[PATCH RTEMS 7/7] libtests/openfirmware: Added a testsuite for openfirmware
Wed Jul 29 16:07:16 UTC 2020
On Wed, Jul 15, 2020 at 12:32 AM G S Niteesh Babu <niteesh.gs at gmail.com> wrote:
>  spec/build/testsuites/libtests/grp.yml        |   3 +
>  .../testsuites/libtests/openfirmware01.yml    |  20 +++
>  testsuites/libtests/openfirmware01/init.c     | 147 ++++++++++++++++++
>  .../openfirmware01/openfirmware01.doc         |  29 ++++
>  .../openfirmware01/openfirmware01.scn         |   2 +
>  testsuites/libtests/openfirmware01/some.c     |  52 +++++++
>  testsuites/libtests/openfirmware01/some.dts   |  54 +++++++
>  testsuites/libtests/openfirmware01/some.h     |  15 ++
>  8 files changed, 322 insertions(+)
>  create mode 100644 spec/build/testsuites/libtests/openfirmware01.yml
>  create mode 100644 testsuites/libtests/openfirmware01/init.c
>  create mode 100644 testsuites/libtests/openfirmware01/openfirmware01.doc
>  create mode 100644 testsuites/libtests/openfirmware01/openfirmware01.scn
>  create mode 100644 testsuites/libtests/openfirmware01/some.c
>  create mode 100644 testsuites/libtests/openfirmware01/some.dts
>  create mode 100644 testsuites/libtests/openfirmware01/some.h
> diff --git a/spec/build/testsuites/libtests/grp.yml b/spec/build/testsuites/libtests/grp.yml
> index f1de6cd75f..56e84d2c89 100644
> --- a/spec/build/testsuites/libtests/grp.yml
> +++ b/spec/build/testsuites/libtests/grp.yml
> @@ -11,6 +11,7 @@ install: []
>  ldflags:
>  - -Wl,--wrap=printf
>  - -Wl,--wrap=puts
> +- -Wl,--wrap=bsp_fdt_get
>  links:
>  - role: build-dependency
>    uid: optbin2c
> @@ -312,6 +313,8 @@ links:
>    uid: write
>    uid: writev
> +- role: build-dependency
> +  uid: openfirmware01
>  type: build
>  use-after:
>  - rtemstest
> diff --git a/spec/build/testsuites/libtests/openfirmware01.yml b/spec/build/testsuites/libtests/openfirmware01.yml
> new file mode 100644
> index 0000000000..8feb69eb1e
> --- /dev/null
> +++ b/spec/build/testsuites/libtests/openfirmware01.yml
> @@ -0,0 +1,20 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: test-program
> +cflags: []
> +copyrights:
> +- Copyright (C) 2020 Niteesh G S
> +cppflags: []
> +cxxflags: []
> +enabled-by: true
> +features: c cprogram
> +includes: []
> +ldflags: []
> +links: []
> +source:
> +- testsuites/libtests/openfirmware01/init.c
> +- testsuites/libtests/openfirmware01/some.c
> +stlib: []
> +target: testsuites/libtests/openfirmware01.exe
> +type: build
> +use-after: []
> +use-before: []
> diff --git a/testsuites/libtests/openfirmware01/init.c b/testsuites/libtests/openfirmware01/init.c
> index 0000000000..fc38e6c513
> --- /dev/null
> +++ b/testsuites/libtests/openfirmware01/init.c
> @@ -0,0 +1,147 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * Copyright (C) <2020> Niteesh G S <niteesh.gs at gmail.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <tmacros.h>
> +#include <stdio.h>
> +#include <stdlib.h>
> +#include <libfdt.h>
> +#include <sys/endian.h>
> +#include <dev/ofw/openfirm.h>
> +#include "some.h"
> +#define BUF_SIZE 100
> +const char rtems_test_name[] = "OpenFirmWare 01";
> +const void *__wrap_bsp_fdt_get(void);
> +const void *__real_bsp_fdt_get(void);
> +    if (some_bin != NULL) {
> +        return &some_bin[0];
> +    return __real_bsp_fdt_get();
> +static void Init(rtems_task_argument arg)
> +    int rv;
> +    phandle_t d;
> +    phandle_t l;
> +    phandle_t t;
> +    phandle_t root;
> +    phandle_t temp;
> +    uint32_t *arr;
> +    char buf[BUF_SIZE];
> +    char *bufp;
> +    ssize_t buf_len;
> +    TEST_BEGIN();
> +    buf_len = sizeof(buf);
> +     * Cannot use fdt_path_offset to compare because
> +     * the OF interface uses the offset from the ftdp
> +     * to the node as phandle.
> +    root = OF_finddevice("/");
> +    rtems_test_assert(root == 56);
> +    root = OF_peer(0);
> +    d = OF_child(root);
> +    temp = OF_finddevice("/d");
> +    rtems_test_assert(d == temp);
> +    temp = OF_parent(d);
> +    rtems_test_assert(root == temp);
> +    rv = OF_getprop(d, "e", buf, buf_len);
> +    rtems_test_assert(rv != -1);
> +    rtems_test_assert(strcmp(buf, "f") == 0);
> +    rv = OF_hasprop(d, "g");
> +    rtems_test_assert(rv == 1);
> +    rv = OF_getproplen(root, "model");
> +    rtems_test_assert(rv == 2);
> +    rv = OF_nextprop(d, "e", buf, buf_len);
> +    rtems_test_assert(strcmp(buf, "g") == 0);
> +    l = OF_finddevice("/m at 1248");
> +    rv = OF_searchprop(l, "model", buf, buf_len);
> +    rtems_test_assert(strcmp(buf, "c") == 0);
> +    rv = OF_getprop_alloc(root, "compatible", (void **)&bufp);
> +    rtems_test_assert(strcmp(bufp, "a,b") == 0);
> +    OF_prop_free(bufp);
> +    rv = OF_getprop_alloc_multi(l, "n", sizeof(*arr), (void **)&arr);
> +    rtems_test_assert(arr[0] == htobe32(0xdeadbeef));
> +    rtems_test_assert(arr[1] == htobe32(0x12345678));
> +    rv = OF_getencprop_alloc_multi(l, "n", sizeof(*arr), (void **)&arr);
> +    rtems_test_assert(arr[0] == 0xdeadbeef);
> +    rtems_test_assert(arr[1] == 0x12345678);
> +    t = OF_finddevice("/t");
> +    rv = OF_nextprop(t, "u", buf, buf_len);
> +    rtems_test_assert(rv == 0);
ok, so these are intended to be application-visible. The interface is
not standard though, as far as I know. So, I think we need to ensure
we provide an RTEMS-friendly namespace for this OF API, and make sure
the header files are properly arranged for visibility/layering.
Everything else seems fine to me in a quick glance.
> +    TEST_END();
> +    rtems_test_exit(0);
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS 1
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#include <rtems/confdefs.h>
> \ No newline at end of file
> diff --git a/testsuites/libtests/openfirmware01/openfirmware01.doc b/testsuites/libtests/openfirmware01/openfirmware01.doc
> index 0000000000..a9d2085798
> --- /dev/null
> +++ b/testsuites/libtests/openfirmware01/openfirmware01.doc
> @@ -0,0 +1,29 @@
> +This file describes the directives and concepts tested by this test set.
> +test set name: openfirmware01
> +directives:
> +  - OF_peer
> +  - OF_child
> +  - OF_parent
> +  - OF_getproplen
> +  - OF_getprop
> +  - OF_getencprop
> +  - OF_hasprop
> +  - OF_searchprop
> +  - OF_searchencprop
> +  - OF_getprop_alloc
> +  - OF_getprop_alloc_multi
> +  - OF_getencprop_alloc
> +  - OF_getencprop_alloc_multi
> +  - OF_prop_free
> +  - OF_nextprop
> +  - OF_setprop
> +  - OF_canon
> +  - OF_finddevice
> +  - OF_package_to_path
> +concepts:
> +  - Ensure that some openfimware functions work as expected.
> diff --git a/testsuites/libtests/openfirmware01/openfirmware01.scn b/testsuites/libtests/openfirmware01/openfirmware01.scn
> index 0000000000..38abbdfc45
> --- /dev/null
> +++ b/testsuites/libtests/openfirmware01/openfirmware01.scn
> @@ -0,0 +1,2 @@
> +*** BEGIN OF TEST OPENFIRMWARE 1 ***
> +*** END OF TEST OPENFIRMWARE 1 ***
> diff --git a/testsuites/libtests/openfirmware01/some.c b/testsuites/libtests/openfirmware01/some.c
> index 0000000000..5eed911204
> --- /dev/null
> +++ b/testsuites/libtests/openfirmware01/some.c
> @@ -0,0 +1,52 @@
> + *  Declarations for C structure representing binary file some.bin
> + *  WARNING: Automatically generated -- do not edit!
> +#include <sys/types.h>
> +const unsigned char some_bin[] = {
> +  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x01, 0xd8, 0x00, 0x00, 0x00, 0x38,
> +  0x00, 0x00, 0x01, 0x90, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
> +  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x48,
> +  0x00, 0x00, 0x01, 0x58, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x00, 0x61, 0x2c, 0x62, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x01,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x1a,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x26, 0x63, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
> +  0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x09, 0x66, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
> +  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x2c, 0x00, 0x00, 0x00, 0x01,
> +  0x68, 0x40, 0x30, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> +  0x68, 0x40, 0x31, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x00, 0x7b, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x61, 0x6c, 0x69, 0x61,
> +  0x73, 0x65, 0x73, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
> +  0x00, 0x00, 0x00, 0x30, 0x2f, 0x6d, 0x40, 0x31, 0x32, 0x34, 0x38, 0x00,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x6d, 0x40, 0x31, 0x32,
> +  0x34, 0x38, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
> +  0x00, 0x00, 0x00, 0x32, 0xde, 0xad, 0xbe, 0xef, 0x12, 0x34, 0x56, 0x78,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x34,
> +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
> +  0x00, 0x00, 0x00, 0x3a, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x01,
> +  0x6f, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x42, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
> +  0x71, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x44, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x74, 0x00, 0x00, 0x00,
> +  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x46,
> +  0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
> +  0x00, 0x00, 0x00, 0x09, 0x63, 0x6f, 0x6d, 0x70, 0x61, 0x74, 0x69, 0x62,
> +  0x6c, 0x65, 0x00, 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73, 0x2d,
> +  0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x23, 0x73, 0x69, 0x7a, 0x65, 0x2d,
> +  0x63, 0x65, 0x6c, 0x6c, 0x73, 0x00, 0x6d, 0x6f, 0x64, 0x65, 0x6c, 0x00,
> +  0x67, 0x00, 0x77, 0x00, 0x6b, 0x00, 0x6e, 0x00, 0x6c, 0x69, 0x6e, 0x75,
> +  0x78, 0x2c, 0x70, 0x68, 0x61, 0x6e, 0x64, 0x6c, 0x65, 0x00, 0x70, 0x00,
> +  0x72, 0x00, 0x75, 0x00,
> +const size_t some_bin_size = sizeof(some_bin);
> diff --git a/testsuites/libtests/openfirmware01/some.dts b/testsuites/libtests/openfirmware01/some.dts
> index 0000000000..ac15825b17
> --- /dev/null
> +++ b/testsuites/libtests/openfirmware01/some.dts
> @@ -0,0 +1,54 @@
> + * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
> + *  embedded brains GmbH
> + *  Dornierstr. 4
> + *  82178 Puchheim
> + *  Germany
> + *  <rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.org/license/LICENSE.
> +/dts-v1/;
> +       compatible = "a,b";
> +       #address-cells = <1>;
> +       #size-cells = <2>;
> +       model = "c";
> +       d {
> +               e = "f";
> +               g;
> +               h at 0 {
> +               h at 1 {
> +                       w = <123>;
> +       aliases {
> +               k = "/m at 1248";
> +       l: m at 1248 {
> +               n = <0xdeadbeef 0x12345678>;
> +               o {
> +                       p;
> +               q {
> +                       r = "s";
> +       t {
> +               u = <&l>;
> diff --git a/testsuites/libtests/openfirmware01/some.h b/testsuites/libtests/openfirmware01/some.h
> index 0000000000..e2e0135e68
> --- /dev/null
> +++ b/testsuites/libtests/openfirmware01/some.h
> @@ -0,0 +1,15 @@
> + *  Extern declarations for C structure representing binary file some.bin
> +#ifndef __some_h
> +#define __some_h
> +extern const unsigned char some_bin[];
> +extern const size_t some_bin_size;
> +#endif
> 2.17.1
