[GSoC 2020]: Weekly thread: Preparing RSB recipies for EPICS
Mritunjay Sharma mritunjaysharma394 at gmail.com
Mon Jul 20 22:39:28 UTC 2020
Hello all,
I went through the
https://docs.rtems.org/branches/master/user/rsb/index.html
and started writing a recipe for building EPICS 7.
The code is based on a very raw idea just now and
so was expected to give errors.
The code can be found here:
https://github.com/mritunjaysharma394/rtems-source-builder/blob/epics-support/source-builder/config/epics-7-1.cfg
After this, just to check, what errors it might gave,
I ran the following command:
../source-builder/sb-builder --prefix=/home/mritunjay/development
 --log=log_epics epics-7-1 --trace
This gave me the following error:
`+ cd epics-3afec267ab08568ea454789e562450b00feea5c0
/home/mritunjay/development/rtems/src/rsb_GSoC/rtems/build/epics-3afec267ab08568ea454789e562450b00feea5c0-x86_64-linux-gnu-1/do-build:
90: cd: can't cd to epics-3afec267ab08568ea454789e562450b00feea5c0
shell cmd failed: /bin/sh -ex
error: building
epics-3afec267ab08568ea454789e562450b00feea5c0-x86_64-linux-gnu-1`
I think there seems to be some problem with naming the directory.
I request you all to kindly help with the error as well as please check the
code
to see if I am on the right path.
I am attaching the log and trace file as well.
Thanks,
Mritunjay
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200721/e7bbe89d/attachment-0001.html>
RTEMS Tools Project - Source Builder Error Report
 Build: error: building epics-3afec267ab08568ea454789e562450b00feea5c0-x86_64-linux-gnu-1
 Command Line: ../source-builder/sb-builder --prefix=/home/mritunjay/development --log=log_epics epics-7-1 --trace
 Python: 2.7.18rc1 (default, Apr  7 2020, 12:05:55) [GCC 9.3.0]
 https://github.com/mritunjaysharma394/rtems-source-builder.git/origin/7f79fe90262aff88f1c3ef22e1d4cc586490a59b
 Linux mritunjay-Lenovo-Yoga-S740-14IIL 5.4.0-40-generic #44-Ubuntu SMP Tue Jun 23 00:01:04 UTC 2020 x86_64
Tail of the build log:
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osdProcess.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osdSignal.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osdSock.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osdSockAddrReuse.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osdSpin.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osdStdio.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osdStrtod.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osdThread.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osdThread.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osdThreadExtra.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osdTime.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osdTime.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/osiUnistd.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/posix/systemCallIntMech.cpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/solaris/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/solaris/epicsAtomicOSD.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/solaris/epicsMath.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/solaris/osdBackTrace.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/solaris/osdEnv.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/solaris/osdFindAddr.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/solaris/osdSock.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/solaris/osdStrtod.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/solaris/osdWireConfig.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/solaris/osiFileName.h
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/atReboot.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/camacLib.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/devLibVMEOSD.c
 extracting: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/epicsAtomicOSD.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/epicsAtomicOSD.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/epicsDynLink.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/epicsDynLink.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/epicsMMIO.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/epicsMath.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/logMsgToErrlog.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/module_types.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdEnv.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdEvent.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdEvent.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdFindSymbol.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdInterrupt.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdInterrupt.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdMessageQueue.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdMessageQueue.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdMonotonic.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdMutex.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdMutex.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdPoolStatus.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdProcess.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdReadline.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdSignal.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdSock.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdSock.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdSpin.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdStdio.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdStrtod.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdThread.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdThread.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdThreadExtra.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdTime.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdTime.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdVME.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osdWireConfig.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/osiFileName.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/strtoll.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/strtoull.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/task_params.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/veclist.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/os/vxWorks/vxComLibrary.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/osiClockTime.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/osiClockTime.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/osiNTPTime.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/osiNTPTime.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/osiPoolStatus.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/osiProcess.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/osiSock.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/osiSock.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/osi/osiWireFormat.h
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/pool/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/pool/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/pool/epicsThreadPool.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/pool/poolJob.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/pool/poolPriv.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/pool/threadPool.c
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/ring/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/ring/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/ring/epicsRingBytes.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/ring/epicsRingBytes.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/ring/epicsRingPointer.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/ring/epicsRingPointer.h
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/taskwd/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/taskwd/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/taskwd/taskwd.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/taskwd/taskwd.h
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/timer/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/timer/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/timer/epicsTimer.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/timer/epicsTimer.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/timer/timer.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/timer/timerPrivate.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/timer/timerQueue.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/timer/timerQueueActive.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/timer/timerQueueActiveMgr.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/timer/timerQueuePassive.cpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/valgrind/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/valgrind/valgrind.h
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/ACKNOWLEDGEMENTS
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/EPICS_READ_THIS
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/NEW_FEATURES
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/NOTES
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/NO_WARRANTY
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/README
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/antelope.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/closure.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/defs.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/error.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/lalr.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/lr0.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/mkpar.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/output.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/reader.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/skeleton.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/symtab.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/verbose.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/warshall.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yacc/yacc.html
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/RULES
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_alloc.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_alloc.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_buf.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_buf.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_bytestack.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_common.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_encode.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_encode.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_gen.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_gen.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_lex.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_lex.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_parse.h
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_parser.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/src/yajl/yajl_parser.h
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/aslibtest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/blockingSockTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/buckTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/cvtFastPerform.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/cvtFastTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsAlgorithmTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsAtomicPerform.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsAtomicTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsCalcTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsEllTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsEnvTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsEnvUnsetTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsErrlogTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsEventTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsExitTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsInlineTest1.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsInlineTest2.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsInlineTest3.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsInlineTest4.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsMMIOTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsMathTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsMaxThreads.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsMessageQueueTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsMutexTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsRunLibComTests.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsSockResolveTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsSpinTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsStackTraceTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsStdioTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsStdlibTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsStringTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsThreadHooksTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsThreadOnceTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsThreadPerform.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsThreadPoolTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsThreadPriorityTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsThreadPrivateTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsThreadTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsTimeTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsTimeZoneTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsTimerTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsTypesTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsUnitTestTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/epicsUnitTestTest.plt
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/fdmgrTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/ipAddrToAsciiTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/macDefExpandTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/macLib.plt
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/macLibTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/nonEpicsThreadPriorityTest.cpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/osiSockTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/ringBytesTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/ringPointerTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/rtemsTestData.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/rtemsTestHarness.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/taskwdTest.c
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/yajlTest.plt
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/yajlTestCases.pm
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/yajlTestConverter.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/test/yajl_test.c
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/Makefile
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/assert.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/checked_delete.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config.hpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/auto_link.hpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/compiler/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/compiler/gcc.hpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/no_tr1/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/no_tr1/memory.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/no_tr1/utility.hpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/platform/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/platform/vxworks.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/posix_features.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/select_compiler_config.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/select_platform_config.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/select_stdlib_config.hpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/stdlib/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/stdlib/dinkumware.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/suffix.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/config/user.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/current_function.hpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/detail/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/detail/sp_typeinfo.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/detail/workaround.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/enable_shared_from_this.hpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/exception/
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/exception/detail/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/exception/detail/attribute_noreturn.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/exception/exception.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/memory_order.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/shared_ptr.hpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/bad_weak_ptr.hpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/operator_bool.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/shared_count.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/sp_convertible.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/sp_counted_base.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/sp_counted_base_gcc_ppc.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/sp_counted_base_gcc_x86.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/sp_counted_impl.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/sp_has_sync.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/sp_nullptr_t.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/spinlock.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/spinlock_pool.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/spinlock_pt.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/spinlock_sync.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/detail/yield_k.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/enable_shared_from_this.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/shared_ptr.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/smart_ptr/weak_ptr.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/throw_exception.hpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/tr1/
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/tr1/detail/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/tr1/detail/config.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/tr1/memory.hpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/type_traits/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/type_traits/is_signed.hpp
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/libcom/vxWorks/boost/weak_ptr.hpp
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/normativeTypes/
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/pvAccess/
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/pvData/
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/pvDatabase/
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/pva2pva/
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/modules/pvaClient/
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/Makefile
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/makeBaseApp.pl
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/Makefile
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/configure/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/configure/CONFIG
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/configure/CONFIG_SITE
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/configure/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/configure/RELEASE
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/configure/RULES
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/configure/RULES.ioc
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/configure/RULES_DIRS
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/configure/RULES_TOP
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/supportApp/
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/supportApp/Db/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/supportApp/Db/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/supportApp/Makefile
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/supportApp/src/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/supportApp/src/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/base/top/supportApp/src/_APPNAME_.dbd
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/makeBaseExt.pl
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/README
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/CONFIG
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/CONFIG_SITE
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/RELEASE
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/RULES
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/RULES_DIRS
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/RULES_IDL
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/RULES_JAVA
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/RULES_PYTHON
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/RULES_TOP
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG.linux-x86.linux-386
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.Common.Common
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.aix-ppc-gnu.aix-ppc-gnu
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.aix-ppc.aix-ppc
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.cygwin-x86.cygwin-x86
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.darwin-ppc.darwin-ppc
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.darwin-ppcx86.darwin-ppcx86
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.darwin-x86.darwin-x86
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.freebsd-x86_64.freebsd-x86_64
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.linux-ppc.linux-ppc
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.linux-x86-debug.linux-x86-debug
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.linux-x86.linux-athlon
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.linux-x86.linux-x86
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.linux-x86_64-debug.linux-x86_64-debug
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.solaris-sparc-debug.solaris-sparc-debug
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.solaris-sparc-gnu.solaris-sparc-gnu
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.solaris-sparc.solaris-sparc
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.solaris-sparc64-gnu.solaris-sparc64-gnu
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.solaris-sparc64.solaris-sparc64
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.solaris-x86-debug.solaris-x86-debug
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.solaris-x86-gnu.solaris-x86-gnu
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.solaris-x86.solaris-x86
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.solaris-x86_64.solaris-x86_64
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.win32-x86-cygwin.win32-x86-cygwin
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.win32-x86-debug.win32-x86-debug
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.win32-x86-mingw.win32-x86-mingw
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.win32-x86.win32-x86
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/configure/os/CONFIG_SITE.windows-x64.windows-x64
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/exampleExt/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/exampleExt/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/exampleExt/RELEASE_NOTES.HTM
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/exampleExt/caExample.c
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/simpleExt/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/simpleExt/Makefile
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/src/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/template/ext/top/src/Makefile
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/EPICS/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/EPICS/Copy.pm
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/EPICS/Getopts.pm
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/EPICS/Path.pm
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/EPICS/Readfile.pm
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/EPICS/Release.pm
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/EpicsHostArch.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/assembleSnippets.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/convertRelease.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/cvsclean.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/depclean.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/dos2unix.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/expandVars.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/fullPathName.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/genVersionHeader.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/installEpics.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/makeMakefile.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/makeTestfile.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/mkmf.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/munch.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/podRemove.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/podToHtml.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/replaceVAR.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/style.css
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/tap-to-junit-xml.pl
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/src/tools/useManifestTool.pl
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/startup/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/startup/EpicsHostArch
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/startup/unix.csh
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/startup/unix.sh
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/startup/win32.bat
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/startup/windows.bat
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/test/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/test/Makefile
   creating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/test/tools/
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/test/tools/Makefile
  inflating: epicsBaseOwnPlayground-3afec267ab08568ea454789e562450b00feea5c0/test/tools/Snippets.plt
+ tar_exit=0
/home/mritunjay/development/rtems/src/rsb_GSoC/rtems/build/epics-3afec267ab08568ea454789e562450b00feea5c0-x86_64-linux-gnu-1/do-build: 90: cd: can't cd to epics-3afec267ab08568ea454789e562450b00feea5c0
shell cmd failed: /bin/sh -ex  /home/mritunjay/development/rtems/src/rsb_GSoC/rtems/build/epics-3afec267ab08568ea454789e562450b00feea5c0-x86_64-linux-gnu-1/do-build
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200721/e7bbe89d/attachment-0001.obj>
