[PATCH 25/33] spintrcritical15: Use T_interrupt_test()
Sebastian Huber
Tue Jul 21 15:04:42 UTC 2020
testsuites/sptests/Makefile.am | 4 +-
testsuites/sptests/spintrcritical15/init.c | 133 ++++++++++++------
.../spintrcritical15/spintrcritical15.scn | 34 ++++-
3 files changed, 117 insertions(+), 54 deletions(-)
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 7dbc829ddf..0cf00f7fa6 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -1310,9 +1310,7 @@ if TEST_spintrcritical15
sp_tests += spintrcritical15
sp_screens += spintrcritical15/spintrcritical15.scn
sp_docs += spintrcritical15/spintrcritical15.doc
-spintrcritical15_SOURCES = spintrcritical15/init.c \
- spintrcritical_support/intrcritical.c \
- spintrcritical_support/intrcritical.h
+spintrcritical15_SOURCES = spintrcritical15/init.c
spintrcritical15_CPPFLAGS = $(AM_CPPFLAGS) \
$(TEST_FLAGS_spintrcritical15) $(support_includes) \
-I$(top_srcdir)/spintrcritical_support
diff --git a/testsuites/sptests/spintrcritical15/init.c b/testsuites/sptests/spintrcritical15/init.c
index 9de33b3cfb..ba917d2a0b 100644
--- a/testsuites/sptests/spintrcritical15/init.c
+++ b/testsuites/sptests/spintrcritical15/init.c
@@ -1,4 +1,6 @@
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
* COPYRIGHT (c) 1989-2009.
* On-Line Applications Research Corporation (OAR).
@@ -11,89 +13,133 @@
#include "config.h"
#endif
-#include <tmacros.h>
-#include <intrcritical.h>
+#include <rtems/test.h>
+#include <rtems/simple-test.h>
-const char rtems_test_name[] = "SPINTRCRITICAL 15";
+#include <rtems/score/threadimpl.h>
-/* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument argument);
-rtems_task Secondary_task(rtems_task_argument ignored);
+const char rtems_test_name[] = "SPINTRCRITICAL 15";
#define INIT_PRIORITY 2
#define BLOCKER_PRIORITY 1
-rtems_id Secondary_task_id;
-rtems_id Semaphore;
+typedef struct {
+ rtems_id secondary_task_id;
+ rtems_id semaphore;
+ Thread_Control *main_thread;
+} test_context;
- rtems_task_argument ignored
+static rtems_task Secondary_task( rtems_task_argument arg )
- rtems_status_code sc;
+ test_context *ctx;
+ rtems_status_code sc;
+ ctx = (test_context *) arg;
while (1) {
- sc = rtems_semaphore_obtain( Semaphore, RTEMS_DEFAULT_OPTIONS, 1 );
- fatal_directive_status( sc, RTEMS_TIMEOUT, "rtems_semaphore_obtain" );
+ sc = rtems_semaphore_obtain( ctx->semaphore, RTEMS_DEFAULT_OPTIONS, 1 );
+ T_quiet_rsc( sc, RTEMS_TIMEOUT );
-static bool test_body( void *arg )
+static T_interrupt_test_state interrupt(void *arg)
+ Thread_Wait_flags flags;
+ T_interrupt_test_state state;
+ ctx = arg;
+ flags = _Thread_Wait_flags_get( ctx->main_thread );
+ if (
+ flags == ( THREAD_WAIT_CLASS_OBJECT | THREAD_WAIT_STATE_INTEND_TO_BLOCK )
+ state = T_INTERRUPT_TEST_DONE;
+ } else if (
+ flags == ( THREAD_WAIT_CLASS_OBJECT | THREAD_WAIT_STATE_BLOCKED )
+ state = T_INTERRUPT_TEST_LATE;
+ } else {
+ state = T_INTERRUPT_TEST_EARLY;
- (void) arg;
+ return state;
- sc = rtems_task_restart( Secondary_task_id, 1 );
- rtems_test_assert( sc == RTEMS_SUCCESSFUL );
+static void prepare( void *arg )
- rtems_test_assert( sc == RTEMS_TIMEOUT );
+ ctx = arg;
+ sc = rtems_task_restart( ctx->secondary_task_id, (rtems_task_argument) ctx );
+ T_quiet_rsc_success( sc );
- return false;
+static void action( void *arg )
+ ctx = arg;
-rtems_task Init(
+static const T_interrupt_test_config config = {
+ .prepare = prepare,
+ .action = action,
+ .interrupt = interrupt,
+ .max_iteration_count = 10000
+T_TEST_CASE( SemaphoreObtainBlockedInterrupt )
+ test_context ctx;
- TEST_BEGIN();
- puts(
- "Init - Trying to generate timeout of a thread while another is blocking\n"
- "Init - on the same thread queue\n"
- "Init - There is no way for the test to know if it hits the case"
+ ctx.main_thread = _Thread_Get_executing();
- puts( "Init - rtems_semaphore_create - OK" );
sc = rtems_semaphore_create(
rtems_build_name( 'S', 'M', '1', ' ' ),
0,
RTEMS_DEFAULT_ATTRIBUTES,
RTEMS_NO_PRIORITY,
- &Semaphore
+ &ctx.semaphore
- directive_failed( sc, "rtems_semaphore_create of SM1" );
+ T_assert_rsc_success( sc );
- puts( "Init - rtems_task_create - OK" );
sc = rtems_task_create(
rtems_build_name( 'B', 'L', 'C', 'K' ),
BLOCKER_PRIORITY,
RTEMS_MINIMUM_STACK_SIZE,
RTEMS_NO_PREEMPT,
- &Secondary_task_id
+ &ctx.secondary_task_id
+ sc = rtems_task_start(
+ ctx.secondary_task_id,
+ Secondary_task,
+ (rtems_task_argument) &ctx
- directive_failed( sc, "rtems_task_create" );
+ state = T_interrupt_test( &config, &ctx );
+ T_eq_int( state, T_INTERRUPT_TEST_DONE );
- sc = rtems_task_start( Secondary_task_id, Secondary_task, 0 );
- directive_failed( sc, "rtems_task_start" );
+ sc = rtems_task_delete( ctx.secondary_task_id );
+ T_rsc_success( sc );
- interrupt_critical_section_test( test_body, NULL, NULL );
+ sc = rtems_semaphore_delete( ctx.semaphore );
- TEST_END();
- rtems_test_exit(0);
+static rtems_task Init( rtems_task_argument argument )
+ rtems_test_run( argument, TEST_STATE );
/* configuration information */
@@ -103,7 +149,6 @@ rtems_task Init(
#define CONFIGURE_MAXIMUM_TASKS 2
#define CONFIGURE_MAXIMUM_SEMAPHORES 1
-#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
#define CONFIGURE_MICROSECONDS_PER_TICK 1000
#define CONFIGURE_INIT_TASK_PRIORITY INIT_PRIORITY
#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_PREEMPT
diff --git a/testsuites/sptests/spintrcritical15/spintrcritical15.scn b/testsuites/sptests/spintrcritical15/spintrcritical15.scn
index ee8db40cdd..937b05ea24 100644
--- a/testsuites/sptests/spintrcritical15/spintrcritical15.scn
+++ b/testsuites/sptests/spintrcritical15/spintrcritical15.scn
@@ -1,7 +1,27 @@
-*** TEST INTERRUPT CRITICAL SECTION 15 ***
-Init - Trying to generate timeout of a thread while another is blocking
-Init - on the same thread queue
-Init - There is no way for the test to know if it hits the case
-Init - rtems_semaphore_create - OK
-Init - rtems_task_create - OK
-*** END OF TEST INTERRUPT CRITICAL SECTION 15 ***
+*** BEGIN OF TEST SPINTRCRITICAL 15 ***
+*** TEST VERSION: 6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD: RTEMS_DEBUG RTEMS_POSIX_API RTEMS_SMP
+*** TEST TOOLS: 10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+A:SPINTRCRITICAL 15
+S:Platform:RTEMS
+S:Compiler:10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+S:Version:6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+S:BSP:realview_pbx_a9_qemu
+S:RTEMS_DEBUG:1
+S:RTEMS_MULTIPROCESSING:0
+S:RTEMS_POSIX_API:1
+S:RTEMS_PROFILING:0
+S:RTEMS_SMP:1
+B:SemaphoreObtainBlockedInterrupt
+P:0:0:UI1:init.c:111
+P:1:0:UI1:init.c:121
+P:2:0:UI1:init.c:128
+P:3:0:UI1:init.c:131
+P:4:0:UI1:init.c:134
+P:5:0:UI1:init.c:137
+E:SemaphoreObtainBlockedInterrupt:N:6:F:0:D:0.063907
+Z:SPINTRCRITICAL 15:C:1:N:6:F:0:D:0.065120
+Y:ReportHash:SHA256:198a9452944e985b137ec4b427be51cef71af413f6e3bfdf03a2f29a9bd81259
+*** END OF TEST SPINTRCRITICAL 15 ***
2.26.2
