GSoC 2020 PATCH: Import OpenFirmWare API to RTEMS
G S Niteesh Babu
niteesh.gs at gmail.com
Wed Jul 15 06:31:50 UTC 2020
Hello,
This series of patches import OpenFirmWare to RTEMS from FreeBSD. These
patches are based on the new build system, so it will require the person
building this patch to pull Sebastian's 'build' branch from his git
repo.
Sebastian's git repo: https://git.rtems.org/sebh/rtems.git/log/?h=build
And the instructions to build RTEMS with the new build system can be
found here: https://ftp.rtems.org/pub/rtems/people/sebh/user.pdf
bsps/include/bsp/fdt.h | 86 ++++--------
cpukit/include/dev/ofw/openfirm.h | 203 +++++++++++++++++++++++++++
cpukit/include/rtems/fdt.h | 69 +++++++++
cpukit/libfreebsd/freebsd/dev/ofw/ofw_fdt.c | 626 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
cpukit/libfreebsd/freebsd/dev/ofw/ofw_if.h | 62 ++++++++
cpukit/libfreebsd/freebsd/dev/ofw/openfirm.c | 904 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
cpukit/libfreebsd/rtems-freebsd-helper.h | 47 +++++++
spec/build/cpukit/librtemscpu.yml | 6 +
spec/build/cpukit/objfreebsd.yml | 17 +++
spec/build/testsuites/libtests/grp.yml | 3 +
spec/build/testsuites/libtests/openfirmware01.yml | 20 +++
testsuites/libtests/openfirmware01/init.c | 147 +++++++++++++++++++
testsuites/libtests/openfirmware01/openfirmware01.doc | 29 ++++
testsuites/libtests/openfirmware01/openfirmware01.scn | 2 +
testsuites/libtests/openfirmware01/some.c | 52 +++++++
testsuites/libtests/openfirmware01/some.dts | 54 +++++++
testsuites/libtests/openfirmware01/some.h | 15 ++
17 files changed, 2286 insertions(+), 56 deletions(-)
create mode 100644 cpukit/include/dev/ofw/openfirm.h
create mode 100644 cpukit/include/rtems/fdt.h
create mode 100644 cpukit/libfreebsd/freebsd/dev/ofw/ofw_fdt.c
create mode 100644 cpukit/libfreebsd/freebsd/dev/ofw/ofw_if.h
create mode 100644 cpukit/libfreebsd/freebsd/dev/ofw/openfirm.c
create mode 100644 cpukit/libfreebsd/rtems-freebsd-helper.h
create mode 100644 spec/build/cpukit/objfreebsd.yml
create mode 100644 spec/build/testsuites/libtests/openfirmware01.yml
create mode 100644 testsuites/libtests/openfirmware01/init.c
create mode 100644
create mode 100644
create mode 100644 testsuites/libtests/openfirmware01/some.c
create mode 100644 testsuites/libtests/openfirmware01/some.dts
create mode 100644 testsuites/libtests/openfirmware01/some.h
