[PATCH RTEMS 1/7] bsp/fdt.h: Move bsp/fdt.h to cpukit
G S Niteesh Babu
niteesh.gs at gmail.com
Wed Jul 15 06:31:51 UTC 2020
This commit move the bsp/fdt.h header to cpukit/include/rtems.
The reason for this is, with inclusion of libfreebsd there are
cases where their is need for bsp_fdt_get(). And with this
header under bsps directory it is not possible to include it
under a cpukit directory.
bsps/include/bsp/fdt.h | 86 +++++++++++--------------------
cpukit/include/rtems/fdt.h | 69 +++++++++++++++++++++++++
spec/build/cpukit/librtemscpu.yml | 1 +
3 files changed, 100 insertions(+), 56 deletions(-)
create mode 100644 cpukit/include/rtems/fdt.h
diff --git a/bsps/include/bsp/fdt.h b/bsps/include/bsp/fdt.h
index 4ed05b136c..4a7c3dfb24 100644
--- a/bsps/include/bsp/fdt.h
+++ b/bsps/include/bsp/fdt.h
@@ -1,67 +1,41 @@
- * Copyright (c) 2015, 2017 embedded brains GmbH. All rights reserved.
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifndef LIBBSP_SHARED_FDT_H
-#define LIBBSP_SHARED_FDT_H
-#include <bsp.h>
-#ifdef __cplusplus
-extern "C" {
-#endif /* __cplusplus */
- * BSPs that implement the FDT support functions must define
- * BSP_FDT_IS_SUPPORTED.
- * @brief Copies the specified source FDT to a dedicated global data area.
+ * @file
- * The source FDT is usually provided by a bootloader and may be located in a
- * memory area that is used by the program. The low-level initialization
- * should copy the FDT for later use.
+ * @ingroup RTEMSBSPsShared
- * The copy can be accessed by bsp_fdt_get().
- * @param[in] src The source FDT.
-void bsp_fdt_copy(const void *src);
- * @brief Returns the FDT of the BSP.
- * @return The FDT of the BSP.
+ * Copyright (C) <2020>, Niteesh G S <niteesh.gs at gmail.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
-const void *bsp_fdt_get(void);
- * @brief Maps the interrupt number of the FDT to the interrupt vector used by
- * the interrupt management.
- * This function is used by the libbsd to implement the OFW_BUS_MAP_INTR bus
- * method.
- * @param[in] intr The FDT interrupt number cells.
- * @param[in] icells The FDT interrupt cell count.
- * @return The interrupt vector of the FDT interrupt number.
-uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells);
+#ifndef LIBBSP_SHARED_FDT_H
+#define LIBBSP_SHARED_FDT_H
-#ifdef __cplusplus
+#include <bsp.h>
+#include <rtems/fdt.h>
#endif /* LIBBSP_SHARED_FDT_H */
diff --git a/cpukit/include/rtems/fdt.h b/cpukit/include/rtems/fdt.h
new file mode 100644
index 0000000000..149f7ff906
--- /dev/null
+++ b/cpukit/include/rtems/fdt.h
@@ -0,0 +1,69 @@
+ * Copyright (c) 2015, 2017 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+ * Modified by Niteesh G S <niteesh.gs at gmail.com>
+#ifndef RTEMS_FDT_H
+#define RTEMS_FDT_H
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * BSPs that implement the FDT support functions must define
+ * BSP_FDT_IS_SUPPORTED.
+ * @brief Copies the specified source FDT to a dedicated global data area.
+ * The source FDT is usually provided by a bootloader and may be located in a
+ * memory area that is used by the program. The low-level initialization
+ * should copy the FDT for later use.
+ * The copy can be accessed by bsp_fdt_get().
+ * @param[in] src The source FDT.
+void bsp_fdt_copy(const void *src);
+ * @brief Returns the FDT of the BSP.
+ * @return The FDT of the BSP.
+const void *bsp_fdt_get(void);
+ * @brief Maps the interrupt number of the FDT to the interrupt vector used by
+ * the interrupt management.
+ * This function is used by the libbsd to implement the OFW_BUS_MAP_INTR bus
+ * method.
+ * @param[in] intr The FDT interrupt number cells.
+ * @param[in] icells The FDT interrupt cell count.
+ * @return The interrupt vector of the FDT interrupt number.
+uint32_t bsp_fdt_map_intr(const uint32_t *intr, size_t icells);
+#ifdef __cplusplus
+#endif /* RTEMS_FDT_H */
diff --git a/spec/build/cpukit/librtemscpu.yml b/spec/build/cpukit/librtemscpu.yml
index 2af315da71..403662b97d 100644
--- a/spec/build/cpukit/librtemscpu.yml
+++ b/spec/build/cpukit/librtemscpu.yml
@@ -105,6 +105,7 @@ install:
- cpukit/include/rtems/extensionimpl.h
- cpukit/include/rtems/fatal.h
- cpukit/include/rtems/fb.h
+ - cpukit/include/rtems/fdt.h
- cpukit/include/rtems/flashdisk.h
- cpukit/include/rtems/framebuffer.h
- cpukit/include/rtems/fs.h
2.17.1
