[PATCH v3] Changed ARM fenv support similar to X86_64
Eshan dhawan eshandhawan51 at gmail.com
Fri Jul 17 23:31:17 UTC 2020
Removed soft float files
Signed-off-by: Eshan dhawan <eshandhawan51 at gmail.com>
 newlib/libc/machine/arm/machine/fenv-mangle.h |  53 ---
 .../libc/machine/arm/machine/fenv-softfloat.h | 187 -----------
 newlib/libc/machine/arm/machine/fenv-vfp.h    | 187 -----------
 newlib/libc/machine/arm/sys/fenv.h            |  19 +-
 newlib/libm/machine/arm/Makefile.am           |   4 +-
 newlib/libm/machine/arm/fenv-softfp.c         |  32 --
 newlib/libm/machine/arm/fenv-vfp.c            |  32 --
 newlib/libm/machine/arm/fenv.c                | 315 +++++++-----------
 8 files changed, 127 insertions(+), 702 deletions(-)
 delete mode 100644 newlib/libc/machine/arm/machine/fenv-mangle.h
 delete mode 100644 newlib/libc/machine/arm/machine/fenv-softfloat.h
 delete mode 100644 newlib/libc/machine/arm/machine/fenv-vfp.h
 delete mode 100644 newlib/libm/machine/arm/fenv-softfp.c
 delete mode 100644 newlib/libm/machine/arm/fenv-vfp.c
diff --git a/newlib/libc/machine/arm/machine/fenv-mangle.h b/newlib/libc/machine/arm/machine/fenv-mangle.h
deleted file mode 100644
index 476f7b20c..000000000
--- a/newlib/libc/machine/arm/machine/fenv-mangle.h
+++ /dev/null
@@ -1,53 +0,0 @@
- * Copyright (c) 2013 Andrew Turner <andrew at FreeBSD.ORG>
- * All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- *    notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- *    notice, this list of conditions and the following disclaimer in the
- *    documentation and/or other materials provided with the distribution.
- * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
- * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
- * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
- * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
- * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
- * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
- * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
- * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
- * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
- * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * $FreeBSD$
-#ifdef _FENV_MANGLE_H_
-#error Only include fenv-mangle.h once
-#endif
-#define	_FENV_MANGLE_H_
-#ifndef FENV_MANGLE
-#error FENV_MANGLE is undefined
-#endif
-#define	feclearexcept	FENV_MANGLE(feclearexcept)
-#define	fegetexceptflag	FENV_MANGLE(fegetexceptflag)
-#define	fesetexceptflag	FENV_MANGLE(fesetexceptflag)
-#define	feraiseexcept	FENV_MANGLE(feraiseexcept)
-#define	fetestexcept	FENV_MANGLE(fetestexcept)
-#define	fegetround	FENV_MANGLE(fegetround)
-#define	fesetround	FENV_MANGLE(fesetround)
-#define	fegetenv	FENV_MANGLE(fegetenv)
-#define	feholdexcept	FENV_MANGLE(feholdexcept)
-#define	fesetenv	FENV_MANGLE(fesetenv)
-#define	feupdateenv	FENV_MANGLE(feupdateenv)
-#define	feenableexcept	FENV_MANGLE(feenableexcept)
-#define	fedisableexcept	FENV_MANGLE(fedisableexcept)
-#define	fegetexcept	FENV_MANGLE(fegetexcept)
diff --git a/newlib/libc/machine/arm/machine/fenv-softfloat.h b/newlib/libc/machine/arm/machine/fenv-softfloat.h
index 5d33e18d0..000000000
--- a/newlib/libc/machine/arm/machine/fenv-softfloat.h
+++ /dev/null
@@ -1,187 +0,0 @@
- * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
- * Copyright (c) 2004-2011 David Schultz <das at FreeBSD.ORG>
- * are met:
- * SUCH DAMAGE.
- * $FreeBSD$
-#ifndef	_SYS_FENV_H_
-#error "This file is meant to be included only by <sys/fenv.h>."
-#endif
-/* the file can be added from architecture specific fenv.h file found in
- *libc/sys/arch/sys *
- * This file implements the functionality of <fenv.h> on platforms that
- * lack an FPU and use softfloat in libc for floating point.  To use it,
- * you must write an <fenv.h> that provides the following:
- *   - a typedef for fenv_t, which may be an integer or struct type
- *   - a typedef for fexcept_t (XXX This file assumes fexcept_t is a
- *     simple integer type containing the exception mask.)
- *   - definitions of FE_* constants for the five exceptions and four
- *     rounding modes in IEEE 754, as described in fenv(3)
- *   - a definition, and the corresponding external symbol, for FE_DFL_ENV
- *   - a macro __set_env(env, flags, mask, rnd), which sets the given fenv_t
- *     from the exception flags, mask, and rounding mode
- *   - macros __env_flags(env), __env_mask(env), and __env_round(env), which
- *     extract fields from an fenv_t
- *   - a definition of __fenv_static
- * If the architecture supports an optional FPU, it's recommended that you
- * define fenv_t and fexcept_t to match the hardware ABI.  Otherwise, it
- * doesn't matter how you define them.
-#include <errno.h>
-int __softfloat_float_exception_flags;
-int __softfloat_float_exception_mask;
-int __softfloat_float_rounding_mode;
-__fenv_static inline int
-feclearexcept(int excepts)
-	__softfloat_float_exception_flags &= ~excepts;
-	return (0);
-fegetexceptflag(fexcept_t *flagp, int excepts)
-	*flagp = __softfloat_float_exception_flags & excepts;
-	return (0);
-fesetexceptflag(const fexcept_t *flagp, int excepts)
-	__softfloat_float_exception_flags |= *flagp & excepts;
-	return (0);
-feraiseexcept(int excepts)
-	return (excepts  ?  -ENOTSUP : 0);
-fetestexcept(int excepts)
-	return (__softfloat_float_exception_flags & excepts);
-fegetround(void)
-	return (__softfloat_float_rounding_mode);
-fesetround(int round)
-	__softfloat_float_rounding_mode = round;
-	return (0);
-fegetenv(fenv_t *envp)
-	__set_env(*envp, __softfloat_float_exception_flags,
-	    __softfloat_float_exception_mask, __softfloat_float_rounding_mode);
-	return (0);
-feholdexcept(fenv_t *envp)
-	fenv_t __env;
-	fegetenv(envp);
-	__softfloat_float_exception_flags = 0;
-	__softfloat_float_exception_mask = 0;
-	return (0);
-fesetenv(const fenv_t *envp)
-	__softfloat_float_exception_flags = __env_flags(*envp);
-	__softfloat_float_exception_mask = __env_mask(*envp);
-	__softfloat_float_rounding_mode = __env_round(*envp);
-	return (0);
-feupdateenv(const fenv_t *envp)
-	int __oflags = __softfloat_float_exception_flags;
-	fesetenv(envp);
-	feraiseexcept(__oflags);
-	return (0);
-#if __BSD_VISIBLE
-/* We currently provide no external definitions of the functions below. */
-feenableexcept(int __mask)
-	int __omask = __softfloat_float_exception_mask;
-	__softfloat_float_exception_mask |= __mask;
-	return (__omask);
-fedisableexcept(int __mask)
-	__softfloat_float_exception_mask &= ~__mask;
-	return (__omask);
-fegetexcept(void)
-	return (__softfloat_float_exception_mask);
-#endif /* __BSD_VISIBLE */
diff --git a/newlib/libc/machine/arm/machine/fenv-vfp.h b/newlib/libc/machine/arm/machine/fenv-vfp.h
index 25d71f3ab..000000000
--- a/newlib/libc/machine/arm/machine/fenv-vfp.h
+++ /dev/null
@@ -1,187 +0,0 @@
- * Copyright (c) 2004-2005 David Schultz <das at FreeBSD.ORG>
- * are met:
- * SUCH DAMAGE.
- * $FreeBSD$
-#define	vmrs_fpscr(__r)	__asm __volatile("vmrs %0, fpscr" : "=&r"(__r))
-#define	vmsr_fpscr(__r)	__asm __volatile("vmsr fpscr, %0" : : "r"(__r))
-#define _FPU_MASK_SHIFT	8
-__fenv_static inline int feclearexcept(int excepts)
-	fexcept_t __fpsr;
-	vmrs_fpscr(__fpsr);
-	__fpsr &= ~excepts;
-	vmsr_fpscr(__fpsr);
-	return (0);
-	fexcept_t __fpsr;
-	*flagp = __fpsr & excepts;
-	return (0);
-	fexcept_t __fpsr;
-	__fpsr |= *flagp & excepts;
-	return (0);
-	fexcept_t __ex = excepts;
-	fesetexceptflag(&__ex, excepts);	/* XXX */
-	return (0);
-	fexcept_t __fpsr;
-	return (__fpsr & excepts);
-fegetround(void)
-	fenv_t __fpsr;
-	return (__fpsr & _ROUND_MASK);
-	fenv_t __fpsr;
-	__fpsr &= ~(_ROUND_MASK);
-	__fpsr |= round;
-	return (0);
-	vmrs_fpscr(*envp);
-	return (0);
-	fenv_t __env;
-	vmrs_fpscr(__env);
-	*envp = __env;
-	__env &= ~(FE_ALL_EXCEPT);
-	vmsr_fpscr(__env);
-	return (0);
-	vmsr_fpscr(*envp);
-	return (0);
-	fexcept_t __fpsr;
-	feraiseexcept(__fpsr & FE_ALL_EXCEPT);
-	return (0);
-#if __BSD_VISIBLE
-	fenv_t __old_fpsr, __new_fpsr;
-	vmrs_fpscr(__old_fpsr);
-	__new_fpsr = __old_fpsr |
-	    ((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
-	vmsr_fpscr(__new_fpsr);
-	return ((__old_fpsr >> _FPU_MASK_SHIFT) & FE_ALL_EXCEPT);
-	__new_fpsr = __old_fpsr &
-	    ~((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
-fegetexcept(void)
-	fenv_t __fpsr;
-	return (__fpsr & FE_ALL_EXCEPT);
diff --git a/newlib/libc/machine/arm/sys/fenv.h b/newlib/libc/machine/arm/sys/fenv.h
index 740995a1a..0224da38b 100644
--- a/newlib/libc/machine/arm/sys/fenv.h
+++ b/newlib/libc/machine/arm/sys/fenv.h
@@ -63,22 +63,11 @@ typedef int fexcept_t;
 /* Rounding modes */
-#define	VFP_FE_TONEAREST	0x00000000
-#define	VFP_FE_UPWARD		0x00400000
-#define	VFP_FE_DOWNWARD		0x00800000
-#define	VFP_FE_TOWARDZERO	0x00c00000
+#define	FE_TONEAREST		0x00000000
+#define	FE_UPWARD		0x00400000
+#define	FE_DOWNWARD		0x00800000
+#define	FE_TOWARDZERO		0x00c00000
-#ifdef __ARM_PCS_VFP
-#define	FE_TONEAREST	VFP_FE_TONEAREST
-#define	FE_UPWARD	VFP_FE_UPWARD
-#define	FE_DOWNWARD	VFP_FE_DOWNWARD
-#define	FE_TOWARDZERO	VFP_FE_TOWARDZERO
-#else
-#define	FE_TONEAREST	0x0000
-#define	FE_TOWARDZERO	0x0001
-#define	FE_UPWARD	0x0002
-#define	FE_DOWNWARD	0x0003
-#endif
 #define	_ROUND_MASK	(FE_TONEAREST | FE_DOWNWARD | \
 			 FE_UPWARD | FE_TOWARDZERO)
diff --git a/newlib/libm/machine/arm/Makefile.am b/newlib/libm/machine/arm/Makefile.am
index a64ee59d5..180a37f44 100644
--- a/newlib/libm/machine/arm/Makefile.am
+++ b/newlib/libm/machine/arm/Makefile.am
@@ -32,9 +32,7 @@ LIB_SOURCES = \
 	fesetexceptflag.c \
 	fesetround.c \
 	fetestexcept.c \
-	feupdateenv.c \
-	fenv-vfp.c \
-	fenv-softfp.c
+	feupdateenv.c
 noinst_LIBRARIES = lib.a
diff --git a/newlib/libm/machine/arm/fenv-softfp.c b/newlib/libm/machine/arm/fenv-softfp.c
index a576cc1b2..000000000
--- a/newlib/libm/machine/arm/fenv-softfp.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * are met:
- * SUCH DAMAGE.
- * $FreeBSD$
-#define	FENV_MANGLE(x)	__softfp_ ##x
-#include <machine/fenv-mangle.h>
-#include "fenv.c"
diff --git a/newlib/libm/machine/arm/fenv-vfp.c b/newlib/libm/machine/arm/fenv-vfp.c
index 297e81296..000000000
--- a/newlib/libm/machine/arm/fenv-vfp.c
+++ /dev/null
@@ -1,32 +0,0 @@
- * are met:
- * SUCH DAMAGE.
- * $FreeBSD$
-#define	FENV_MANGLE(x)	__vfp_ ##x
-#include "fenv.c"
diff --git a/newlib/libm/machine/arm/fenv.c b/newlib/libm/machine/arm/fenv.c
index 5b61ab81f..6f24aa9f0 100644
--- a/newlib/libm/machine/arm/fenv.c
+++ b/newlib/libm/machine/arm/fenv.c
@@ -29,7 +29,6 @@
  * $FreeBSD$
-#define	__fenv_static
 #include <fenv.h>
 #include <machine/acle-compat.h>
@@ -38,156 +37,40 @@
 #define FENV_ARMv6
 #endif
-/* When SOFTFP_ABI is defined we are using the softfp ABI. */
-#if defined(__VFP_FP__) && !defined(__ARM_PCS_VFP)
-#define SOFTFP_ABI
-#endif
- * Hopefully the system ID byte is immutable, so it's valid to use
- * this as a default environment.
 fenv_t __fe_dfl_env = { 0 };
 const fenv_t *_fe_dfl_env = &__fe_dfl_env;
-#endif
-/* If this is a non-mangled softfp version special processing is required */
-#if defined(FENV_MANGLE) || !defined(SOFTFP_ABI) || !defined(FENV_ARMv6)
- * The following macros map between the softfloat emulator's flags and
- * the hardware's FPSR.  The hardware this file was written for doesn't
- * have rounding control bits, so we stick those in the system ID byte.
-#ifndef __ARM_PCS_VFP
-#define	__set_env(env, flags, mask, rnd) env = ((flags)			\
-						| (mask)<<_FPUSW_SHIFT	\
-						| (rnd) << 24)
-#define	__env_flags(env)		((env) & FE_ALL_EXCEPT)
-#define	__env_mask(env)			(((env) >> _FPUSW_SHIFT)	\
-						& FE_ALL_EXCEPT)
-#define	__env_round(env)		(((env) >> 24) & _ROUND_MASK)
-#include <machine/fenv-softfloat.h>
-#else /* __ARM_PCS_VFP PRESENT */
-#include <machine/fenv-vfp.h>
-#endif /* __ARM_PCS_VFP */
-#ifdef __GNUC_GNU_INLINE__
-#error "This file must be compiled with C99 'inline' semantics"
+#ifdef __ARM_PCS_VFP
+#define	vmrs_fpscr(__r)	__asm __volatile("vmrs %0, fpscr" : "=&r"(__r))
+#define	vmsr_fpscr(__r)	__asm __volatile("vmsr fpscr, %0" : : "r"(__r))
 #endif
-extern inline int feclearexcept(int excepts);
-extern inline int fegetexceptflag(fexcept_t *flagp, int excepts);
-extern inline int fesetexceptflag(const fexcept_t *flagp, int excepts);
-extern inline int feraiseexcept(int excepts);
-extern inline int fetestexcept(int excepts);
-extern inline int fegetround(void);
-extern inline int fesetround(int round);
-extern inline int fegetenv(fenv_t *envp);
-extern inline int feholdexcept(fenv_t *envp);
-extern inline int fesetenv(const fenv_t *envp);
-extern inline int feupdateenv(const fenv_t *envp);
-extern inline int feenableexcept(int __mask);
-extern inline int fedisableexcept(int __mask);
-extern inline int fegetexcept(void);
-#else /* !FENV_MANGLE && SOFTFP_ABI */
-/* Set by libc when the VFP unit is enabled */
-int _libc_arm_fpu_present;
-int __softfp_feclearexcept(int excepts);
-int __softfp_fegetexceptflag(fexcept_t *flagp, int excepts);
-int __softfp_fesetexceptflag(const fexcept_t *flagp, int excepts);
-int __softfp_feraiseexcept(int excepts);
-int __softfp_fetestexcept(int excepts);
-int __softfp_fegetround(void);
-int __softfp_fesetround(int round);
-int __softfp_fegetenv(fenv_t *envp);
-int __softfp_feholdexcept(fenv_t *envp);
-int __softfp_fesetenv(const fenv_t *envp);
-int __softfp_feupdateenv(const fenv_t *envp);
-int __softfp_feenableexcept(int __mask);
-int __softfp_fedisableexcept(int __mask);
-int __softfp_fegetexcept(void);
-int __vfp_feclearexcept(int excepts);
-int __vfp_fegetexceptflag(fexcept_t *flagp, int excepts);
-int __vfp_fesetexceptflag(const fexcept_t *flagp, int excepts);
-int __vfp_feraiseexcept(int excepts);
-int __vfp_fetestexcept(int excepts);
-int __vfp_fegetround(void);
-int __vfp_fesetround(int round);
-int __vfp_fegetenv(fenv_t *envp);
-int __vfp_feholdexcept(fenv_t *envp);
-int __vfp_fesetenv(const fenv_t *envp);
-int __vfp_feupdateenv(const fenv_t *envp);
-int __vfp_feenableexcept(int __mask);
-int __vfp_fedisableexcept(int __mask);
-int __vfp_fegetexcept(void);
-static int
-__softfp_round_to_vfp(int round)
-	switch (round) {
-	case FE_TONEAREST:
-	default:
-		return VFP_FE_TONEAREST;
-	case FE_TOWARDZERO:
-		return VFP_FE_TOWARDZERO;
-	case FE_UPWARD:
-		return VFP_FE_UPWARD;
-	case FE_DOWNWARD:
-		return VFP_FE_DOWNWARD;
-static int
-__softfp_round_from_vfp(int round)
-	switch (round) {
-	case VFP_FE_TONEAREST:
-	default:
-		return FE_TONEAREST;
-	case VFP_FE_TOWARDZERO:
-		return FE_TOWARDZERO;
-	case VFP_FE_UPWARD:
-		return FE_UPWARD;
-	case VFP_FE_DOWNWARD:
-		return FE_DOWNWARD;
+#define _FPU_MASK_SHIFT	8
-	if (_libc_arm_fpu_present)
-		__vfp_feclearexcept(excepts);
-	__softfp_feclearexcept(excepts);
+	fexcept_t __fpsr;
+	vmrs_fpscr(__fpsr);
+	__fpsr &= ~excepts;
+	vmsr_fpscr(__fpsr);
+#endif
 	return (0);
-	fexcept_t __vfp_flagp;
-	__vfp_flagp = 0;
-		__vfp_fegetexceptflag(&__vfp_flagp, excepts);
-	__softfp_fegetexceptflag(flagp, excepts);
-	*flagp |= __vfp_flagp;
+	fexcept_t __fpsr;
+	__fpsr |= *flagp & excepts;
+#endif
 	return (0);
@@ -195,9 +78,13 @@ int fegetexceptflag(fexcept_t *flagp, int excepts)
-		__vfp_fesetexceptflag(flagp, excepts);
-	__softfp_fesetexceptflag(flagp, excepts);
+	fexcept_t __fpsr;
+#endif
 	return (0);
@@ -205,65 +92,86 @@ int fesetexceptflag(const fexcept_t *flagp, int excepts)
-		__vfp_feraiseexcept(excepts);
-	__softfp_feraiseexcept(excepts);
+	fexcept_t __ex = excepts;
+	fesetexceptflag(&__ex, excepts);
+#endif
 	return (0);
-	int __got_excepts;
-	__got_excepts = 0;
-		__got_excepts = __vfp_fetestexcept(excepts);
-	__got_excepts |= __softfp_fetestexcept(excepts);
+	fexcept_t __fpsr;
+	return (__fpsr & excepts);
+#endif
-	return (__got_excepts);
+	return (0);
-		return __softfp_round_from_vfp(__vfp_fegetround());
-	return __softfp_fegetround();
+	fenv_t __fpsr;
+	return (__fpsr & _ROUND_MASK);
+#else
+/* For soft float */
+#ifdef FE_TONEAREST
+		return FE_TONEAREST;
+#else
+		return 0;
+#endif
+#endif
-		__vfp_fesetround(__softfp_round_to_vfp(round));
-	__softfp_fesetround(round);
+#ifndef __SOFTFP__
+	fenv_t __fpsr;
+	__fpsr &= ~(_ROUND_MASK);
+	__fpsr |= round;
+	return (0);
+#endif
 	return (0);
-	fenv_t __vfp_envp;
+#ifndef __SOFTFP__
+		vmrs_fpscr(*envp);
+		return 0;
+#endif
-	__vfp_envp = 0;
-		__vfp_fegetenv(&__vfp_envp);
-	__softfp_fegetenv(envp);
-	*envp |= __vfp_envp;
+	*envp |= 0;
 	return (0);
-	__vfp_envp = 0;
-		__vfp_feholdexcept(&__vfp_envp);
-	__softfp_feholdexcept(envp);
+#ifndef __SOFTFP__
+	fenv_t __env;
+	vmrs_fpscr(__env);
+	*envp = __env;
+	__env &= ~(FE_ALL_EXCEPT);
+	vmsr_fpscr(__env);
+	return (0);
+#endif
+	*envp |= 0;
 	return (0);
@@ -271,58 +179,79 @@ int feholdexcept(fenv_t *envp)
-		__vfp_fesetenv(envp);
-	__softfp_fesetenv(envp);
+#ifndef __SOFTFP__
+		vmsr_fpscr(*envp);
+#endif
 	return (0);
-		__vfp_feupdateenv(envp);
-	__softfp_feupdateenv(envp);
+#ifndef __SOFTFP__
+	fexcept_t __fpsr;
+	feraiseexcept(__fpsr & FE_ALL_EXCEPT);
+	return 0;
+#else
+#if defined FE_NOMASK_ENV && FE_ALL_EXCEPT != 0
+  if (envp == FE_NOMASK_ENV)
+      return 1;
+#endif
+  return 0;
+#endif
-	return (0);
-	int __unmasked;
-	__unmasked = 0;
-		__unmasked = __vfp_feenableexcept(__mask);
-	__unmasked |= __softfp_feenableexcept(__mask);
+#ifndef __SOFTFP__
+	fenv_t __old_fpsr, __new_fpsr;
+	vmrs_fpscr(__old_fpsr);
+	__new_fpsr = __old_fpsr |
+	    ((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
+	vmsr_fpscr(__new_fpsr);
+	return ((__old_fpsr >> _FPU_MASK_SHIFT) & FE_ALL_EXCEPT);
+#endif
-	return (__unmasked);
+	return (0);
-	int __unmasked;
-	__unmasked = 0;
-		__unmasked = __vfp_fedisableexcept(__mask);
-	__unmasked |= __softfp_fedisableexcept(__mask);
+#ifndef __SOFTFP__
+	__new_fpsr = __old_fpsr &
+	    ~((__mask & FE_ALL_EXCEPT) << _FPU_MASK_SHIFT);
+#endif
+	return (0);
-	int __unmasked;
-	__unmasked = 0;
-		__unmasked = __vfp_fegetexcept();
-	__unmasked |= __softfp_fegetexcept();
+#ifndef __SOFTFP__
+	fenv_t __fpsr;
+	return (__fpsr & FE_ALL_EXCEPT);
+#endif
+	return (0);
-#endif
2.17.1
