[PATCH v3] Changed ARM fenv support similar to X86_64
Eshan Dhawan eshandhawan51 at gmail.com
Sat Jul 18 15:17:42 UTC 2020
> On 18-Jul-2020, at 4:52 PM, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> Hello Eshan,
> you produce a lot of extra work for me. Your patch applies now. But it didn't build:
> make[9]: *** No rule to make target 'fenv-vfp.c', needed by 'lib_a-fenv-vfp.o'.  Stop.
> make[9]: *** Waiting for unfinished jobs....
> make[9]: Leaving directory '/build/git-build/b-gcc-10.1.0-arm-rtems5/arm-rtems5/thumb/newlib/libm/machine/arm'
Fenv-vpf.c file was deleted as well as the declarations were deleted from makefile.am
So it shouldn’t be compiled
Did you try Remaking the autoconf files after applying the patch ???
This patch have the autoconf files
> Why is x86_64 mentioned in the commit message? On the mailing list it was discussed to use RISC-V as the model. Please improve the commit message in general. It should reflect all the problems discussed on the mailing list and how the commit addresses the issues.
The files follow the similar file structure as x86_64. So I added X86
> Attached is a patch which fixes a couple of obvious things. Please apply it, review it, test it, and make a v4 patch out of it with an improved commit message.
The error isn’t supposed to occur
I tested the code on machine
> <0001-arm-fenv.c-Fix-use-of-defines-and-format.patch>
I will apply the patch and test it
And resend it
Is this patch applied over the current patch
Or the newlib master?
