[PATCH rtems-libbsd 2/7] imx: Use RTEMS GPIO driver instead of FreeBSD one.
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Jul 17 05:56:15 UTC 2020
 freebsd/sys/arm/freescale/imx/imx_gpio.c      | 914 ------------------
 libbsd.py                                     |   2 +-
 rtemsbsd/include/bsp/nexus-devices.h          |   2 +-
 .../sys/arm/freescale/imx/imx_rtems_gpio.c    | 306 ++++++
 4 files changed, 308 insertions(+), 916 deletions(-)
 delete mode 100644 freebsd/sys/arm/freescale/imx/imx_gpio.c
 create mode 100644 rtemsbsd/sys/arm/freescale/imx/imx_rtems_gpio.c
diff --git a/freebsd/sys/arm/freescale/imx/imx_gpio.c b/freebsd/sys/arm/freescale/imx/imx_gpio.c
deleted file mode 100644
index c33205c2..00000000
--- a/freebsd/sys/arm/freescale/imx/imx_gpio.c
+++ /dev/null
@@ -1,914 +0,0 @@
-#include <machine/rtems-bsd-kernel-space.h>
- * Copyright (c) 2012, 2013 The FreeBSD Foundation
- * All rights reserved.
- * This software was developed by Oleksandr Rybalko under sponsorship
- * from the FreeBSD Foundation.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1.	Redistributions of source code must retain the above copyright
- *	notice, this list of conditions and the following disclaimer.
- * 2.	Redistributions in binary form must reproduce the above copyright
- *	notice, this list of conditions and the following disclaimer in the
- *	documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * Freescale i.MX515 GPIO driver.
-#include <sys/cdefs.h>
-__FBSDID("$FreeBSD$");
-#include <rtems/bsd/local/opt_platform.h>
-#include <sys/param.h>
-#include <sys/systm.h>
-#include <sys/bus.h>
-#include <sys/kernel.h>
-#include <sys/module.h>
-#include <sys/rman.h>
-#include <sys/lock.h>
-#include <sys/mutex.h>
-#include <sys/gpio.h>
-#include <sys/proc.h>
-#include <machine/bus.h>
-#include <machine/intr.h>
-#include <machine/resource.h>
-#include <dev/gpio/gpiobusvar.h>
-#include <dev/ofw/openfirm.h>
-#include <dev/ofw/ofw_bus.h>
-#include <dev/ofw/ofw_bus_subr.h>
-#include <rtems/bsd/local/gpio_if.h>
-#ifdef INTRNG
-#include <rtems/bsd/local/pic_if.h>
-#endif
-#define	WRITE4(_sc, _r, _v)						\
-	    bus_space_write_4((_sc)->sc_iot, (_sc)->sc_ioh, (_r), (_v))
-#define	READ4(_sc, _r)							\
-	    bus_space_read_4((_sc)->sc_iot, (_sc)->sc_ioh, (_r))
-#define	SET4(_sc, _r, _m)						\
-	    WRITE4((_sc), (_r), READ4((_sc), (_r)) | (_m))
-#define	CLEAR4(_sc, _r, _m)						\
-	    WRITE4((_sc), (_r), READ4((_sc), (_r)) & ~(_m))
-/* Registers definition for Freescale i.MX515 GPIO controller */
-#define	IMX_GPIO_DR_REG		0x000 /* Pin Data */
-#define	IMX_GPIO_OE_REG		0x004 /* Set Pin Output */
-#define	IMX_GPIO_PSR_REG	0x008 /* Pad Status */
-#define	IMX_GPIO_ICR1_REG	0x00C /* Interrupt Configuration */
-#define	IMX_GPIO_ICR2_REG	0x010 /* Interrupt Configuration */
-#define		GPIO_ICR_COND_LOW	0
-#define		GPIO_ICR_COND_HIGH	1
-#define		GPIO_ICR_COND_RISE	2
-#define		GPIO_ICR_COND_FALL	3
-#define		GPIO_ICR_COND_MASK	0x3
-#define	IMX_GPIO_IMR_REG	0x014 /* Interrupt Mask Register */
-#define	IMX_GPIO_ISR_REG	0x018 /* Interrupt Status Register */
-#define	IMX_GPIO_EDGE_REG	0x01C /* Edge Detect Register */
-#ifdef INTRNG
-#define	DEFAULT_CAPS	(GPIO_PIN_INPUT | GPIO_PIN_OUTPUT | \
-    GPIO_INTR_LEVEL_LOW | GPIO_INTR_LEVEL_HIGH | GPIO_INTR_EDGE_RISING | \
-    GPIO_INTR_EDGE_FALLING | GPIO_INTR_EDGE_BOTH)
-#else
-#define	DEFAULT_CAPS	(GPIO_PIN_INPUT | GPIO_PIN_OUTPUT)
-#endif
-#define	NGPIO		32
-#ifdef INTRNG
-struct gpio_irqsrc {
-	struct intr_irqsrc	gi_isrc;
-	u_int			gi_irq;
-	uint32_t		gi_mode;
-#endif
-struct imx51_gpio_softc {
-	device_t		dev;
-	device_t		sc_busdev;
-	struct mtx		sc_mtx;
-	struct resource		*sc_res[3]; /* 1 x mem, 2 x IRQ */
-	void			*gpio_ih[2];
-	bus_space_tag_t		sc_iot;
-	bus_space_handle_t	sc_ioh;
-	int			gpio_npins;
-	struct gpio_pin		gpio_pins[NGPIO];
-#ifdef INTRNG
-	struct gpio_irqsrc 	gpio_pic_irqsrc[NGPIO];
-#endif
-static struct ofw_compat_data compat_data[] = {
-#ifdef __rtems__
-	{"fsl,imx35-gpio",  1},
-	{"fsl,imx7d-gpio",  1},
-#endif /* __rtems__ */
-	{"fsl,imx6q-gpio",  1},
-	{"fsl,imx53-gpio",  1},
-	{"fsl,imx51-gpio",  1},
-	{NULL,	            0}
-static struct resource_spec imx_gpio_spec[] = {
-	{ SYS_RES_MEMORY,	0,	RF_ACTIVE },
-	{ SYS_RES_IRQ,		0,	RF_ACTIVE },
-	{ SYS_RES_IRQ,		1,	RF_ACTIVE },
-	{ -1, 0 }
-#define	FIRST_IRQRES	1
-#define	NUM_IRQRES	2
- * Helpers
-static void imx51_gpio_pin_configure(struct imx51_gpio_softc *,
-    struct gpio_pin *, uint32_t);
- * Driver stuff
-static int imx51_gpio_probe(device_t);
-static int imx51_gpio_attach(device_t);
-static int imx51_gpio_detach(device_t);
- * GPIO interface
-static device_t imx51_gpio_get_bus(device_t);
-static int imx51_gpio_pin_max(device_t, int *);
-static int imx51_gpio_pin_getcaps(device_t, uint32_t, uint32_t *);
-static int imx51_gpio_pin_getflags(device_t, uint32_t, uint32_t *);
-static int imx51_gpio_pin_getname(device_t, uint32_t, char *);
-static int imx51_gpio_pin_setflags(device_t, uint32_t, uint32_t);
-static int imx51_gpio_pin_set(device_t, uint32_t, unsigned int);
-static int imx51_gpio_pin_get(device_t, uint32_t, unsigned int *);
-static int imx51_gpio_pin_toggle(device_t, uint32_t pin);
-#ifdef INTRNG
-static int
-gpio_pic_map_fdt(struct imx51_gpio_softc *sc, struct intr_map_data_fdt *daf,
-    u_int *irqp, uint32_t *modep)
-	u_int irq;
-	uint32_t mode;
-	 * From devicetree/bindings/gpio/fsl-imx-gpio.txt:
-	 *  #interrupt-cells:  2. The first cell is the GPIO number. The second
-	 *  cell bits[3:0] is used to specify trigger type and level flags:
-	 *    1 = low-to-high edge triggered.
-	 *    2 = high-to-low edge triggered.
-	 *    4 = active high level-sensitive.
-	 *    8 = active low level-sensitive.
-	 * We can do any single one of these modes, and also edge low+high
-	 * (i.e., trigger on both edges); other combinations are not supported.
-	if (daf->ncells != 2) {
-		device_printf(sc->dev, "Invalid #interrupt-cells\n");
-		return (EINVAL);
-	irq = daf->cells[0];
-	if (irq >= sc->gpio_npins) {
-		device_printf(sc->dev, "Invalid interrupt number %u\n", irq);
-		return (EINVAL);
-	switch (daf->cells[1]) {
-	case 1:
-		mode = GPIO_INTR_EDGE_RISING;
-		break;
-	case 2:
-		mode = GPIO_INTR_EDGE_FALLING;
-		break;
-	case 3:
-		mode = GPIO_INTR_EDGE_BOTH;
-		break;
-	case 4:
-		mode = GPIO_INTR_LEVEL_HIGH;
-		break;
-	case 8:
-		mode = GPIO_INTR_LEVEL_LOW;
-		break;
-	default:
-		device_printf(sc->dev, "Unsupported interrupt mode 0x%2x\n",
-		    daf->cells[1]);
-		return (ENOTSUP);
-	*irqp = irq;
-	if (modep != NULL)
-		*modep = mode;
-	return (0);
-static int
-gpio_pic_map_gpio(struct imx51_gpio_softc *sc, struct intr_map_data_gpio *dag,
-	u_int irq;
-	irq = dag->gpio_pin_num;
-		return (EINVAL);
-	switch (dag->gpio_intr_mode) {
-	case GPIO_INTR_LEVEL_LOW:
-	case GPIO_INTR_LEVEL_HIGH:
-	case GPIO_INTR_EDGE_RISING:
-	case GPIO_INTR_EDGE_FALLING:
-	case GPIO_INTR_EDGE_BOTH:
-		break;
-	default:
-		device_printf(sc->dev, "Unsupported interrupt mode 0x%8x\n",
-		    dag->gpio_intr_mode);
-		return (EINVAL);
-	*irqp = irq;
-		*modep = dag->gpio_intr_mode;
-	return (0);
-static int
-gpio_pic_map(struct imx51_gpio_softc *sc, struct intr_map_data *data,
-	switch (data->type) {
-	case INTR_MAP_DATA_FDT:
-		return (gpio_pic_map_fdt(sc, (struct intr_map_data_fdt *)data,
-		    irqp, modep));
-	case INTR_MAP_DATA_GPIO:
-		return (gpio_pic_map_gpio(sc, (struct intr_map_data_gpio *)data,
-		    irqp, modep));
-	default:
-		return (ENOTSUP);
-static int
-gpio_pic_map_intr(device_t dev, struct intr_map_data *data,
-    struct intr_irqsrc **isrcp)
-	int error;
-	u_int irq;
-	struct imx51_gpio_softc *sc;
-	sc = device_get_softc(dev);
-	error = gpio_pic_map(sc, data, &irq, NULL);
-	if (error == 0)
-		*isrcp = &sc->gpio_pic_irqsrc[irq].gi_isrc;
-	return (error);
-static int
-gpio_pic_teardown_intr(device_t dev, struct intr_irqsrc *isrc,
-    struct resource *res, struct intr_map_data *data)
-	struct gpio_irqsrc *gi;
-	if (isrc->isrc_handlers == 0) {
-		gi = (struct gpio_irqsrc *)isrc;
-		gi->gi_mode = GPIO_INTR_CONFORM;
-		// XXX Not sure this is necessary
-		mtx_lock_spin(&sc->sc_mtx);
-		CLEAR4(sc, IMX_GPIO_IMR_REG, (1U << gi->gi_irq));
-		WRITE4(sc, IMX_GPIO_ISR_REG, (1U << gi->gi_irq));
-		mtx_unlock_spin(&sc->sc_mtx);
-	return (0);
-static int
-gpio_pic_setup_intr(device_t dev, struct intr_irqsrc *isrc,
-	int error;
-	u_int icfg, irq, reg, shift, wrk;
-	uint32_t mode;
-	if (data == NULL)
-		return (ENOTSUP);
-	/* Get config for interrupt. */
-	error = gpio_pic_map(sc, data, &irq, &mode);
-	if (error != 0)
-		return (error);
-	if (gi->gi_irq != irq)
-		return (EINVAL);
-	/* Compare config if this is not first setup. */
-	if (isrc->isrc_handlers != 0)
-		return (gi->gi_mode == mode ? 0 : EINVAL);
-	gi->gi_mode = mode;
-	 * To interrupt on both edges we have to use the EDGE register.  The
-	 * manual says it only exists for backwards compatibilty with older imx
-	 * chips, but it's also the only way to configure interrupting on both
-	 * edges.  If the EDGE bit is on, the corresponding ICRn bit is ignored.
-	if (mode == GPIO_INTR_EDGE_BOTH) {
-		SET4(sc, IMX_GPIO_EDGE_REG, (1u << irq));
-	} else {
-		CLEAR4(sc, IMX_GPIO_EDGE_REG, (1u << irq));
-		switch (mode) {
-		default:
-			/* silence warnings; default can't actually happen. */
-			/* FALLTHROUGH */
-			icfg = GPIO_ICR_COND_LOW;
-			break;
-			icfg = GPIO_ICR_COND_HIGH;
-			break;
-			icfg = GPIO_ICR_COND_RISE;
-			break;
-			icfg = GPIO_ICR_COND_FALL;
-			break;
-		if (irq < 16) {
-			reg = IMX_GPIO_ICR1_REG;
-			shift = 2 * irq;
-		} else {
-			reg = IMX_GPIO_ICR2_REG;
-			shift = 2 * (irq - 16);
-		wrk = READ4(sc, reg);
-		wrk &= ~(GPIO_ICR_COND_MASK << shift);
-		wrk |= icfg << shift;
-		WRITE4(sc, reg, wrk);
-	WRITE4(sc, IMX_GPIO_ISR_REG, (1u << irq));
-	SET4(sc, IMX_GPIO_IMR_REG, (1u << irq));
-	return (0);
- * this is mask_intr
-static void
-gpio_pic_disable_intr(device_t dev, struct intr_irqsrc *isrc)
-	u_int irq;
-	irq = ((struct gpio_irqsrc *)isrc)->gi_irq;
-	CLEAR4(sc, IMX_GPIO_IMR_REG, (1U << irq));
- * this is unmask_intr
-static void
-gpio_pic_enable_intr(device_t dev, struct intr_irqsrc *isrc)
-	u_int irq;
-	SET4(sc, IMX_GPIO_IMR_REG, (1U << irq));
-static void
-gpio_pic_post_filter(device_t dev, struct intr_irqsrc *isrc)
-	u_int irq;
-	arm_irq_memory_barrier(0);
-        /* EOI.  W1C reg so no r-m-w, no locking needed. */
-	WRITE4(sc, IMX_GPIO_ISR_REG, (1U << irq));
-static void
-gpio_pic_post_ithread(device_t dev, struct intr_irqsrc *isrc)
-	u_int irq;
-	gpio_pic_enable_intr(dev, isrc);
-static void
-gpio_pic_pre_ithread(device_t dev, struct intr_irqsrc *isrc)
-	gpio_pic_disable_intr(dev, isrc);
-static int
-gpio_pic_filter(void *arg)
-	struct intr_irqsrc *isrc;
-	uint32_t i, interrupts;
-	sc = arg;
-	interrupts = READ4(sc, IMX_GPIO_ISR_REG) & READ4(sc, IMX_GPIO_IMR_REG);
-	for (i = 0; interrupts != 0; i++, interrupts >>= 1) {
-		if ((interrupts & 0x1) == 0)
-			continue;
-		isrc = &sc->gpio_pic_irqsrc[i].gi_isrc;
-		if (intr_isrc_dispatch(isrc, curthread->td_intr_frame) != 0) {
-			gpio_pic_disable_intr(sc->dev, isrc);
-			gpio_pic_post_filter(sc->dev, isrc);
-			device_printf(sc->dev, "Stray irq %u disabled\n", i);
-	return (FILTER_HANDLED);
- * Initialize our isrcs and register them with intrng.
-static int
-gpio_pic_register_isrcs(struct imx51_gpio_softc *sc)
-	int error;
-	uint32_t irq;
-	const char *name;
-	name = device_get_nameunit(sc->dev);
-	for (irq = 0; irq < NGPIO; irq++) {
-		sc->gpio_pic_irqsrc[irq].gi_irq = irq;
-		sc->gpio_pic_irqsrc[irq].gi_mode = GPIO_INTR_CONFORM;
-		error = intr_isrc_register(&sc->gpio_pic_irqsrc[irq].gi_isrc,
-		    sc->dev, 0, "%s,%u", name, irq);
-		if (error != 0) {
-			/* XXX call intr_isrc_deregister() */
-			device_printf(sc->dev, "%s failed", __func__);
-			return (error);
-	return (0);
-#endif
-static void
-imx51_gpio_pin_configure(struct imx51_gpio_softc *sc, struct gpio_pin *pin,
-    uint32_t flags)
-	u_int newflags, pad;
-	 * Manage input/output; other flags not supported yet (maybe not ever,
-	 * since we have no connection to the pad config registers from here).
-	 * When setting a pin to output, honor the PRESET_[LOW,HIGH] flags if
-	 * present.  Otherwise, for glitchless transistions on pins with pulls,
-	 * read the current state of the pad and preset the DR register to drive
-	 * the current value onto the pin before enabling the pin for output.
-	 * Note that changes to pin->gp_flags must be acccumulated in newflags
-	 * and stored with a single writeback to gp_flags at the end, to enable
-	 * unlocked reads of that value elsewhere. This is only about unlocked
-	 * access to gp_flags from elsewhere; we still use locking in this
-	 * function to protect r-m-w access to the hardware registers.
-	if (flags & (GPIO_PIN_INPUT | GPIO_PIN_OUTPUT)) {
-		newflags = pin->gp_flags & ~(GPIO_PIN_INPUT | GPIO_PIN_OUTPUT);
-		if (flags & GPIO_PIN_OUTPUT) {
-			if (flags & GPIO_PIN_PRESET_LOW) {
-				pad = 0;
-			} else if (flags & GPIO_PIN_PRESET_HIGH) {
-				pad = 1;
-			} else {
-				if (flags & GPIO_PIN_OPENDRAIN)
-					pad = READ4(sc, IMX_GPIO_PSR_REG);
-				else
-					pad = READ4(sc, IMX_GPIO_DR_REG);
-				pad = (pad >> pin->gp_pin) & 1;
-			newflags |= GPIO_PIN_OUTPUT;
-			SET4(sc, IMX_GPIO_DR_REG, (pad << pin->gp_pin));
-			SET4(sc, IMX_GPIO_OE_REG, (1U << pin->gp_pin));
-		} else {
-			newflags |= GPIO_PIN_INPUT;
-			CLEAR4(sc, IMX_GPIO_OE_REG, (1U << pin->gp_pin));
-		pin->gp_flags = newflags;
-static device_t
-imx51_gpio_get_bus(device_t dev)
-	return (sc->sc_busdev);
-static int
-imx51_gpio_pin_max(device_t dev, int *maxpin)
-	*maxpin = sc->gpio_npins - 1;
-	return (0);
-static int
-imx51_gpio_pin_getcaps(device_t dev, uint32_t pin, uint32_t *caps)
-	if (pin >= sc->gpio_npins)
-		return (EINVAL);
-	*caps = sc->gpio_pins[pin].gp_caps;
-	return (0);
-static int
-imx51_gpio_pin_getflags(device_t dev, uint32_t pin, uint32_t *flags)
-		return (EINVAL);
-	*flags = sc->gpio_pins[pin].gp_flags;
-	return (0);
-static int
-imx51_gpio_pin_getname(device_t dev, uint32_t pin, char *name)
-		return (EINVAL);
-	memcpy(name, sc->gpio_pins[pin].gp_name, GPIOMAXNAME);
-	return (0);
-static int
-imx51_gpio_pin_setflags(device_t dev, uint32_t pin, uint32_t flags)
-		return (EINVAL);
-	imx51_gpio_pin_configure(sc, &sc->gpio_pins[pin], flags);
-	return (0);
-static int
-imx51_gpio_pin_set(device_t dev, uint32_t pin, unsigned int value)
-		return (EINVAL);
-	if (value)
-		SET4(sc, IMX_GPIO_DR_REG, (1U << pin));
-	else
-		CLEAR4(sc, IMX_GPIO_DR_REG, (1U << pin));
-	return (0);
-static int
-imx51_gpio_pin_get(device_t dev, uint32_t pin, unsigned int *val)
-		return (EINVAL);
-	 * Normally a pin set for output can be read by reading the DR reg which
-	 * indicates what value is being driven to that pin.  The exception is
-	 * pins configured for open-drain mode, in which case we have to read
-	 * the pad status register in case the pin is being driven externally.
-	 * Doing so requires that the SION bit be configured in pinmux, which
-	 * isn't the case for most normal gpio pins, so only try to read via PSR
-	 * if the OPENDRAIN flag is set, and it's the user's job to correctly
-	 * configure SION along with open-drain output mode for those pins.
-	if (sc->gpio_pins[pin].gp_flags & GPIO_PIN_OPENDRAIN)
-		*val = (READ4(sc, IMX_GPIO_PSR_REG) >> pin) & 1;
-	else
-		*val = (READ4(sc, IMX_GPIO_DR_REG) >> pin) & 1;
-	return (0);
-static int
-imx51_gpio_pin_toggle(device_t dev, uint32_t pin)
-		return (EINVAL);
-	WRITE4(sc, IMX_GPIO_DR_REG,
-	    (READ4(sc, IMX_GPIO_DR_REG) ^ (1U << pin)));
-	return (0);
-static int
-imx51_gpio_pin_access_32(device_t dev, uint32_t first_pin, uint32_t clear_pins,
-    uint32_t change_pins, uint32_t *orig_pins)
-	if (first_pin != 0)
-		return (EINVAL);
-	if (orig_pins != NULL)
-		*orig_pins = READ4(sc, IMX_GPIO_DR_REG);
-	if ((clear_pins | change_pins) != 0) {
-		    (READ4(sc, IMX_GPIO_DR_REG) & ~clear_pins) ^ change_pins);
-	return (0);
-static int
-imx51_gpio_pin_config_32(device_t dev, uint32_t first_pin, uint32_t num_pins,
-    uint32_t *pin_flags)
-	u_int i;
-	uint32_t bit, drclr, drset, flags, oeclr, oeset, pads;
-	if (first_pin != 0 || num_pins > sc->gpio_npins)
-		return (EINVAL);
-	drclr = drset = oeclr = oeset = 0;
-	pads = READ4(sc, IMX_GPIO_DR_REG);
-	for (i = 0; i < num_pins; ++i) {
-		bit = 1u << i;
-		flags = pin_flags[i];
-		if (flags & GPIO_PIN_INPUT) {
-			oeclr |= bit;
-		} else if (flags & GPIO_PIN_OUTPUT) {
-			oeset |= bit;
-				drclr |= bit;
-			else if (flags & GPIO_PIN_PRESET_HIGH)
-				drset |= bit;
-			else /* Drive whatever it's now pulled to. */
-				drset |= pads & bit;
-	    (READ4(sc, IMX_GPIO_DR_REG) & ~drclr) | drset);
-	WRITE4(sc, IMX_GPIO_OE_REG,
-	    (READ4(sc, IMX_GPIO_OE_REG) & ~oeclr) | oeset);
-	return (0);
-static int
-imx51_gpio_probe(device_t dev)
-	if (!ofw_bus_status_okay(dev))
-		return (ENXIO);
-	if (ofw_bus_search_compatible(dev, compat_data)->ocd_data != 0) {
-		device_set_desc(dev, "Freescale i.MX GPIO Controller");
-		return (BUS_PROBE_DEFAULT);
-	return (ENXIO);
-static int
-imx51_gpio_attach(device_t dev)
-	int i, irq, unit;
-	sc->dev = dev;
-	sc->gpio_npins = NGPIO;
-	mtx_init(&sc->sc_mtx, device_get_nameunit(sc->dev), NULL, MTX_SPIN);
-	if (bus_alloc_resources(dev, imx_gpio_spec, sc->sc_res)) {
-		device_printf(dev, "could not allocate resources\n");
-		bus_release_resources(dev, imx_gpio_spec, sc->sc_res);
-		mtx_destroy(&sc->sc_mtx);
-		return (ENXIO);
-	sc->sc_iot = rman_get_bustag(sc->sc_res[0]);
-	sc->sc_ioh = rman_get_bushandle(sc->sc_res[0]);
-	 * Mask off all interrupts in hardware, then set up interrupt handling.
-	WRITE4(sc, IMX_GPIO_IMR_REG, 0);
-	for (irq = 0; irq < 2; irq++) {
-#ifdef INTRNG
-		if ((bus_setup_intr(dev, sc->sc_res[1 + irq], INTR_TYPE_CLK,
-		    gpio_pic_filter, NULL, sc, &sc->gpio_ih[irq]))) {
-			    "WARNING: unable to register interrupt handler\n");
-			imx51_gpio_detach(dev);
-			return (ENXIO);
-#endif
-	unit = device_get_unit(dev);
-	for (i = 0; i < sc->gpio_npins; i++) {
- 		sc->gpio_pins[i].gp_pin = i;
- 		sc->gpio_pins[i].gp_caps = DEFAULT_CAPS;
- 		sc->gpio_pins[i].gp_flags =
- 		    (READ4(sc, IMX_GPIO_OE_REG) & (1U << i)) ? GPIO_PIN_OUTPUT :
- 		    GPIO_PIN_INPUT;
- 		snprintf(sc->gpio_pins[i].gp_name, GPIOMAXNAME,
- 		    "GPIO%d_IO%02d", unit + 1, i);
-#ifdef INTRNG
-	gpio_pic_register_isrcs(sc);
-	intr_pic_register(dev, OF_xref_from_node(ofw_bus_get_node(dev)));
-#endif
-	sc->sc_busdev = gpiobus_attach_bus(dev);
-	if (sc->sc_busdev == NULL) {
-		return (ENXIO);
-	return (0);
-static int
-imx51_gpio_detach(device_t dev)
-	int irq;
-	gpiobus_detach_bus(dev);
-	for (irq = 0; irq < NUM_IRQRES; irq++) {
-		if (sc->gpio_ih[irq])
-			bus_teardown_intr(dev, sc->sc_res[irq + FIRST_IRQRES],
-			    sc->gpio_ih[irq]);
-	return(0);
-static device_method_t imx51_gpio_methods[] = {
-	DEVMETHOD(device_probe,		imx51_gpio_probe),
-	DEVMETHOD(device_attach,	imx51_gpio_attach),
-	DEVMETHOD(device_detach,	imx51_gpio_detach),
-#ifdef INTRNG
-	/* Interrupt controller interface */
-	DEVMETHOD(pic_disable_intr,	gpio_pic_disable_intr),
-	DEVMETHOD(pic_enable_intr,	gpio_pic_enable_intr),
-	DEVMETHOD(pic_map_intr,		gpio_pic_map_intr),
-	DEVMETHOD(pic_setup_intr,	gpio_pic_setup_intr),
-	DEVMETHOD(pic_teardown_intr,	gpio_pic_teardown_intr),
-	DEVMETHOD(pic_post_filter,	gpio_pic_post_filter),
-	DEVMETHOD(pic_post_ithread,	gpio_pic_post_ithread),
-	DEVMETHOD(pic_pre_ithread,	gpio_pic_pre_ithread),
-#endif
-	/* GPIO protocol */
-	DEVMETHOD(gpio_get_bus,		imx51_gpio_get_bus),
-	DEVMETHOD(gpio_pin_max,		imx51_gpio_pin_max),
-	DEVMETHOD(gpio_pin_getname,	imx51_gpio_pin_getname),
-	DEVMETHOD(gpio_pin_getflags,	imx51_gpio_pin_getflags),
-	DEVMETHOD(gpio_pin_getcaps,	imx51_gpio_pin_getcaps),
-	DEVMETHOD(gpio_pin_setflags,	imx51_gpio_pin_setflags),
-	DEVMETHOD(gpio_pin_get,		imx51_gpio_pin_get),
-	DEVMETHOD(gpio_pin_set,		imx51_gpio_pin_set),
-	DEVMETHOD(gpio_pin_toggle,	imx51_gpio_pin_toggle),
-	DEVMETHOD(gpio_pin_access_32,	imx51_gpio_pin_access_32),
-	DEVMETHOD(gpio_pin_config_32,	imx51_gpio_pin_config_32),
-	{0, 0},
-static driver_t imx51_gpio_driver = {
-	"gpio",
-	imx51_gpio_methods,
-	sizeof(struct imx51_gpio_softc),
-static devclass_t imx51_gpio_devclass;
-EARLY_DRIVER_MODULE(imx51_gpio, simplebus, imx51_gpio_driver,
-    imx51_gpio_devclass, 0, 0, BUS_PASS_INTERRUPT + BUS_PASS_ORDER_LATE);
diff --git a/libbsd.py b/libbsd.py
index aa940ab2..511de7af 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -673,7 +673,6 @@ class mmc_ti(builder.Module):
         self.addKernelSpaceSourceFiles(
-                'sys/arm/freescale/imx/imx_gpio.c',
                 'sys/arm/ti/ti_hwmods.c',
                 'sys/arm/ti/ti_sdhci.c',
                 'sys/dev/gpio/gpiobus.c',
@@ -688,6 +687,7 @@ class mmc_ti(builder.Module):
                 'local/sdhci_if.c',
                 'local/gpiobus_if.c',
+                'sys/arm/freescale/imx/imx_rtems_gpio.c',
             mm.generator['source']()
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index 89f78edf..92125619 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -146,7 +146,7 @@ RTEMS_BSD_DRIVER_USB_MASS;
 SYSINIT_DRIVER_REFERENCE(ffec, simplebus);
 SYSINIT_DRIVER_REFERENCE(ukphy, miibus);
-SYSINIT_DRIVER_REFERENCE(imx51_gpio, simplebus);
+SYSINIT_DRIVER_REFERENCE(imx_rtems_gpio, simplebus);
 SYSINIT_DRIVER_REFERENCE(sdhci_fsl, simplebus);
 RTEMS_BSD_DRIVER_MMC;
diff --git a/rtemsbsd/sys/arm/freescale/imx/imx_rtems_gpio.c b/rtemsbsd/sys/arm/freescale/imx/imx_rtems_gpio.c
new file mode 100644
index 00000000..c24732cc
--- /dev/null
+++ b/rtemsbsd/sys/arm/freescale/imx/imx_rtems_gpio.c
@@ -0,0 +1,306 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#include <bsp.h>
+#if defined(LIBBSP_ARM_IMX_BSP_H)
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+#include <sys/param.h>
+#include <sys/bus.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <sys/gpio.h>
+#include <dev/fdt/fdt_common.h>
+#include <dev/gpio/gpiobusvar.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include <bsp/imx-gpio.h>
+#define MAXPIN		(32)
+#define VALID_PIN(u)	((u) >= 0 && (u) <= MAXPIN)
+struct imx_rtems_gpio_softc {
+	device_t		dev;
+	device_t		busdev;
+	struct imx_gpio		*imx_gpio;
+	struct {
+		struct imx_gpio_pin	pin;
+		bool			initialized;
+		uint32_t		flags;
+	} pin[MAXPIN];
+static device_t
+imx_rtems_gpio_get_bus(device_t dev)
+	struct imx_rtems_gpio_softc *sc = device_get_softc(dev);
+	return (sc->busdev);
+static int
+imx_rtems_gpio_pin_max(device_t dev, int *maxpin)
+	*maxpin = MAXPIN;
+	return (0);
+static int
+imx_rtems_gpio_pin_getcaps(device_t dev, uint32_t pin, uint32_t *caps)
+	if (!VALID_PIN(pin))
+		return (EINVAL);
+	*caps = (GPIO_PIN_INPUT | GPIO_PIN_OUTPUT);
+	return (0);
+/* Get a specific pin's name. */
+static int
+imx_rtems_gpio_pin_getname(device_t dev, uint32_t pin, char *name)
+		return (EINVAL);
+	snprintf(name, GPIOMAXNAME, "%s_%d",
+	    imx_gpio_get_name(sc->imx_gpio), pin);
+	name[GPIOMAXNAME-1] = '\0';
+	return (0);
+static void
+imx_rtems_gpio_pin_init(struct imx_rtems_gpio_softc *sc, uint32_t pin)
+	imx_gpio_init(&sc->pin[pin].pin);
+	sc->pin[pin].initialized = true;
+static int
+imx_rtems_gpio_pin_set(device_t dev, uint32_t pin, unsigned int value)
+	if (!VALID_PIN(pin) || value > 1)
+		return (EINVAL);
+	if (!sc->pin[pin].initialized) {
+		imx_rtems_gpio_pin_init(sc, pin);
+	imx_gpio_set_output(&sc->pin[pin].pin, value);
+	return (0);
+static int
+imx_rtems_gpio_pin_get(device_t dev, uint32_t pin, unsigned int *value)
+		return (EINVAL);
+	*value = imx_gpio_get_input(&sc->pin[pin].pin);
+	return (0);
+static int
+imx_rtems_gpio_pin_toggle(device_t dev, uint32_t pin)
+		return (EINVAL);
+	imx_gpio_toggle_output(&sc->pin[pin].pin);
+	return (0);
+static int
+imx_rtems_gpio_pin_getflags(device_t dev, uint32_t pin, uint32_t *flags)
+		return (EINVAL);
+	*flags = sc->pin[pin].flags;
+	return (0);
+static int
+imx_rtems_gpio_pin_setflags(device_t dev, uint32_t pin, uint32_t flags)
+		return (EINVAL);
+	if (flags & (GPIO_PIN_INPUT | GPIO_PIN_OUTPUT)) {
+		if (flags & GPIO_PIN_PRESET_LOW) {
+			imx_gpio_set_output(&sc->pin[pin].pin, 0);
+		} else if (flags & GPIO_PIN_PRESET_HIGH) {
+			imx_gpio_set_output(&sc->pin[pin].pin, 1);
+		if (flags & GPIO_PIN_OUTPUT) {
+			sc->pin[pin].pin.mode = IMX_GPIO_MODE_OUTPUT;
+		} else {
+			sc->pin[pin].pin.mode = IMX_GPIO_MODE_INPUT;
+		sc->pin[pin].flags = flags;
+	} else {
+		return (EINVAL);
+	return (0);
+static struct ofw_compat_data compat_data[] = {
+	{"fsl,imx35-gpio",  1},
+	{"fsl,imx7d-gpio",  1},
+	{NULL,              0}
+static int
+imx_rtems_gpio_probe(device_t dev)
+	if (!ofw_bus_status_okay(dev))
+		return (ENXIO);
+	if (ofw_bus_search_compatible(dev, compat_data)->ocd_data != 0) {
+		device_set_desc(dev, "Freescale i.MX GPIO Controller (RTEMS)");
+		return (BUS_PROBE_DEFAULT);
+	return (ENXIO);
+static int
+imx_rtems_gpio_attach(device_t dev)
+	u_long base, size;
+	size_t i;
+	sc->dev = dev;
+	/* Get register address */
+	if (fdt_regsize(ofw_bus_get_node(sc->dev), &base, &size) != 0) {
+		device_printf(dev, "Can't get register address");
+		return (EINVAL);
+	sc->imx_gpio = imx_gpio_get_by_register((void *)base);
+	if (sc->imx_gpio == NULL) {
+		device_printf(dev, "Can't get RTEMS imx_gpio handle");
+		return (EINVAL);
+	memset(sc->pin, 0, sizeof(sc->pin));
+	for (i = 0; i < MAXPIN; ++i) {
+		sc->pin[i].pin.gpio = sc->imx_gpio;
+		sc->pin[i].pin.mask = 1 << i;
+		sc->pin[i].pin.shift = i;
+		sc->pin[i].pin.mode = IMX_GPIO_MODE_INPUT;
+	 * Do _not_ initialize the pins here. Otherwise we would overwrite prior
+	 * initializations done by other application parts.
+	sc->busdev = gpiobus_attach_bus(dev);
+	if (sc->busdev == NULL) {
+		return (ENOMEM);
+	return (0);
+static int
+imx_rtems_gpio_detach(device_t dev)
+	gpiobus_detach_bus(dev);
+	return (0);
+static device_method_t imx_rtems_gpio_methods[] = {
+	/* device_if */
+	DEVMETHOD(device_probe,		imx_rtems_gpio_probe),
+	DEVMETHOD(device_attach,	imx_rtems_gpio_attach),
+	DEVMETHOD(device_detach,	imx_rtems_gpio_detach),
+	/* GPIO protocol */
+	DEVMETHOD(gpio_get_bus,		imx_rtems_gpio_get_bus),
+	DEVMETHOD(gpio_pin_max,		imx_rtems_gpio_pin_max),
+	DEVMETHOD(gpio_pin_getname,	imx_rtems_gpio_pin_getname),
+	DEVMETHOD(gpio_pin_getflags,	imx_rtems_gpio_pin_getflags),
+	DEVMETHOD(gpio_pin_getcaps,	imx_rtems_gpio_pin_getcaps),
+	DEVMETHOD(gpio_pin_get,		imx_rtems_gpio_pin_get),
+	DEVMETHOD(gpio_pin_setflags,	imx_rtems_gpio_pin_setflags),
+	DEVMETHOD(gpio_pin_set,		imx_rtems_gpio_pin_set),
+	DEVMETHOD(gpio_pin_toggle,	imx_rtems_gpio_pin_toggle),
+	DEVMETHOD_END
+static driver_t imx_rtems_gpio_driver = {
+	"gpio",
+	imx_rtems_gpio_methods,
+	sizeof(struct imx_rtems_gpio_softc),
+static devclass_t imx_rtems_gpio_devclass;
+EARLY_DRIVER_MODULE(imx_rtems_gpio, simplebus, imx_rtems_gpio_driver,
+    imx_rtems_gpio_devclass, NULL, NULL,
+    BUS_PASS_RESOURCE + BUS_PASS_ORDER_MIDDLE);
+#endif /* LIBBSP_ARM_IMX_BSP_H */
2.26.2
