[PATCH v3] Changed ARM fenv support similar to X86_64
Sebastian Huber
Sat Jul 18 15:21:45 UTC 2020
On 18/07/2020 17:17, Eshan Dhawan wrote:
>> On 18-Jul-2020, at 4:52 PM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> Hello Eshan,
>> you produce a lot of extra work for me. Your patch applies now. But it didn't build:
>> make[9]: *** No rule to make target 'fenv-vfp.c', needed by 'lib_a-fenv-vfp.o'. Stop.
>> make[9]: *** Waiting for unfinished jobs....
>> make[9]: Leaving directory '/build/git-build/b-gcc-10.1.0-arm-rtems5/arm-rtems5/thumb/newlib/libm/machine/arm'
> Fenv-vpf.c file was deleted as well as the declarations were deleted from makefile.am
> So it shouldn’t be compiled
> Did you try Remaking the autoconf files after applying the patch ???
> This patch have the autoconf files
I don't want to run autoconf myself to test your patches. Please include
the build system changes in your patches.
>> Why is x86_64 mentioned in the commit message? On the mailing list it was discussed to use RISC-V as the model. Please improve the commit message in general. It should reflect all the problems discussed on the mailing list and how the commit addresses the issues.
> The files follow the similar file structure as x86_64. So I added X86
Which file did you use as a template?
>> Attached is a patch which fixes a couple of obvious things. Please apply it, review it, test it, and make a v4 patch out of it with an improved commit message.
> The error isn’t supposed to occur
> I tested the code on machine
>> <0001-arm-fenv.c-Fix-use-of-defines-and-format.patch>
> I will apply the patch and test it
> And resend it
> Is this patch applied over the current patch
> Or the newlib master?
Over your v3 patch.
