[PATCH RTEMS 7/7] libtests/openfirmware: Added a testsuite for openfirmware
G S Niteesh Babu
niteesh.gs at gmail.com
Wed Jul 15 06:31:57 UTC 2020
spec/build/testsuites/libtests/grp.yml | 3 +
.../testsuites/libtests/openfirmware01.yml | 20 +++
testsuites/libtests/openfirmware01/init.c | 147 ++++++++++++++++++
.../openfirmware01/openfirmware01.doc | 29 ++++
.../openfirmware01/openfirmware01.scn | 2 +
testsuites/libtests/openfirmware01/some.c | 52 +++++++
testsuites/libtests/openfirmware01/some.dts | 54 +++++++
testsuites/libtests/openfirmware01/some.h | 15 ++
8 files changed, 322 insertions(+)
create mode 100644 spec/build/testsuites/libtests/openfirmware01.yml
create mode 100644 testsuites/libtests/openfirmware01/init.c
create mode 100644 testsuites/libtests/openfirmware01/openfirmware01.doc
create mode 100644 testsuites/libtests/openfirmware01/openfirmware01.scn
create mode 100644 testsuites/libtests/openfirmware01/some.c
create mode 100644 testsuites/libtests/openfirmware01/some.dts
create mode 100644 testsuites/libtests/openfirmware01/some.h
diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
index f1de6cd75f..56e84d2c89 100644
--- a/spec/build/testsuites/libtests/grp.yml
+++ b/spec/build/testsuites/libtests/grp.yml
@@ -11,6 +11,7 @@ install: []
ldflags:
- -Wl,--wrap=printf
- -Wl,--wrap=puts
+- -Wl,--wrap=bsp_fdt_get
links:
- role: build-dependency
uid: optbin2c
@@ -312,6 +313,8 @@ links:
uid: write
uid: writev
+- role: build-dependency
+ uid: openfirmware01
type: build
use-after:
- rtemstest
diff --git a/spec/build/testsuites/libtests/openfirmware01.yml b/spec/build/testsuites/libtests/openfirmware01.yml
new file mode 100644
index 0000000000..8feb69eb1e
--- /dev/null
+++ b/spec/build/testsuites/libtests/openfirmware01.yml
@@ -0,0 +1,20 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2020 Niteesh G S
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/libtests/openfirmware01/init.c
+- testsuites/libtests/openfirmware01/some.c
+stlib: []
+target: testsuites/libtests/openfirmware01.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/libtests/openfirmware01/init.c b/testsuites/libtests/openfirmware01/init.c
index 0000000000..fc38e6c513
--- /dev/null
+++ b/testsuites/libtests/openfirmware01/init.c
@@ -0,0 +1,147 @@
+ * Copyright (C) <2020> Niteesh G S <niteesh.gs at gmail.com>
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <tmacros.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <libfdt.h>
+#include <sys/endian.h>
+#include <dev/ofw/openfirm.h>
+#include "some.h"
+#define BUF_SIZE 100
+const char rtems_test_name[] = "OpenFirmWare 01";
+const void *__wrap_bsp_fdt_get(void);
+const void *__real_bsp_fdt_get(void);
+ if (some_bin != NULL) {
+ return &some_bin[0];
+ return __real_bsp_fdt_get();
+static void Init(rtems_task_argument arg)
+ int rv;
+ phandle_t d;
+ phandle_t l;
+ phandle_t t;
+ phandle_t root;
+ phandle_t temp;
+ uint32_t *arr;
+ char buf[BUF_SIZE];
+ char *bufp;
+ ssize_t buf_len;
+ TEST_BEGIN();
+ buf_len = sizeof(buf);
+ * Cannot use fdt_path_offset to compare because
+ * the OF interface uses the offset from the ftdp
+ * to the node as phandle.
+ root = OF_finddevice("/");
+ rtems_test_assert(root == 56);
+ root = OF_peer(0);
+ d = OF_child(root);
+ temp = OF_finddevice("/d");
+ rtems_test_assert(d == temp);
+ temp = OF_parent(d);
+ rtems_test_assert(root == temp);
+ rv = OF_getprop(d, "e", buf, buf_len);
+ rtems_test_assert(rv != -1);
+ rtems_test_assert(strcmp(buf, "f") == 0);
+ rv = OF_hasprop(d, "g");
+ rtems_test_assert(rv == 1);
+ rv = OF_getproplen(root, "model");
+ rtems_test_assert(rv == 2);
+ rv = OF_nextprop(d, "e", buf, buf_len);
+ rtems_test_assert(strcmp(buf, "g") == 0);
+ l = OF_finddevice("/m at 1248");
+ rv = OF_searchprop(l, "model", buf, buf_len);
+ rtems_test_assert(strcmp(buf, "c") == 0);
+ rv = OF_getprop_alloc(root, "compatible", (void **)&bufp);
+ rtems_test_assert(strcmp(bufp, "a,b") == 0);
+ OF_prop_free(bufp);
+ rv = OF_getprop_alloc_multi(l, "n", sizeof(*arr), (void **)&arr);
+ rtems_test_assert(arr[0] == htobe32(0xdeadbeef));
+ rtems_test_assert(arr[1] == htobe32(0x12345678));
+ rv = OF_getencprop_alloc_multi(l, "n", sizeof(*arr), (void **)&arr);
+ rtems_test_assert(arr[0] == 0xdeadbeef);
+ rtems_test_assert(arr[1] == 0x12345678);
+ t = OF_finddevice("/t");
+ rv = OF_nextprop(t, "u", buf, buf_len);
+ rtems_test_assert(rv == 0);
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
\ No newline at end of file
diff --git a/testsuites/libtests/openfirmware01/openfirmware01.doc b/testsuites/libtests/openfirmware01/openfirmware01.doc
index 0000000000..a9d2085798
--- /dev/null
+++ b/testsuites/libtests/openfirmware01/openfirmware01.doc
@@ -0,0 +1,29 @@
+This file describes the directives and concepts tested by this test set.
+test set name: openfirmware01
+directives:
+ - OF_peer
+ - OF_child
+ - OF_parent
+ - OF_getproplen
+ - OF_getprop
+ - OF_getencprop
+ - OF_hasprop
+ - OF_searchprop
+ - OF_searchencprop
+ - OF_getprop_alloc
+ - OF_getprop_alloc_multi
+ - OF_getencprop_alloc
+ - OF_getencprop_alloc_multi
+ - OF_prop_free
+ - OF_nextprop
+ - OF_setprop
+ - OF_canon
+ - OF_finddevice
+ - OF_package_to_path
+concepts:
+ - Ensure that some openfimware functions work as expected.
diff --git a/testsuites/libtests/openfirmware01/openfirmware01.scn b/testsuites/libtests/openfirmware01/openfirmware01.scn
index 0000000000..38abbdfc45
--- /dev/null
+++ b/testsuites/libtests/openfirmware01/openfirmware01.scn
@@ -0,0 +1,2 @@
+*** BEGIN OF TEST OPENFIRMWARE 1 ***
+*** END OF TEST OPENFIRMWARE 1 ***
diff --git a/testsuites/libtests/openfirmware01/some.c b/testsuites/libtests/openfirmware01/some.c
index 0000000000..5eed911204
--- /dev/null
+++ b/testsuites/libtests/openfirmware01/some.c
@@ -0,0 +1,52 @@
+ * Declarations for C structure representing binary file some.bin
+ * WARNING: Automatically generated -- do not edit!
+#include <sys/types.h>
+const unsigned char some_bin[] = {
+ 0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x01, 0xd8, 0x00, 0x00, 0x00, 0x38,
+ 0x00, 0x00, 0x01, 0x90, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
+ 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x48,
+ 0x00, 0x00, 0x01, 0x58, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x00, 0x61, 0x2c, 0x62, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x01,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x1a,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x26, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
+ 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x09, 0x66, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00, 0x00, 0x01,
+ 0x68, 0x40, 0x30, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+ 0x68, 0x40, 0x31, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x7b, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x61, 0x6c, 0x69, 0x61,
+ 0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+ 0x00, 0x00, 0x00, 0x30, 0x2f, 0x6d, 0x40, 0x31, 0x32, 0x34, 0x38, 0x00,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x6d, 0x40, 0x31, 0x32,
+ 0x34, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
+ 0x00, 0x00, 0x00, 0x32, 0xde, 0xad, 0xbe, 0xef, 0x12, 0x34, 0x56, 0x78,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x34,
+ 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+ 0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01,
+ 0x6f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+ 0x71, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x44, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x74, 0x00, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x46,
+ 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
+ 0x00, 0x00, 0x00, 0x09, 0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62,
+ 0x6c, 0x65, 0x00, 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73, 0x2d,
+ 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23, 0x73, 0x69, 0x7a, 0x65, 0x2d,
+ 0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x6d, 0x6f, 0x64, 0x65, 0x6c, 0x00,
+ 0x67, 0x00, 0x77, 0x00, 0x6b, 0x00, 0x6e, 0x00, 0x6c, 0x69, 0x6e, 0x75,
+ 0x78, 0x2c, 0x70, 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x70, 0x00,
+ 0x72, 0x00, 0x75, 0x00,
+const size_t some_bin_size = sizeof(some_bin);
diff --git a/testsuites/libtests/openfirmware01/some.dts b/testsuites/libtests/openfirmware01/some.dts
index 0000000000..ac15825b17
--- /dev/null
+++ b/testsuites/libtests/openfirmware01/some.dts
@@ -0,0 +1,54 @@
+ * Copyright (c) 2015 embedded brains GmbH. All rights reserved.
+ * embedded brains GmbH
+ * Dornierstr. 4
+ * 82178 Puchheim
+ * Germany
+ * <rtems at embedded-brains.de>
+/dts-v1/;
+ compatible = "a,b";
+ #address-cells = <1>;
+ #size-cells = <2>;
+ model = "c";
+ d {
+ e = "f";
+ g;
+ h at 0 {
+ h at 1 {
+ w = <123>;
+ aliases {
+ k = "/m at 1248";
+ l: m at 1248 {
+ n = <0xdeadbeef 0x12345678>;
+ o {
+ p;
+ q {
+ r = "s";
+ t {
+ u = <&l>;
diff --git a/testsuites/libtests/openfirmware01/some.h b/testsuites/libtests/openfirmware01/some.h
index 0000000000..e2e0135e68
--- /dev/null
+++ b/testsuites/libtests/openfirmware01/some.h
@@ -0,0 +1,15 @@
+ * Extern declarations for C structure representing binary file some.bin
+#ifndef __some_h
+#define __some_h
+extern const unsigned char some_bin[];
+extern const size_t some_bin_size;
+#endif
2.17.1
