[PATCH v3] Changed ARM fenv support similar to X86_64
Sebastian Huber
Sat Jul 18 11:22:25 UTC 2020
Hello Eshan,
you produce a lot of extra work for me. Your patch applies now. But it
didn't build:
make[9]: *** No rule to make target 'fenv-vfp.c', needed by
'lib_a-fenv-vfp.o'. Stop.
make[9]: *** Waiting for unfinished jobs....
make[9]: Leaving directory
'/build/git-build/b-gcc-10.1.0-arm-rtems5/arm-rtems5/thumb/newlib/libm/machine/arm'
Why is x86_64 mentioned in the commit message? On the mailing list it
was discussed to use RISC-V as the model. Please improve the commit
message in general. It should reflect all the problems discussed on the
mailing list and how the commit addresses the issues.
Attached is a patch which fixes a couple of obvious things. Please apply
it, review it, test it, and make a v4 patch out of it with an improved
commit message.
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200718/cbffdf63/attachment.bin>
