Need help in understanding some of the existing code in RTEMS
Richi Dubey
richidubey at gmail.com
Fri Jul 17 08:24:06 UTC 2020
> During system startup the application configuration defines which
> processor is available to RTEMS. Every configured and present processor
> gets an idle thread assigned which is managed by a scheduler. This is
> the starting point of the system. If someone calls
> rtems_scheduler_remove_processor(), then a processor gets removed from a
> scheduler instance. This processor still has to execute code. For this a
> idle thread is used. This idle thread is not managed by a scheduler. If
> someone uses rtems_scheduler_add_processor() this idle thread is again
> controlled by a scheduler.
This makes sense. Thanks.
On Thu, Jul 16, 2020 at 9:17 PM Sebastian Huber <
> On 15/07/2020 14:55, Richi Dubey wrote:
> > On Wed, Jul 15, 2020 at 5:57 PM Richi Dubey <richidubey at gmail.com
> > <mailto:richidubey at gmail.com>> wrote:
> > Hi,
> > I had a small question. The scheduler struct inside percpu.h looks
> > like:
> > struct {
> > * @brief The scheduler control of the scheduler owning this
> > processor.
> > * This pointer is NULL in case this processor is currently
> > not used by a
> > * scheduler instance.
> > const struct _Scheduler_Control *control;
> > * @brief The scheduler context of the scheduler owning this
> > processor.
> > not used by a
> > const struct Scheduler_Context *context;
> > * @brief The idle thread for this processor in case it is
> > online and
> > * currently not used by a scheduler instance.
> > struct _Thread_Control *idle_if_online_and_unused;
> > } Scheduler;
> > So, does this mean a CPU when active is always either executing an
> > idle thread and is not being used by a scheduler (so has a thread
> > attribute in the idle_if_online_and_unused), or is used by a
> > scheduler and is executing a task ( which can not be an idle
> > task)? Another equivalent question is do we have an idle scheduler
> > node, like we have idle predefined threads that run on a CPU?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200717/a89c2122/attachment.html>
