[PATCH 04/33] libtest: Add T_get_one_clock_tick_busy()
Sebastian Huber
Tue Jul 21 15:04:21 UTC 2020
Update #3199.
cpukit/Makefile.am | 1 +
cpukit/include/rtems/simple-test.h | 6 -
cpukit/include/rtems/test.h | 2 +
cpukit/libtest/t-test-busy-tick.c | 121 ++++++++++++++++++
cpukit/libtest/testbusy.c | 73 -----------
.../spintrcritical_support/intrcritical.c | 2 +-
6 files changed, 125 insertions(+), 80 deletions(-)
create mode 100644 cpukit/libtest/t-test-busy-tick.c
diff --git a/cpukit/Makefile.am b/cpukit/Makefile.am
index 7f89f6a283..a119055abb 100644
--- a/cpukit/Makefile.am
+++ b/cpukit/Makefile.am
@@ -1858,6 +1858,7 @@ librtemstest_a_SOURCES += libtest/testparallel.c
librtemstest_a_SOURCES += libtest/testwrappers.c
librtemstest_a_SOURCES += libtest/t-test.c
librtemstest_a_SOURCES += libtest/t-test-busy.c
+librtemstest_a_SOURCES += libtest/t-test-busy-tick.c
librtemstest_a_SOURCES += libtest/t-test-checks.c
librtemstest_a_SOURCES += libtest/t-test-checks-eno.c
librtemstest_a_SOURCES += libtest/t-test-checks-psx.c
diff --git a/cpukit/include/rtems/simple-test.h b/cpukit/include/rtems/simple-test.h
index 5f73e92055..42f5235af8 100644
--- a/cpukit/include/rtems/simple-test.h
+++ b/cpukit/include/rtems/simple-test.h
@@ -304,12 +304,6 @@ void rtems_test_parallel(
void rtems_test_busy_cpu_usage(time_t seconds, long nanoseconds);
- * @brief Returns a count value for T_busy() which yields roughly a
- * duration of one clock tick.
-uint_fast32_t rtems_test_get_one_tick_busy_count(void);
#ifdef __cplusplus
diff --git a/cpukit/include/rtems/test.h b/cpukit/include/rtems/test.h
index 4c14e8d217..b68f303e16 100644
--- a/cpukit/include/rtems/test.h
+++ b/cpukit/include/rtems/test.h
@@ -2263,6 +2263,8 @@ void T_case_body_##name(void)
void T_busy(uint_fast32_t);
+uint_fast32_t T_get_one_clock_tick_busy(void);
void T_report_hash_sha256(T_event, const char *);
void T_check_heap(T_event, const char *);
diff --git a/cpukit/libtest/t-test-busy-tick.c b/cpukit/libtest/t-test-busy-tick.c
new file mode 100644
index 0000000000..3613f8ed72
--- /dev/null
+++ b/cpukit/libtest/t-test-busy-tick.c
@@ -0,0 +1,121 @@
+ * @file
+ * @ingroup RTEMSTestFrameworkImpl
+ * @brief Implementation of T_get_one_clock_tick_busy().
+ * Copyright (C) 2014, 2020 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/test.h>
+#include <rtems.h>
+static uint_fast32_t
+T_estimate_busy_loop_maximum(void)
+ uint_fast32_t initial;
+ uint_fast32_t units;
+ initial = rtems_clock_get_ticks_since_boot();
+ units = 0;
+ while (initial == rtems_clock_get_ticks_since_boot()) {
+ ++units;
+ return units;
+T_wait_for_tick_change(void)
+ uint_fast32_t now;
+ do {
+ now = rtems_clock_get_ticks_since_boot();
+ } while (now == initial);
+ return now;
+uint_fast32_t
+T_get_one_clock_tick_busy(void)
+ uint_fast32_t last;
+ uint_fast32_t a;
+ uint_fast32_t b;
+ uint_fast32_t m;
+ /* Choose a lower bound */
+ a = 1;
+ /* Estimate an upper bound */
+ T_wait_for_tick_change();
+ b = 2 * T_estimate_busy_loop_maximum();
+ while (true) {
+ last = T_wait_for_tick_change();
+ T_busy(b);
+ if (now != last) {
+ break;
+ b *= 2;
+ last = now;
+ /* Find a good value */
+ do {
+ m = (a + b) / 2;
+ T_busy(m);
+ b = m;
+ } else {
+ a = m;
+ } while (b - a > 1);
+ return m;
diff --git a/cpukit/libtest/testbusy.c b/cpukit/libtest/testbusy.c
index 68a38fbbf9..7122a3ecf8 100644
--- a/cpukit/libtest/testbusy.c
+++ b/cpukit/libtest/testbusy.c
@@ -18,81 +18,8 @@
#endif
#include <rtems/simple-test.h>
-#include <rtems.h>
-#include <rtems/test.h>
-static uint_fast32_t estimate_busy_loop_maximum( void )
- uint_fast32_t units = 0;
- uint_fast32_t initial = rtems_clock_get_ticks_since_boot();
- while ( initial == rtems_clock_get_ticks_since_boot() ) {
- ++units;
- return units;
-static uint_fast32_t wait_for_tick_change( void )
- uint_fast32_t now;
- do {
- now = rtems_clock_get_ticks_since_boot();
- } while ( now == initial );
- return now;
-uint_fast32_t rtems_test_get_one_tick_busy_count( void )
- uint_fast32_t last;
- uint_fast32_t a;
- uint_fast32_t b;
- uint_fast32_t m;
- /* Choose a lower bound */
- a = 1;
- /* Estimate an upper bound */
- wait_for_tick_change();
- b = 2 * estimate_busy_loop_maximum();
- while ( true ) {
- last = wait_for_tick_change();
- T_busy( b );
- if ( now != last ) {
- break;
- b *= 2;
- last = now;
- /* Find a good value */
- do {
- m = ( a + b ) / 2;
- T_busy( m );
- b = m;
- } else {
- a = m;
- } while ( b - a > 1 );
- return m;
void rtems_test_busy_cpu_usage( time_t seconds, long nanoseconds )
Thread_Control *executing;
diff --git a/testsuites/sptests/spintrcritical_support/intrcritical.c b/testsuites/sptests/spintrcritical_support/intrcritical.c
index 9bce230d2a..b6c6dad169 100644
--- a/testsuites/sptests/spintrcritical_support/intrcritical.c
+++ b/testsuites/sptests/spintrcritical_support/intrcritical.c
@@ -71,7 +71,7 @@ void interrupt_critical_section_test_support_initialize(
rtems_test_assert( sc == RTEMS_SUCCESSFUL );
- m = rtems_test_get_one_tick_busy_count();
+ m = T_get_one_clock_tick_busy();
interrupt_critical.minimum = 0;
interrupt_critical.maximum = m;
2.26.2
