[GSoC 2020]: Weekly thread update
Mritunjay Sharma mritunjaysharma394 at gmail.com
Wed Jul 15 20:04:56 UTC 2020
Apologies as I mistakenly sent this as a private mail.
I missed to tag Chris, Gedare and RTEMS Devel and that's why sending this
again on what
I responded.
On Wed, Jul 15, 2020 at 10:35 PM Mritunjay Sharma <
mritunjaysharma394 at gmail.com> wrote:
> On Wed, Jul 15, 2020 at 7:48 PM Heinz Junkes <junkes at fhi-berlin.mpg.de>
> wrote:
>> Hello, Mritunjay,
>> I'm afraid I've lost track of the situation. I am also still on holiday
>> in Norway for 2 weeks and
>> I don't always have perfect internet access.
This:->
> I am extremely sorry to disturb you on a holiday. I will try to bring back
> to you where we currently are:
> As advised by you I already have Built EPICS 7 with RTEMS 4.10 and tested
> it as well.
> I was doing the same for EPICS7 with RTEMS5 for pc-386. I apologise that I
> forgot to update the thread that the suggestion
> presented by Gedare to change to  `#include <rtems/bsd.h>` from existing `#include
> <rtems/bsd/bsd.h>` helped me
> fixed the error mentioned in the start of the thread ("../posix/rtems_init.c:38:10:
> fatal error: rtems/bsd/bsd.h: No such file or directory
>  #include <rtems/bsd/bsd.h>").
> I used the 'make' command again then inside `epics-base` (Downloaded from
> your GitHub's playground) and then got the
> following error:
> `../posix/rtems_init.c:39:10: fatal error: rtems/dhcpcd.h: No such file or
> directory
>  #include <rtems/dhcpcd.h>
> I discussed this with Gedare on the IRC channel and we concluded that it
> is there because we have to either
> use and build the old legacy stack using `--enable-networking` or the
> libbsd stack.
> I would like your advice on what should work here and how to approach
> doing each of these builds?
> Also, I again apologise that I am disturbing you on a holiday. Please
> enjoy and take care!
> Thanks
> Mritunjay
>> Where can I find your blog. I only found something from June 9th. What is
>> the current location of the blog?
This:->
> I have made another blog which as of now deals with building BSPs and I
> have to update the draft of another one
> which will further demonstrate on how to Build EPICS.
> The link to the blog is:
> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
>> I'm afraid you've made a mess of things here.
> This:-
> I am sorry if I have and I accept that I am a beginner but am really
> enjoying the learning I am making this summer.
> Thank you so much for the support everyone in helping me grow and learn.
> Thanks
> Mritunjay
>> In the "official" epics repo, you can read
>> https://github.com/epics-base/epics-base/blob/7.0/modules/libcom/RTEMS/rtems_init.c
>> #include <rtems/stackchk.h>
>> #include <rtems/rtems_bsdnet.h>
>> #include <rtems/imfs.h>
>> #include <librtemsNfs.h>
>> #include <bsp.h>
>> Here the definition of the legacy stack will be included
>> Viele Grüße
>> Heinz Junkes
>> Experience directly varies with equipment ruined.
>> > On 15. Jul 2020, at 05:57, Mritunjay Sharma <
>> > On Wed, Jul 15, 2020 at 5:33 AM Chris Johns <chrisj at rtems.org> wrote:
>> > On 15/7/20 4:30 am, Mritunjay Sharma wrote:
>> > > Hello everyone,
>> > > Pardon my mistake for that long thread. From now on the daily updates
>> will be
>> > > given on a thread that will end every week.
>> > Thank you :)
>> > > 1) I studied about https://github.com/RTEMS/rtems-libbsd
>> > > 2) Tried to fix the error that I reported yesterday:
>> > Why cut the compile command line used to build this file out of the
>> message? The
>> > compiler command is important because it lets us see what paths are
>> being used
>> > and I think there may be a problem with them.
>> > > ../posix/rtems_init.c:38:10: fatal error: rtems/bsd/bsd.h: No such
>> file or directory
>> > I cannot duplicate this because I am not sure what the sequence of
>> commands are
>> > you used to get to here. I am sorry if I missed it in a previous post.
>> > The error indicates a set up issue. It normally means the networking
>> software
>> > (rtems-libbsd) has not been installed into a prefix path EPICS looks in.
>> > I am posting the entire command set further ahead in the email which
>> will make things
>> > easier to understand.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200716/3c535522/attachment.html>
