[PATCH 22/33] spintrcritical10: Use T_interrupt_test()
Sebastian Huber
Tue Jul 21 15:04:39 UTC 2020
testsuites/sptests/Makefile.am | 4 +-
testsuites/sptests/spintrcritical10/init.c | 198 +++++++-----------
.../spintrcritical10/spintrcritical10.scn | 33 ++-
3 files changed, 109 insertions(+), 126 deletions(-)
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 9f66b66371..ceea27565f 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -1260,9 +1260,7 @@ if TEST_spintrcritical10
sp_tests += spintrcritical10
sp_screens += spintrcritical10/spintrcritical10.scn
sp_docs += spintrcritical10/spintrcritical10.doc
-spintrcritical10_SOURCES = spintrcritical10/init.c \
- spintrcritical_support/intrcritical.c \
- spintrcritical_support/intrcritical.h
+spintrcritical10_SOURCES = spintrcritical10/init.c
spintrcritical10_CPPFLAGS = $(AM_CPPFLAGS) \
$(TEST_FLAGS_spintrcritical10) $(support_includes) \
-I$(top_srcdir)/spintrcritical_support
diff --git a/testsuites/sptests/spintrcritical10/init.c b/testsuites/sptests/spintrcritical10/init.c
index fff1991cbc..8210853588 100644
--- a/testsuites/sptests/spintrcritical10/init.c
+++ b/testsuites/sptests/spintrcritical10/init.c
@@ -2,7 +2,7 @@
* COPYRIGHT (c) 1989-2012.
* On-Line Applications Research Corporation (OAR).
- * Copyright (c) 2013 embedded brains GmbH.
+ * Copyright (c) 2013, 2020 embedded brains GmbH.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
@@ -14,13 +14,15 @@
#endif
#include <tmacros.h>
-#include <intrcritical.h>
+#include <rtems/test.h>
#include <rtems/rtems/eventimpl.h>
const char rtems_test_name[] = "SPINTRCRITICAL 10";
+#define MAX_ITERATION_COUNT 10000
#define GREEN RTEMS_EVENT_0
#define RED RTEMS_EVENT_1
@@ -30,9 +32,7 @@ const char rtems_test_name[] = "SPINTRCRITICAL 10";
#define DEADBEEF 0xdeadbeef
typedef struct {
- rtems_id timer;
Thread_Control *thread;
- bool hit;
} test_context;
static bool blocks_for_event(Thread_Wait_flags flags)
@@ -47,15 +47,20 @@ static bool interrupts_blocking_op(Thread_Wait_flags flags)
flags == (THREAD_WAIT_CLASS_EVENT | THREAD_WAIT_STATE_INTEND_TO_BLOCK);
-static void any_satisfy_before_timeout(rtems_id timer, void *arg)
+static T_interrupt_test_state any_satisfy_before_timeout_interrupt(void *arg)
rtems_status_code sc;
test_context *ctx = arg;
Thread_Control *thread = ctx->thread;
Thread_Wait_flags flags = _Thread_Wait_flags_get(thread);
+ T_interrupt_test_state state;
if (blocks_for_event(flags)) {
- ctx->hit = interrupts_blocking_op(flags);
+ if (interrupts_blocking_op(flags)) {
+ state = T_INTERRUPT_TEST_DONE;
+ } else {
+ state = T_INTERRUPT_TEST_LATE;
rtems_test_assert(
*(rtems_event_set *) thread->Wait.return_argument == DEADBEEF
@@ -85,7 +90,7 @@ static void any_satisfy_before_timeout(rtems_id timer, void *arg)
rtems_test_assert(_Thread_Wait_get_status(thread) == STATUS_SUCCESSFUL);
- if (ctx->hit) {
+ if (state == T_INTERRUPT_TEST_DONE) {
rtems_test_assert(
== (THREAD_WAIT_CLASS_EVENT | THREAD_WAIT_STATE_READY_AGAIN)
@@ -93,18 +98,20 @@ static void any_satisfy_before_timeout(rtems_id timer, void *arg)
rtems_test_assert(thread->Wait.count == EVENTS);
+ } else {
+ state = T_INTERRUPT_TEST_EARLY;
- sc = rtems_timer_reset(timer);
- rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ return state;
-static bool test_body_any_satisfy_before_timeout(void *arg)
+static void any_satisfy_before_timeout_action(void *arg)
- test_context *ctx = arg;
rtems_event_set out;
+ (void) arg;
out = DEADBEEF;
sc = rtems_event_receive(EVENTS, RTEMS_EVENT_ANY | RTEMS_WAIT, 1, &out);
@@ -114,45 +121,38 @@ static bool test_body_any_satisfy_before_timeout(void *arg)
sc = rtems_event_receive(EVENTS, RTEMS_EVENT_ANY | RTEMS_NO_WAIT, 0, &out);
rtems_test_assert(out == RED);
- return ctx->hit;
-static void test_any_satisfy_before_timeout(test_context *ctx)
- rtems_status_code sc;
- puts(
- "Init - Trying to generate any satisfied before timeout "
- "while blocking on event"
- ctx->hit = false;
- sc = rtems_timer_fire_after(ctx->timer, 1, any_satisfy_before_timeout, ctx);
- interrupt_critical_section_test(
- test_body_any_satisfy_before_timeout,
- ctx,
- NULL
+static const T_interrupt_test_config any_satisfy_before_timeout_config = {
+ .action = any_satisfy_before_timeout_action,
+ .interrupt = any_satisfy_before_timeout_interrupt,
+ .max_iteration_count = MAX_ITERATION_COUNT
- sc = rtems_timer_cancel(ctx->timer);
+T_TEST_CASE(EventAnySatisfyBeforeTimeout)
+ test_context ctx;
- rtems_test_assert(ctx->hit);
+ ctx.thread = _Thread_Get_executing();
+ state = T_interrupt_test(&any_satisfy_before_timeout_config, &ctx);
+ T_eq_int(state, T_INTERRUPT_TEST_DONE);
-static void all_satisfy_before_timeout(rtems_id timer, void *arg)
+static T_interrupt_test_state all_satisfy_before_timeout_interrupt(void *arg)
+ } else {
rtems_test_assert(
@@ -182,7 +182,7 @@ static void all_satisfy_before_timeout(rtems_id timer, void *arg)
- if (ctx->hit) {
rtems_test_assert(
@@ -190,15 +190,15 @@ static void all_satisfy_before_timeout(rtems_id timer, void *arg)
+ } else {
+ return state;
-static bool test_body_all_satisfy_before_timeout(void *arg)
+static void all_satisfy_before_timeout_action(void *arg)
@@ -206,45 +206,38 @@ static bool test_body_all_satisfy_before_timeout(void *arg)
sc = rtems_event_receive(EVENTS, RTEMS_EVENT_ALL | RTEMS_WAIT, 1, &out);
rtems_test_assert(out == EVENTS);
- return ctx->hit;
-static void test_all_satisfy_before_timeout(test_context *ctx)
- puts(
- "Init - Trying to generate all satisfied before timeout "
- ctx->hit = false;
+static const T_interrupt_test_config all_satisfy_before_timeout_config = {
+ .action = all_satisfy_before_timeout_action,
+ .interrupt = all_satisfy_before_timeout_interrupt,
- sc = rtems_timer_fire_after(ctx->timer, 1, all_satisfy_before_timeout, ctx);
- test_body_all_satisfy_before_timeout,
- ctx,
- NULL
+T_TEST_CASE(EventAllSatisfyBeforeTimeout)
+ test_context ctx;
+ state = T_interrupt_test(&all_satisfy_before_timeout_config, &ctx);
-static void timeout_before_satisfied(rtems_id timer, void *arg)
+static T_interrupt_test_state timeout_before_satisfied_interrupt(void *arg)
+ } else {
rtems_test_assert(
@@ -266,7 +259,7 @@ static void timeout_before_satisfied(rtems_id timer, void *arg)
rtems_test_assert(_Thread_Wait_get_status(thread) == STATUS_TIMEOUT);
- if (ctx->hit) {
rtems_test_assert(
@@ -274,15 +267,15 @@ static void timeout_before_satisfied(rtems_id timer, void *arg)
+ } else {
+ return state;
-static bool test_body_timeout_before_all_satisfy(void *arg)
+static void timeout_before_satisfied_action(void *arg)
@@ -295,56 +288,27 @@ static bool test_body_timeout_before_all_satisfy(void *arg)
sc = rtems_event_receive(EVENTS, RTEMS_EVENT_ALL | RTEMS_NO_WAIT, 0, &out);
- return ctx->hit;
-static void test_timeout_before_all_satisfy(test_context *ctx)
- puts(
- "Init - Trying to generate timeout before all satisfied "
- ctx->hit = false;
+static const T_interrupt_test_config timeout_before_satisfied_config = {
+ .action = timeout_before_satisfied_action,
+ .interrupt = timeout_before_satisfied_interrupt,
- sc = rtems_timer_fire_after(ctx->timer, 1, timeout_before_satisfied, ctx);
- test_body_timeout_before_all_satisfy,
- ctx,
- NULL
+T_TEST_CASE(EventTimeoutBeforeSatisfied)
+ test_context ctx;
+ state = T_interrupt_test(&timeout_before_satisfied_config, &ctx);
-static rtems_task Init(
- rtems_task_argument ignored
+static rtems_task Init( rtems_task_argument argument )
- test_context ctx = {
- .thread = _Thread_Get_executing()
- TEST_BEGIN();
- sc = rtems_timer_create(rtems_build_name('T', 'I', 'M', 'R'), &ctx.timer);
- test_any_satisfy_before_timeout(&ctx);
- test_all_satisfy_before_timeout(&ctx);
- test_timeout_before_all_satisfy(&ctx);
- TEST_END();
- rtems_test_exit(0);
+ rtems_test_run( argument, TEST_STATE );
/* configuration information */
@@ -353,8 +317,6 @@ static rtems_task Init(
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
#define CONFIGURE_MAXIMUM_TASKS 1
-#define CONFIGURE_MAXIMUM_TIMERS 1
-#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
diff --git a/testsuites/sptests/spintrcritical10/spintrcritical10.scn b/testsuites/sptests/spintrcritical10/spintrcritical10.scn
index e8db0c576a..968f052190 100644
--- a/testsuites/sptests/spintrcritical10/spintrcritical10.scn
+++ b/testsuites/sptests/spintrcritical10/spintrcritical10.scn
@@ -1,5 +1,28 @@
-*** TEST INTERRUPT CRITICAL SECTION 10 ***
-Init - Trying to generate any satisfied before timeout while blocking on event
-Init - Trying to generate all satisfied before timeout while blocking on event
-Init - Trying to generate timeout before all satisfied while blocking on event
-*** END OF TEST INTERRUPT CRITICAL SECTION 10 ***
+*** BEGIN OF TEST SPINTRCRITICAL 10 ***
+*** TEST VERSION: 6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD: RTEMS_DEBUG RTEMS_POSIX_API RTEMS_SMP
+*** TEST TOOLS: 10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+A:SPINTRCRITICAL 10
+S:Platform:RTEMS
+S:Compiler:10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+S:Version:6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+S:BSP:realview_pbx_a9_qemu
+S:RTEMS_DEBUG:1
+S:RTEMS_MULTIPROCESSING:0
+S:RTEMS_POSIX_API:1
+S:RTEMS_PROFILING:0
+S:RTEMS_SMP:1
+B:EventTimeoutBeforeSatisfied
+P:0:0:UI1:init.c:306
+E:EventTimeoutBeforeSatisfied:N:1:F:0:D:0.062089
+B:EventAnySatisfyBeforeTimeout
+P:0:0:UI1:init.c:139
+E:EventAnySatisfyBeforeTimeout:N:1:F:0:D:0.009101
+B:EventAllSatisfyBeforeTimeout
+P:0:0:UI1:init.c:224
+E:EventAllSatisfyBeforeTimeout:N:1:F:0:D:0.008658
+Z:SPINTRCRITICAL 10:C:3:N:3:F:0:D:0.081653
+Y:ReportHash:SHA256:e2da8e487b37934523fa5810dc7d76f8ca736168d3019b09db80edb40dffff34
+*** END OF TEST SPINTRCRITICAL 10 ***
2.26.2
