[PATCH 19/33] spintrcritical06/spintrcritical07: Remove tests
Tue Jul 21 15:04:36 UTC 2020
These two tests check conditions which no longer exist in the thread
queue implementation.  The are obsolete since the change to use
red-black trees for the priority queues.
 testsuites/sptests/Makefile.am                |  23 ---
 testsuites/sptests/configure.ac               |   2 -
 testsuites/sptests/spintrcritical06/init.c    |   2 -
 .../spintrcritical06/spintrcritical06.doc     |  28 ----
 .../spintrcritical06/spintrcritical06.scn     |   6 -
 .../spintrcritical06/spintrcritical06impl.h   | 145 ------------------
 testsuites/sptests/spintrcritical07/init.c    |   2 -
 .../spintrcritical07/spintrcritical07.doc     |  28 ----
 .../spintrcritical07/spintrcritical07.scn     |   6 -
 9 files changed, 242 deletions(-)
 delete mode 100644 testsuites/sptests/spintrcritical06/init.c
 delete mode 100644 testsuites/sptests/spintrcritical06/spintrcritical06.doc
 delete mode 100644 testsuites/sptests/spintrcritical06/spintrcritical06.scn
 delete mode 100644 testsuites/sptests/spintrcritical06/spintrcritical06impl.h
 delete mode 100644 testsuites/sptests/spintrcritical07/init.c
 delete mode 100644 testsuites/sptests/spintrcritical07/spintrcritical07.doc
 delete mode 100644 testsuites/sptests/spintrcritical07/spintrcritical07.scn
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 3bdb0fe232..bbfabbaa36 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -1236,29 +1236,6 @@ spintrcritical05_CPPFLAGS = $(AM_CPPFLAGS) \
 	-I$(top_srcdir)/spintrcritical_support
 endif
-if TEST_spintrcritical06
-sp_tests += spintrcritical06
-sp_screens += spintrcritical06/spintrcritical06.scn
-sp_docs += spintrcritical06/spintrcritical06.doc
-spintrcritical06_SOURCES = spintrcritical06/init.c \
-	spintrcritical_support/intrcritical.c \
-	spintrcritical_support/intrcritical.h
-spintrcritical06_CPPFLAGS = $(AM_CPPFLAGS) \
-	$(TEST_FLAGS_spintrcritical06) $(support_includes) \
-	-I$(top_srcdir)/spintrcritical_support
-endif
-if TEST_spintrcritical07
-sp_tests += spintrcritical07
-sp_screens += spintrcritical07/spintrcritical07.scn
-sp_docs += spintrcritical07/spintrcritical07.doc
-spintrcritical07_SOURCES = spintrcritical07/init.c \
-spintrcritical07_CPPFLAGS = $(AM_CPPFLAGS) \
-	$(TEST_FLAGS_spintrcritical07) $(support_includes) \
-endif
 if TEST_spintrcritical08
 sp_tests += spintrcritical08
 sp_screens += spintrcritical08/spintrcritical08.scn
diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
index 9476e3b0d7..460917dd04 100644
--- a/testsuites/sptests/configure.ac
+++ b/testsuites/sptests/configure.ac
@@ -174,8 +174,6 @@ RTEMS_TEST_CHECK([spintrcritical02])
 RTEMS_TEST_CHECK([spintrcritical03])
 RTEMS_TEST_CHECK([spintrcritical04])
 RTEMS_TEST_CHECK([spintrcritical05])
-RTEMS_TEST_CHECK([spintrcritical06])
-RTEMS_TEST_CHECK([spintrcritical07])
 RTEMS_TEST_CHECK([spintrcritical08])
 RTEMS_TEST_CHECK([spintrcritical09])
 RTEMS_TEST_CHECK([spintrcritical10])
diff --git a/testsuites/sptests/spintrcritical06/init.c b/testsuites/sptests/spintrcritical06/init.c
deleted file mode 100644
index d8fedae772..0000000000
--- a/testsuites/sptests/spintrcritical06/init.c
+++ /dev/null
@@ -1,2 +0,0 @@
-#define PRIORITY_NO_TIMEOUT_FORWARD
-#include "spintrcritical06impl.h"
diff --git a/testsuites/sptests/spintrcritical06/spintrcritical06.doc b/testsuites/sptests/spintrcritical06/spintrcritical06.doc
index 6100a91218..0000000000
--- a/testsuites/sptests/spintrcritical06/spintrcritical06.doc
+++ /dev/null
@@ -1,28 +0,0 @@
-#  COPYRIGHT (c) 1989-2009.
-#  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.org/license/LICENSE.
-This file describes the directives and concepts tested by this test set.
-test set name:  spintrcritical06
-directives:
-  _Thread_queue_Enqueue_priority
-    - interrupt synchronization
-  rtems_task_restart
-  _Thread_queue_Extract_priority
-concepts:
-+ Ensure that removing the "search task" from the thread queue while we
-  are looping and enqueuing another works as expected.  This case is where
-  the TCB we are using as a current pointer is removed from the thread queue
-  when we flash interrupts WHILE SEARCHING FORWARD.
-NOTE: There is no way to know this case is hit from a test perspective.  The
-      test just runs and we check the coverage report.
diff --git a/testsuites/sptests/spintrcritical06/spintrcritical06.scn b/testsuites/sptests/spintrcritical06/spintrcritical06.scn
index fdcf91c4f1..0000000000
--- a/testsuites/sptests/spintrcritical06/spintrcritical06.scn
+++ /dev/null
@@ -1,6 +0,0 @@
-*** TEST INTERRUPT CRITICAL SECTION 06 ***
-Init - Trying to generate semaphore release from ISR while blocking
-Init - There is no way for the test to know if it hits the case
-Init - Variation is: Priority/Restart Search Task (Forward)
-Support - rtems_timer_create - creating timer 1
-*** END OF TEST INTERRUPT CRITICAL SECTION 06 ***
diff --git a/testsuites/sptests/spintrcritical06/spintrcritical06impl.h b/testsuites/sptests/spintrcritical06/spintrcritical06impl.h
index f0424e3dc8..0000000000
--- a/testsuites/sptests/spintrcritical06/spintrcritical06impl.h
+++ /dev/null
@@ -1,145 +0,0 @@
- *  COPYRIGHT (c) 1989-2012.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#include <tmacros.h>
-#include <intrcritical.h>
-/* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument argument);
-rtems_timer_service_routine test_release_from_isr(rtems_id  timer, void *arg);
-rtems_task Secondary_task(rtems_task_argument arg);
-/* common parameters */
-#define SEMAPHORE_ATTRIBUTES     RTEMS_PRIORITY
-#if defined(PRIORITY_NO_TIMEOUT_FORWARD)
-  #define TEST_NAME          "6"
-  #define TEST_STRING        "Priority/Restart Search Task (Forward)"
-  #define INIT_PRIORITY      2
-  #define BLOCKER_PRIORITY   1
-  #define SEMAPHORE_OBTAIN_TIMEOUT 2
-#elif defined(PRIORITY_NO_TIMEOUT_REVERSE)
-  #define TEST_NAME          "7"
-  #define TEST_STRING        "Priority/Restart Search Task (Backward)"
-  #define INIT_PRIORITY      126
-  #define BLOCKER_PRIORITY   127
-  #define SEMAPHORE_OBTAIN_TIMEOUT 0
-#else
-  #error "Test Mode not defined"
-#endif
-const char rtems_test_name[] = "SPINTRCRITICAL " TEST_NAME;
-rtems_id Secondary_task_id;
-rtems_id Semaphore;
-  rtems_id  timer,
-  void     *arg
-  (void) rtems_task_restart( Secondary_task_id, 1 );
-  rtems_task_argument arg
-  if ( arg )
-    (void) rtems_semaphore_flush( Semaphore );
-  (void) rtems_semaphore_obtain(
-    Semaphore,
-    RTEMS_DEFAULT_OPTIONS,
-    RTEMS_NO_TIMEOUT
-  rtems_test_assert(0);
-static bool test_body( void *arg )
-  (void) arg;
-  rtems_semaphore_obtain(
-    Semaphore,
-    SEMAPHORE_OBTAIN_TIMEOUT
-  return false;
-rtems_task Init(
-  rtems_task_argument ignored
-  rtems_status_code     status;
-  TEST_BEGIN();
-  puts( "Init - Trying to generate semaphore release from ISR while blocking" );
-  puts( "Init - There is no way for the test to know if it hits the case" );
-  puts( "Init - Variation is: " TEST_STRING );
-  status = rtems_semaphore_create(
-    rtems_build_name( 'S', 'M', '1', ' ' ),
-    0,
-    SEMAPHORE_ATTRIBUTES,
-    RTEMS_NO_PRIORITY,
-    &Semaphore
-  directive_failed( status, "rtems_semaphore_create of SM1" );
-  status = rtems_task_create(
-    rtems_build_name( 'B', 'L', 'C', 'K' ),
-    BLOCKER_PRIORITY,
-    RTEMS_MINIMUM_STACK_SIZE,
-    RTEMS_NO_PREEMPT,
-    RTEMS_DEFAULT_ATTRIBUTES,
-    &Secondary_task_id
-  directive_failed( status, "rtems_task_create" );
-  status = rtems_task_start( Secondary_task_id, Secondary_task, 0 );
-  directive_failed( status, "rtems_task_start" );
-  interrupt_critical_section_test( test_body, NULL, test_release_from_isr );
-  TEST_END();
-  rtems_test_exit(0);
-/* configuration information */
-#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS       2
-#define CONFIGURE_MAXIMUM_TIMERS      1
-#define CONFIGURE_MAXIMUM_SEMAPHORES  1
-#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
-#define CONFIGURE_INIT_TASK_PRIORITY  INIT_PRIORITY
-#define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_PREEMPT
-#define CONFIGURE_MICROSECONDS_PER_TICK  2000
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#include <rtems/confdefs.h>
-/* global variables */
diff --git a/testsuites/sptests/spintrcritical07/init.c b/testsuites/sptests/spintrcritical07/init.c
index 0c4f2a7f78..0000000000
--- a/testsuites/sptests/spintrcritical07/init.c
+++ /dev/null
@@ -1,2 +0,0 @@
-#define PRIORITY_NO_TIMEOUT_REVERSE
-#include "../spintrcritical06/spintrcritical06impl.h"
diff --git a/testsuites/sptests/spintrcritical07/spintrcritical07.doc b/testsuites/sptests/spintrcritical07/spintrcritical07.doc
index 2d8e2cd045..0000000000
--- a/testsuites/sptests/spintrcritical07/spintrcritical07.doc
+++ /dev/null
@@ -1,28 +0,0 @@
-test set name:  spintrcritical07
-directives:
-concepts:
diff --git a/testsuites/sptests/spintrcritical07/spintrcritical07.scn b/testsuites/sptests/spintrcritical07/spintrcritical07.scn
index 0f6dd8a3a3..0000000000
--- a/testsuites/sptests/spintrcritical07/spintrcritical07.scn
+++ /dev/null
@@ -1,6 +0,0 @@
-*** TEST INTERRUPT CRITICAL SECTION 07 ***
-Init - Variation is: Priority/Restart Search Task (Backward)
-*** END OF TEST INTERRUPT CRITICAL SECTION 07 ***
2.26.2
