[GSoC 2020]: Weekly thread update
Gedare Bloom
gedare at rtems.org
Wed Jul 15 04:30:35 UTC 2020
On Tue, Jul 14, 2020 at 9:57 PM Mritunjay Sharma
<mritunjaysharma394 at gmail.com> wrote:
> On Wed, Jul 15, 2020 at 5:33 AM Chris Johns <chrisj at rtems.org> wrote:
>> On 15/7/20 4:30 am, Mritunjay Sharma wrote:
>> > Hello everyone,
>> > Pardon my mistake for that long thread. From now on the daily updates will be
>> > given on a thread that will end every week.
>> Thank you :)
>> > 1) I studied about https://github.com/RTEMS/rtems-libbsd
>> > 2) Tried to fix the error that I reported yesterday:
>> Why cut the compile command line used to build this file out of the message? The
>> compiler command is important because it lets us see what paths are being used
>> and I think there may be a problem with them.
>> > ../posix/rtems_init.c:38:10: fatal error: rtems/bsd/bsd.h: No such file or directory
>> > #include <rtems/bsd/bsd.h>
Try #include <rtems/bsd.h>
>> I cannot duplicate this because I am not sure what the sequence of commands are
>> you used to get to here. I am sorry if I missed it in a previous post.
>> The error indicates a set up issue. It normally means the networking software
>> (rtems-libbsd) has not been installed into a prefix path EPICS looks in.
> I am posting the entire command set further ahead in the email which will make things
> easier to understand.
>> > compilation terminated.
>> > make[4]: ***
>> > [/home/mritunjay/development/EPICS/epics-playground/configure/RULES_BUILD:235:
>> > rtems_init.o] Error 1
>> > make[4]: Leaving directory
>> > '/home/mritunjay/development/EPICS/epics-playground/modules/libcom/RTEMS/O.RTEMS-pc386'
>> > make[3]: ***
>> > [/home/mritunjay/development/EPICS/epics-playground/configure/RULES_ARCHS:58:
>> > install.RTEMS-pc386] Error 2
>> > make[3]: Leaving directory
>> > '/home/mritunjay/development/EPICS/epics-playground/modules/libcom/RTEMS'
>> > make[2]: ***
>> > [/home/mritunjay/development/EPICS/epics-playground/configure/RULES_DIRS:84:
>> > RTEMS.install] Error 2
>> > make[2]: Leaving directory
>> > '/home/mritunjay/development/EPICS/epics-playground/modules/libcom'
>> > make[1]: *** [../configure/RULES_DIRS:84: libcom.install] Error 2
>> > make[1]: Leaving directory
>> > '/home/mritunjay/development/EPICS/epics-playground/modules'
>> > make: *** [configure/RULES_DIRS:84: modules.install] Error 2
>> > I am still not successful even though I tried to search for it.
>> I doubt there will be anything to search for. You are solving the problem and
>> creating the first info to be searched. We need to debug the problem.
>> > On the advice of Heinz, I have already built EPICS 7 with RTEMS4.10
>> > by hand and am on the verge of doing the same for EPICS7 with RTEMS5
>> > for pc-386.
>> I am sorry I do not understand what "on the verge of doing the same" means.
> I am sorry for the misunderstanding. It means that after these bugs are resolved with this
> discussion I will successfully be able to build EPICS7 with RTEMS5
>> > However, I will like to request all my mentors to help me set the goals
>> > for this week and where should I begin next?
>> Could you please update your blog with the exact command sequences you are using
>> to build EPICS7 for RTEMS 4.10 and EPICS7 for RTEMS 5 for a PC?
> While I will be updating the commands in the blog, I am posting the same here for easier reference:
> Building EPICS7 for RTEMS4.10 with pc-386:
> In order to do that, I made the directory
> i) $HOME/development/rtems/
> ii) I extracted rtems-4.10 from here https://ftp.rtems.org/pub/rtems/releases/4.10/
> iii)I created another directory rtems/src
> iv)Inside src, I cloned rsb and moved to 4.10 branch.
> v) After performing checks, I entered to rsb/rtems and used this command:
> '../source-builder/sb-set-builder --prefix=/home/mritunjay/development/rtems/4.10 4.10/rtems-i386'.
> vi) Now the directory structure under $HOME/development/rtems/ looked like:
> | rtems-4.10
> | 4.10
> | src/rsb
> | kernel/pc386
> I also used this command: "export PATH=$HOME/development/rtems/4.10/bin:$PATH"
> vi) Then I went to rtems/rtems-4.10 and used this command:
> "./bootstrap -c && $HOME/development/rtems/src/rsb/source-builder/sb-bootstrap"
> vi) After this I went insid directory $HOME/development/rtems/kernel/pc-386
> vii) Inside pc-386, I used the following command:
> ''$HOME/development/rtems_dev/rtems-4.10.2/configure --target=i386-rtems4.10 --enable-posix --enable-rtemsbsp=pc386 --enable-tests=samples --prefix=$HOME/development/rtems/4.10 --enable-cxx"
> viii) Then I entered the make command which ran successfully and the make install was also successful.
> So all the errors were resolved and I moved on to build EPICS now for RTEMS 4.10.
> '''export RTEMS_MAKEFILE_PATH=$HOME/development/rtems/4.10/i386-rtems4.10/pc386''
> Location of epics-base in my system is as follows:
> "$HOME/development/EPICS/epics-base"
> After this, I followed the tutorial Heinz sent to build EPICS for rtems-4.10 for pc-386 which is:
>> Very roughly:
>> git clone —recursive epics-base
>> in epics-base/configure/CONFIG_SITE
>> set
>> CROSS_COMPILER_TARGET_ARCHS=
> What I entered:
> CROSS_COMPILER_TARGET_ARCHS= RTEMS-pc386-qemu
>> e.g. RTEMS-pc386
>> or RTEMS-xilinx_zynq_a9_qemu
>> in epics-base/configure/os there must be a file for the target used,
>> e.g.
>> CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
>> or
>> CONFIG.Common.RTEMS-pc386
> Checked. CONFIG.Common.RTEMS-pc386 was there
>> Then you have to set in configure/os/CONFIG_SITE.Common.RTEMS
>> where to find RTEMS:
>> # Where to find RTEMS
>> # APS:
>> #RTEMS_VERSION = 4.10.2
>> #RTEMS_BASE = /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)
> In my system, I entered this:
> #APS
> RTEMS_BASE = /home/mritunjay/development/rtems/$(RTEMS_VERSION)
> I followed the above instructions and used the 'make' command.
> It was successful for RTEMS 4.10 and EPICS 7.
> I was following almost the same set of commands and steps for RTEMS5 as well with changes
> in RTEMS source and the prefix such that the directory structure under $HOME/development/rtems/ looked like:
> | rtems-5 (source from git set in `5` branch)
> | 5 (prefix)
> | src/rsb (switched to `5` branch)
> | kernels-5/pc386
> I used this command inside kernels-5/pc386:
> `$HOME/development/rtems/rtems-5/configure --target=i386-rtems5 --enable-rtemsbsp=pc386 --enable-tests=samples --prefix=$HOME/development/rtems/5 --enable-cxx --enable-networking --enable-posix`.
> The make and make install was successful here.
> After this, I used a different epics-base (The one I downloaded from Heinz's playground)
> and made corresponding changes in the file for RTEMS5 as described above in the tutorial sent by Heinz.
> When I ran `make` inside the `playground` epics-base, I got the error that I mentioned.
>> Have you run EPIRC7 for 4.10 in qemu? If so did the network come up and work?
> Yes, I ran EPICS7 for 4.10 in qemu. I ran the EPICS test suites for RTEMS in QEMU using the
> following command:
> ```qemu-system-i386 -no-reboot -m 128 -boot n -serial stdio -net nic -net user,tftp=$PWD,bootfile=bin/RTEMS-pc386-qemu/dbTestHarness```
> The QEMU emulator successfully opened then and it showed that all the tests passed.
> I am attaching the screenshot as well.
>> Have you run the rtems-libbsd test executables in qemu?
> I am not sure if I have done this. Can you please tell what can be the command for it?
> Thanks
> Mritunjay
>> Thanks
>> Chris
