[GSoC 2020]: Weekly thread update
Mritunjay Sharma
mritunjaysharma394 at gmail.com
Wed Jul 15 03:57:21 UTC 2020
On Wed, Jul 15, 2020 at 5:33 AM Chris Johns <chrisj at rtems.org> wrote:
> On 15/7/20 4:30 am, Mritunjay Sharma wrote:
> > Hello everyone,
> > Pardon my mistake for that long thread. From now on the daily updates
> will be
> > given on a thread that will end every week.
> Thank you :)
> > 1) I studied about https://github.com/RTEMS/rtems-libbsd
> > 2) Tried to fix the error that I reported yesterday:
> Why cut the compile command line used to build this file out of the
> message? The
> compiler command is important because it lets us see what paths are being
> used
> and I think there may be a problem with them.
> > ../posix/rtems_init.c:38:10: fatal error: rtems/bsd/bsd.h: No such file
> or directory
> > #include <rtems/bsd/bsd.h>
> I cannot duplicate this because I am not sure what the sequence of
> commands are
> you used to get to here. I am sorry if I missed it in a previous post.
> The error indicates a set up issue. It normally means the networking
> software
> (rtems-libbsd) has not been installed into a prefix path EPICS looks in.
I am posting the entire command set further ahead in the email which will
make things
easier to understand.
> > compilation terminated.
> > make[4]: ***
> [/home/mritunjay/development/EPICS/epics-playground/configure/RULES_BUILD:235:
> > rtems_init.o] Error 1
> > make[4]: Leaving directory
> '/home/mritunjay/development/EPICS/epics-playground/modules/libcom/RTEMS/O.RTEMS-pc386'
> > make[3]: ***
> [/home/mritunjay/development/EPICS/epics-playground/configure/RULES_ARCHS:58:
> > install.RTEMS-pc386] Error 2
> > make[3]: Leaving directory
> > '/home/mritunjay/development/EPICS/epics-playground/modules/libcom/RTEMS'
> > make[2]: ***
> [/home/mritunjay/development/EPICS/epics-playground/configure/RULES_DIRS:84:
> > RTEMS.install] Error 2
> > make[2]: Leaving directory
> > '/home/mritunjay/development/EPICS/epics-playground/modules/libcom'
> > make[1]: *** [../configure/RULES_DIRS:84: libcom.install] Error 2
> > make[1]: Leaving directory
> > '/home/mritunjay/development/EPICS/epics-playground/modules'
> > make: *** [configure/RULES_DIRS:84: modules.install] Error 2
> > I am still not successful even though I tried to search for it.
> I doubt there will be anything to search for. You are solving the problem
> and
> creating the first info to be searched. We need to debug the problem.
> > On the advice of Heinz, I have already built EPICS 7 with RTEMS4.10
> > by hand and am on the verge of doing the same for EPICS7 with RTEMS5
> > for pc-386.
> I am sorry I do not understand what "on the verge of doing the same" means.
I am sorry for the misunderstanding. It means that after these bugs are
resolved with this
discussion I will successfully be able to build EPICS7 with RTEMS5
> > However, I will like to request all my mentors to help me set the goals
> > for this week and where should I begin next?
> Could you please update your blog with the exact command sequences you are
> using
> to build EPICS7 for RTEMS 4.10 and EPICS7 for RTEMS 5 for a PC?
While I will be updating the commands in the blog, I am posting the same
here for easier reference:
Building EPICS7 for RTEMS4.10 with pc-386:
In order to do that, I made the directory
i) $HOME/development/rtems/
ii) I extracted rtems-4.10 from here
https://ftp.rtems.org/pub/rtems/releases/4.10/
<https://ftp.rtems.org/pub/rtems/releases/4.10/4.10.2/>
iii)I created another directory rtems/src
iv)Inside src, I cloned rsb and moved to 4.10 branch.
v) After performing checks, I entered to rsb/rtems and used this command:
'../source-builder/sb-set-builder
--prefix=/home/mritunjay/development/rtems/4.10 4.10/rtems-i386'.
vi) Now the directory structure under $HOME/development/rtems/ looked like:
| rtems-4.10
| 4.10
| src/rsb
| kernel/pc386
I also used this command: "export
PATH=$HOME/development/rtems/4.10/bin:$PATH"
vi) Then I went to rtems/rtems-4.10 and used this command:
"./bootstrap -c &&
$HOME/development/rtems/src/rsb/source-builder/sb-bootstrap"
vi) After this I went insid directory $HOME/development/rtems/kernel/pc-386
vii) Inside pc-386, I used the following command:
''$HOME/development/rtems_dev/rtems-4.10.2/configure
--target=i386-rtems4.10 --enable-posix --enable-rtemsbsp=pc386
--enable-tests=samples --prefix=$HOME/development/rtems/4.10 --enable-cxx"
viii) Then I entered the make command which ran successfully and the make
install was also successful.
So all the errors were resolved and I moved on to build EPICS now for RTEMS
4.10.
'''export
RTEMS_MAKEFILE_PATH=$HOME/development/rtems/4.10/i386-rtems4.10/pc386''
Location of epics-base in my system is as follows:
"$HOME/development/EPICS/epics-base"
After this, I followed the tutorial Heinz sent to build EPICS for
rtems-4.10 for pc-386 which is:
> Very roughly:
> git clone —recursive epics-base
> in epics-base/configure/CONFIG_SITE
> set
> CROSS_COMPILER_TARGET_ARCHS=
What I entered:
CROSS_COMPILER_TARGET_ARCHS= RTEMS-pc386-qemu
> e.g. RTEMS-pc386
> or RTEMS-xilinx_zynq_a9_qemu
> in epics-base/configure/os there must be a file for the target used,
> e.g.
> CONFIG.Common.RTEMS-xilinx_zynq_a9_qemu
> or
> CONFIG.Common.RTEMS-pc386
Checked. CONFIG.Common.RTEMS-pc386 was there
> Then you have to set in configure/os/CONFIG_SITE.Common.RTEMS
> where to find RTEMS:
> # Where to find RTEMS
> # APS:
> #RTEMS_VERSION = 4.10.2
> #RTEMS_BASE = /usr/local/vw/rtems/rtems-$(RTEMS_VERSION)
In my system, I entered this:
#APS
RTEMS_BASE = /home/mritunjay/development/rtems/$(RTEMS_VERSION)
I followed the above instructions and used the 'make' command.
It was successful for RTEMS 4.10 and EPICS 7.
I was following almost the same set of commands and steps for RTEMS5 as
well with changes
in RTEMS source and the prefix such that the directory structure under
| rtems-5 (source from git set in `5` branch)
| 5 (prefix)
| src/rsb (switched to `5` branch)
| kernels-5/pc386
I used this command inside kernels-5/pc386:
`$HOME/development/rtems/rtems-5/configure --target=i386-rtems5
--enable-rtemsbsp=pc386 --enable-tests=samples
--prefix=$HOME/development/rtems/5 --enable-cxx --enable-networking
--enable-posix`.
The make and make install was successful here.
After this, I used a different epics-base (The one I downloaded from
Heinz's playground)
and made corresponding changes in the file for RTEMS5 as described above in
the tutorial sent by Heinz.
When I ran `make` inside the `playground` epics-base, I got the error that
I mentioned.
> Have you run EPIRC7 for 4.10 in qemu? If so did the network come up and
> work?
Yes, I ran EPICS7 for 4.10 in qemu. I ran the EPICS test suites for RTEMS
in QEMU using the
following command:
```qemu-system-i386 -no-reboot -m 128 -boot n -serial stdio -net nic -net
user,tftp=$PWD,bootfile=bin/RTEMS-pc386-qemu/dbTestHarness```
The QEMU emulator successfully opened then and it showed that all the tests
passed.
I am attaching the screenshot as well.
> Have you run the rtems-libbsd test executables in qemu?
I am not sure if I have done this. Can you please tell what can be the
command for it?
Thanks
Mritunjay
> Thanks
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200715/84dba957/attachment-0001.html>
Name: Screenshot from 2020-07-05 02-26-55.png
Type: image/png
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200715/84dba957/attachment-0001.png>
