branch and later on continue the
>>> same for RTEMS6
>>> Thank you so much Gedare and Joel.
>>> Mritunjay
>>>> >> > Please suggest for the future steps.
>>>> >> > Thanks
>>>> >> > Mritunjay
>>>> >> > On Mon, Jul 6, 2020 at 5:38 AM Joel Sherrill <joel at rtems.org> wrote:
>>>> >> >> On Sun, Jul 5, 2020, 6:12 PM Chris Johns <chrisj at rtems.org> wrote:
>>>> >> >>> On 6/7/20 12:47 am, Heinz Junkes wrote:
>>>> >> >>> > Thank you, this is exactly where I was unsure.
>>>> >> >>> > @Chris: Can you give a recommendation here?
>>>> >> >>> > Danke Heinz
>>>> >> >>> > Fritz-Haber-Institut    | Phone:         (+49 30) 8413-4270
>>>> >> >>> > Heinz Junkes             | Fax (G3+G4):   (+49 30) 8413-5900
>>>> >> >>> > Faradayweg 4-6        | VC: 102220181216 at bjn.vc
>>>> >> >>> > D - 14195 Berlin        | E-Mail:        junkes at fhi-berlin.mpg.de
>>>> >> >>> >> On 5. Jul 2020, at 16:20, Gedare Bloom <gedare at rtems.org> wrote:
>>>> >> >>> >> On Sat, Jul 4, 2020 at 1:18 PM Mritunjay Sharma
>>>> >> >>> >>> On Sun, Jul 5, 2020 at 12:28 AM Heinz Junkes <junkes at fhi-berlin.mpg.de> wrote:
>>>> >> >>> >>>> Hello, Mritunjay,
>>>> >> >>> >>>> that's good news. Don't you want to try to develop a rsb-set for exactly this combination of RTEMS4.10 and EPICS7?
>>>> >> >>> >>> Sure, I am ready to do this and then do it with RTEMS5 in the same way. Please tell how to begin or some existing similar
>>>> >> >>> >>> work that can guide me how to proceed further in relation to rsb-set for  RTEMS4.10 and EPICS7.
>>>> >> >>> >> I don't know if this is best. RSB didn't exist in 4.10. I haven't
>>>> >> >>> >> looked to see how well the rtems-source-builder/4.10 would support a
>>>> >> >>> >> package build. It should be discussed with Chris probably. A couple of
>>>> >> >>> >> packages were added in the 4.11 branch.
>>>> >> >>> I would leave 4.10 and move on. It may work but these things can expose issues
>>>> >> >>> that turn into distractions.
>>>> >> >>> Would making a script that does the build so we can document the steps be worth
>>>> >> >>> while
>>>> >> >> Yes. Emphatically yes. We need to make sure we know how it is best built by hand to automate it.
>>>> >> >> I firmly believe you should not attempt to automate something until doing it manually is well understood and documented.
>>>> >> >> After you have this down for one BSP, we need to ask questions like:
>>>> >> >> + Is there any per BSP tailoring beyond the obviod architecture and compilation settings?
>>>> >> >> + Any tweaks to settings users may want?
>>>> >> >> The manual process should include testing. The RSB is a great way to automate and ease building but it doesn't address testing the packages yet.
>>>> >> >> --joel
>>>> >> >>> Chris
>>>> >> >>> _______________________________________________
>>>> >> >>> devel mailing list
>>>> >> >>> devel at rtems.org
>>>> >> >>> http://lists.rtems.org/mailman/listinfo/devel
>>>> >> >> devel mailing list
>>>> >> >> devel at rtems.org
