[PATCH rtems-libbsd 3/7] busdma: Option to round to cache lines on sync
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Jul 17 05:56:16 UTC 2020
Some targets support only flushing or invalidating complete cache lines.
In this cases misaligned buffers might lead to unexpected results. This
patch adds a flag that allows drivers to signal to the bus dma driver
that it is OK to round a buffer to the next full cache line. That's for
example necessary if a driver wants to send out 14 byte via a USB DMA.
Only the driver knows whether these 14 bytes are located in an otherwise
unused cache line aligned buffer.
 freebsd/sys/dev/usb/usb_busdma.c             | 31 ++++++++++++++++++++
 freebsd/sys/dev/usb/usb_busdma.h             |  5 ++++
 freebsd/sys/dev/usb/usb_transfer.c           | 20 +++++++++++++
 freebsd/sys/dev/usb/usbdi.h                  |  4 +++
 freebsd/sys/sys/bus_dma.h                    |  6 ++++
 rtemsbsd/include/machine/rtems-bsd-bus-dma.h |  3 ++
 rtemsbsd/rtems/rtems-kernel-bus-dma-mbuf.c   |  3 ++
 rtemsbsd/rtems/rtems-kernel-bus-dma.c        |  9 ++++++
 8 files changed, 81 insertions(+)
diff --git a/freebsd/sys/dev/usb/usb_busdma.c b/freebsd/sys/dev/usb/usb_busdma.c
index dc52fe15..b74f0823 100644
--- a/freebsd/sys/dev/usb/usb_busdma.c
+++ b/freebsd/sys/dev/usb/usb_busdma.c
@@ -67,6 +67,9 @@
 #include <dev/usb/usb_controller.h>
 #include <dev/usb/usb_bus.h>
 #endif			/* USB_GLOBAL_INCLUDE_FILE */
+#ifdef __rtems__
+#include <machine/rtems-bsd-cache.h>
+#endif /* __rtems__ */
 #if USB_HAVE_BUSDMA
 static void	usb_dma_tag_create(struct usb_dma_tag *, usb_size_t, usb_size_t);
@@ -543,6 +546,15 @@ usb_pc_alloc_mem(struct usb_page_cache *pc, struct usb_page *pg,
 	uptag = pc->tag_parent;
+#if defined(__rtems__) && defined(CPU_DATA_CACHE_ALIGNMENT)
+	while (align % CPU_DATA_CACHE_ALIGNMENT != 0) {
+		align *= 2;
+	if (size % CPU_DATA_CACHE_ALIGNMENT != 0) {
+		size = (size + (CPU_DATA_CACHE_ALIGNMENT - 1)) &
+		    ~(CPU_DATA_CACHE_ALIGNMENT - 1);
 	if (align != 1) {
 	         * The alignment must be greater or equal to the
@@ -605,7 +617,12 @@ usb_pc_alloc_mem(struct usb_page_cache *pc, struct usb_page *pg,
 	/* load memory into DMA */
 	err = bus_dmamap_load(
 	    utag->tag, map, ptr, size, &usb_pc_alloc_mem_cb,
+#if defined(__rtems__) && CPU_DATA_CACHE_ALIGNMENT
+	    pc, (BUS_DMA_WAITOK | BUS_DMA_COHERENT |
+	    BUS_DMA_DO_CACHE_LINE_BLOW_UP));
+#else /* __rtems__ */
 	    pc, (BUS_DMA_WAITOK | BUS_DMA_COHERENT));
 	if (err == EINPROGRESS) {
 		cv_wait(uptag->cv, uptag->mtx);
@@ -662,6 +679,12 @@ usb_pc_free_mem(struct usb_page_cache *pc)
 uint8_t
 usb_pc_load_mem(struct usb_page_cache *pc, usb_size_t size, uint8_t sync)
+#ifdef __rtems__
+	int flags;
+	flags = pc->dma_do_cache_line_blow_up ?
+	    BUS_DMA_DO_CACHE_LINE_BLOW_UP : 0;
 	/* setup page cache */
 	pc->page_offset_buf = 0;
 	pc->page_offset_end = size;
@@ -687,7 +710,11 @@ usb_pc_load_mem(struct usb_page_cache *pc, usb_size_t size, uint8_t sync)
 			    pc->tag, pc->map, pc->buffer, size,
+#ifndef __rtems__
 			    &usb_pc_alloc_mem_cb, pc, BUS_DMA_WAITOK);
+			    &usb_pc_alloc_mem_cb, pc, BUS_DMA_WAITOK | flags);
 				err = 0;
@@ -709,7 +736,11 @@ usb_pc_load_mem(struct usb_page_cache *pc, usb_size_t size, uint8_t sync)
 			if (bus_dmamap_load(
+#ifndef __rtems__
 			    &usb_pc_load_mem_cb, pc, BUS_DMA_WAITOK)) {
+			    &usb_pc_load_mem_cb, pc, BUS_DMA_WAITOK | flags)) {
 	} else {
diff --git a/freebsd/sys/dev/usb/usb_busdma.h b/freebsd/sys/dev/usb/usb_busdma.h
index d75e67ee..03eca30d 100644
--- a/freebsd/sys/dev/usb/usb_busdma.h
+++ b/freebsd/sys/dev/usb/usb_busdma.h
@@ -102,6 +102,11 @@ struct usb_page_cache {
 					 * from the memory. Else write. */
 	uint8_t	ismultiseg:1;		/* set if we can have multiple
 					 * segments */
+#ifdef __rtems__
+	uint8_t dma_do_cache_line_blow_up:1;
+					/* set if it is OK to align the buffer
+					 * start and end to next cache line */
 #endif
diff --git a/freebsd/sys/dev/usb/usb_transfer.c b/freebsd/sys/dev/usb/usb_transfer.c
index 3b67c20c..ee1e4c28 100644
--- a/freebsd/sys/dev/usb/usb_transfer.c
+++ b/freebsd/sys/dev/usb/usb_transfer.c
@@ -2195,6 +2195,9 @@ usbd_xfer_set_frame_data(struct usb_xfer *xfer, usb_frcount_t frindex,
 	/* set virtual address to load and length */
 	xfer->frbuffers[frindex].buffer = ptr;
 	usbd_xfer_set_frame_len(xfer, frindex, len);
+#ifdef __rtems__
+	xfer->frbuffers[frindex].dma_do_cache_line_blow_up = 0;
 void
@@ -2209,6 +2212,23 @@ usbd_xfer_frame_data(struct usb_xfer *xfer, usb_frcount_t frindex,
 		*len = xfer->frlengths[frindex];
+#ifdef __rtems__
+ *	usbd_xfer_frame_allow_cache_line_blow_up
+ * Set a flag that the buffer start and end belonging to this frame can be
+ * aligned to the next cache line on sync and flush.
+void
+usbd_xfer_frame_allow_cache_line_blow_up(struct usb_xfer *xfer,
+    usb_frcount_t frindex)
+	KASSERT(frindex < xfer->max_frame_count, ("frame index overflow"));
+	xfer->frbuffers[frindex].dma_do_cache_line_blow_up = 1;
  *	usbd_xfer_old_frame_length
diff --git a/freebsd/sys/dev/usb/usbdi.h b/freebsd/sys/dev/usb/usbdi.h
index 0a393844..834810a8 100644
--- a/freebsd/sys/dev/usb/usbdi.h
+++ b/freebsd/sys/dev/usb/usbdi.h
@@ -640,6 +640,10 @@ void	usbd_xfer_set_frame_data(struct usb_xfer *xfer, usb_frcount_t frindex,
 	    void *ptr, usb_frlength_t len);
 void	usbd_xfer_frame_data(struct usb_xfer *xfer, usb_frcount_t frindex,
 	    void **ptr, int *len);
+#ifdef __rtems__
+void	usbd_xfer_frame_allow_cache_line_blow_up(struct usb_xfer *xfer,
+	    usb_frcount_t frindex);
 void	usbd_xfer_set_frame_offset(struct usb_xfer *xfer, usb_frlength_t offset,
 usb_frlength_t usbd_xfer_max_len(struct usb_xfer *xfer);
diff --git a/freebsd/sys/sys/bus_dma.h b/freebsd/sys/sys/bus_dma.h
index e99d8ece..d5a08be0 100644
--- a/freebsd/sys/sys/bus_dma.h
+++ b/freebsd/sys/sys/bus_dma.h
@@ -107,6 +107,12 @@
 #define	BUS_DMA_KEEP_PG_OFFSET	0x400
 #define	BUS_DMA_LOAD_MBUF	0x800
+#ifdef __rtems__
+ * Hint that the start address and size can be aligned to the next cache line.
+#define BUS_DMA_DO_CACHE_LINE_BLOW_UP	0x80000000
 /* Forwards needed by prototypes below. */
 union ccb;
diff --git a/rtemsbsd/include/machine/rtems-bsd-bus-dma.h b/rtemsbsd/include/machine/rtems-bsd-bus-dma.h
index ac970537..e9566882 100644
--- a/rtemsbsd/include/machine/rtems-bsd-bus-dma.h
+++ b/rtemsbsd/include/machine/rtems-bsd-bus-dma.h
@@ -75,6 +75,9 @@ struct bus_dma_tag {
 struct bus_dmamap {
 	void *buffer_begin;
 	bus_size_t buffer_size;
+	int flags;
+/* OK to flush / invalidate the complete cache line */
+#define DMAMAP_CACHE_ALIGNED	(1 << 0)
 int
diff --git a/rtemsbsd/rtems/rtems-kernel-bus-dma-mbuf.c b/rtemsbsd/rtems/rtems-kernel-bus-dma-mbuf.c
index c435fd74..56ead4ee 100644
--- a/rtemsbsd/rtems/rtems-kernel-bus-dma-mbuf.c
+++ b/rtemsbsd/rtems/rtems-kernel-bus-dma-mbuf.c
@@ -69,6 +69,9 @@ bus_dmamap_load_mbuf(bus_dma_tag_t dmat, bus_dmamap_t map,
 		int first = 1;
 		bus_addr_t lastaddr = 0;
 		struct mbuf *m;
+		if ((flags & BUS_DMA_LOAD_MBUF) != 0) {
+			map->flags |= DMAMAP_CACHE_ALIGNED;
 		for (m = m0; m != NULL && error == 0; m = m->m_next) {
 			if (m->m_len > 0) {
diff --git a/rtemsbsd/rtems/rtems-kernel-bus-dma.c b/rtemsbsd/rtems/rtems-kernel-bus-dma.c
index 8c15e92b..4dc634f3 100644
--- a/rtemsbsd/rtems/rtems-kernel-bus-dma.c
+++ b/rtemsbsd/rtems/rtems-kernel-bus-dma.c
@@ -365,9 +365,13 @@ bus_dmamap_load(bus_dma_tag_t dmat, bus_dmamap_t map, void *buf,
 	map->buffer_begin = buf;
 	map->buffer_size = buflen;
+	if ((flags & BUS_DMA_DO_CACHE_LINE_BLOW_UP) != 0) {
 	lastaddr = (vm_offset_t)0;
 	nsegs = 0;
 	error = bus_dmamap_load_buffer(dmat, dm_segments, buf, buflen,
 	    NULL, flags, &lastaddr, &nsegs, 1);
@@ -397,6 +401,11 @@ bus_dmamap_sync(bus_dma_tag_t dmat, bus_dmamap_t map, bus_dmasync_op_t op)
 	uintptr_t begin = (uintptr_t) map->buffer_begin;
 	uintptr_t end = begin + size;
+	if ((map->flags & DMAMAP_CACHE_ALIGNED) != 0) {
+		begin &= ~CLMASK;
+		end = (end + CLMASK) & ~CLMASK;
+		size = end - begin;
 	if ((op & BUS_DMASYNC_PREWRITE) != 0 && (op & BUS_DMASYNC_PREREAD) == 0) {
 		rtems_cache_flush_multiple_data_lines((void *) begin, size);
2.26.2
