[GSoC 2020: Daily Update]: Building EPICS with RTEMS5
Mritunjay Sharma mritunjaysharma394 at gmail.com
Mon Jul 13 19:03:48 UTC 2020
Hello everyone,
Good news is that my new system is fully functional now with
the development environment and I resumed the work today.
What I was trying to do was build EPICS 7 with RTEMS 5 by hand
for pc-386.
As advised in the thread, in my new system, I built pc-386 with
'--enable-networking' and used the epics 'playground' code of
Heinz to do 'make' in epics-base.
Few errors came which I was able to remove by installing a few dependencies.
However, the below-mentioned error is something that I haven't been able to
resolve for now:
`./posix/rtems_init.c:38:10: fatal error: rtems/bsd/bsd.h: No such file or
directory
 #include <rtems/bsd/bsd.h>
compilation terminated.
make[4]: ***
[/home/mritunjay/development/EPICS/epics-playground/configure/RULES_BUILD:235:
rtems_init.o] Error 1
make[4]: Leaving directory
'/home/mritunjay/development/EPICS/epics-playground/modules/libcom/RTEMS/O.RTEMS-pc386'
make[3]: ***
[/home/mritunjay/development/EPICS/epics-playground/configure/RULES_ARCHS:58:
install.RTEMS-pc386] Error 2
make[3]: Leaving directory
'/home/mritunjay/development/EPICS/epics-playground/modules/libcom/RTEMS'
make[2]: ***
[/home/mritunjay/development/EPICS/epics-playground/configure/RULES_DIRS:84:
RTEMS.install] Error 2
make[2]: Leaving directory
'/home/mritunjay/development/EPICS/epics-playground/modules/libcom'
make[1]: *** [../configure/RULES_DIRS:84: libcom.install] Error 2
make[1]: Leaving directory
'/home/mritunjay/development/EPICS/epics-playground/modules'
make: *** [configure/RULES_DIRS:84: modules.install] Error 2
Please help me how to fix these and also guide on what should be my target
this week? What should be my next steps?
Thanks
Mritunjay
On Sat, Jul 11, 2020 at 8:16 PM Heinz Junkes <junkes at fhi-berlin.mpg.de>
wrote:
> It's not my experience.
> I made my first attempts with RTEMS5 for a beatnik-board (MVME6100).
> For this I created the BSP like this:
>  cd build/b-beatnik
>     ../../rtems/configure --enable-maintainer-mode
> --prefix=$HOME/RTEMS/rtems-5 --target=powerpc-rtems5
> --enable-rtemsbsp="beatnik" --enable-posix --enable-cxx --enable-networking
> Through "--enable-networking" I was able to use the "old" rtems-bsdnet.
> With NTP, NFS etc. .
> At the moment I am in the process of using the "new" netbsd. For this I am
> no longer allowed to specify "--enable-networking" when building the bsp.
> That's what it says
> in the documentation and it works. The old NFS also works with it, it just
> lacks NTP (or PTP). And what I still miss very much is the support for the
> RTC and above all
> the libpci to access the vmebus.
> So I played a little with xilinx-zynq and beaglebone. Now I make the
> rtems_init at EPICS dependent on
> xilinx_zynq_zedboard/make/bsp.cfg:HAS_NETWORKING = no (new bsdlib)
> beatnik/make/bsp.cfg:HAS_NETWORKING = yes (old rtemsbsd code)
> Gruss Heinz
> On 11. Jul 2020, at 00:14, Joel Sherrill <joel at rtems.org> wrote:
> Wading in late but I thought I saw something that was contradictory:
> Build BSP with --enable-networking
> Code needs rtems-libbsd
> If the code needs rtems-libbsd, then you MUST build fill with
> --disable-networking.
> If EPICS code needs rtems-libbsd, that limits the number of BSPs that can
> be used but you need to always use libbsd.
> --joel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200714/20dbf773/attachment.html>
