[GSoC 2020]: Weekly thread update
Heinz Junkes junkes at fhi-berlin.mpg.de
Wed Jul 15 14:18:11 UTC 2020
Hello, Mritunjay,
I'm afraid I've lost track of the situation. I am also still on holiday in Norway for 2 weeks and
I don't always have perfect internet access.
Where can I find your blog. I only found something from June 9th. What is the current location of the blog?
I'm afraid you've made a mess of things here.
In the "official" epics repo, you can read
https://github.com/epics-base/epics-base/blob/7.0/modules/libcom/RTEMS/rtems_init.c :
#include <rtems/stackchk.h>
#include <rtems/imfs.h>
#include <librtemsNfs.h>
#include <bsp.h>
Here the definition of the legacy stack will be included
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> On 15. Jul 2020, at 05:57, Mritunjay Sharma <mritunjaysharma394 at gmail.com> wrote:
> On Wed, Jul 15, 2020 at 5:33 AM Chris Johns <chrisj at rtems.org> wrote:
> On 15/7/20 4:30 am, Mritunjay Sharma wrote:
> > Hello everyone,
> > Pardon my mistake for that long thread. From now on the daily updates will be
> > given on a thread that will end every week.
> Thank you :)
> > 1) I studied about https://github.com/RTEMS/rtems-libbsd
> > 2) Tried to fix the error that I reported yesterday:
> Why cut the compile command line used to build this file out of the message? The
> compiler command is important because it lets us see what paths are being used
> and I think there may be a problem with them.
> > ../posix/rtems_init.c:38:10: fatal error: rtems/bsd/bsd.h: No such file or directory
> >  #include <rtems/bsd/bsd.h>
> I cannot duplicate this because I am not sure what the sequence of commands are
> you used to get to here. I am sorry if I missed it in a previous post.
> The error indicates a set up issue. It normally means the networking software
> (rtems-libbsd) has not been installed into a prefix path EPICS looks in.
> I am posting the entire command set further ahead in the email which will make things
> easier to understand.
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200715/9b9195ec/attachment-0001.bin>
