[PATCH 20/33] spintrcritical08: Use T_interrupt_test()
Tue Jul 21 15:04:37 UTC 2020
 testsuites/sptests/Makefile.am                |   4 +-
 testsuites/sptests/spintrcritical08/init.c    | 165 +++++++++++-------
 .../spintrcritical08/spintrcritical08.scn     |  30 +++-
 3 files changed, 131 insertions(+), 68 deletions(-)
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index bbfabbaa36..4e3a3f0009 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -1240,9 +1240,7 @@ if TEST_spintrcritical08
 sp_tests += spintrcritical08
 sp_screens += spintrcritical08/spintrcritical08.scn
 sp_docs += spintrcritical08/spintrcritical08.doc
-spintrcritical08_SOURCES = spintrcritical08/init.c \
-	spintrcritical_support/intrcritical.c \
-	spintrcritical_support/intrcritical.h
+spintrcritical08_SOURCES = spintrcritical08/init.c
 spintrcritical08_CPPFLAGS = $(AM_CPPFLAGS) \
 	$(TEST_FLAGS_spintrcritical08) $(support_includes) \
 	-I$(top_srcdir)/spintrcritical_support
diff --git a/testsuites/sptests/spintrcritical08/init.c b/testsuites/sptests/spintrcritical08/init.c
index aab5701ed4..1191ca6f9c 100644
--- a/testsuites/sptests/spintrcritical08/init.c
+++ b/testsuites/sptests/spintrcritical08/init.c
@@ -1,4 +1,6 @@
+ *  Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
  *  COPYRIGHT (c) 1989-2012.
  *  On-Line Applications Research Corporation (OAR).
@@ -11,111 +13,158 @@
 #include "config.h"
 #endif
-#include <tmacros.h>
-#include <intrcritical.h>
+#include <string.h>
+#include <rtems/test.h>
+#include <rtems/simple-test.h>
 #include <rtems/rtems/ratemonimpl.h>
 const char rtems_test_name[] = "SPINTRCRITICAL 8";
-/* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument argument);
-static rtems_id Period;
-static volatile bool case_hit = false;
-static Thread_Control *thread;
+typedef struct {
+  rtems_id        period;
+  Thread_Control *thread;
+  volatile bool   early;
+  volatile bool   late;
+} test_context;
-static rtems_rate_monotonic_period_states getState(void)
+static rtems_rate_monotonic_period_states getState(test_context *ctx)
   Rate_monotonic_Control *the_period;
   ISR_lock_Context        lock_context;
-  the_period = _Rate_monotonic_Get( Period, &lock_context );
-  rtems_test_assert( the_period != NULL );
+  the_period = _Rate_monotonic_Get( ctx->period, &lock_context );
+  T_quiet_assert_not_null( the_period );
   _ISR_lock_ISR_enable( &lock_context );
   return the_period->state;
-static rtems_timer_service_routine test_release_from_isr(
-  rtems_id  timer,
-  void     *arg
+static T_interrupt_test_state interrupt( void *arg )
-  Per_CPU_Control *cpu = _Per_CPU_Get();
-  Watchdog_Header *header = &cpu->Watchdog.Header[ PER_CPU_WATCHDOG_TICKS ];
-  Watchdog_Control *watchdog = (Watchdog_Control *) header->first;
+  test_context           *ctx;
+  Per_CPU_Control        *cpu_self;
+  Watchdog_Header        *header;
+  Watchdog_Control       *watchdog;
+  T_interrupt_test_state  state;
+  state = T_interrupt_test_get_state();
+  if (state != T_INTERRUPT_TEST_ACTION) {
+    return T_INTERRUPT_TEST_CONTINUE;
+  ctx = arg;
+  cpu_self = _Per_CPU_Get();
+  header = &cpu_self->Watchdog.Header[ PER_CPU_WATCHDOG_TICKS ];
+  watchdog = (Watchdog_Control *) header->first;
   if (
     watchdog != NULL
-      && watchdog->expire == cpu->Watchdog.ticks
+      && watchdog->expire == cpu_self->Watchdog.ticks
       && watchdog->routine == _Rate_monotonic_Timeout
-    Thread_Wait_flags flags = _Thread_Wait_flags_get( thread );
+    Thread_Wait_flags flags = _Thread_Wait_flags_get( ctx->thread );
+    ISR_Level level;
-    _Watchdog_Per_CPU_remove_ticks( watchdog );
+    _ISR_Local_disable( level );
+    _Watchdog_Per_CPU_remove( watchdog, cpu_self, header );
+    _ISR_Local_enable( level );
-    rtems_test_assert( getState() == RATE_MONOTONIC_ACTIVE );
+    T_quiet_eq_int( getState( ctx ), RATE_MONOTONIC_ACTIVE );
     (*watchdog->routine)( watchdog );
     if ( flags == RATE_MONOTONIC_INTEND_TO_BLOCK ) {
-        _Thread_Wait_flags_get( thread ) == RATE_MONOTONIC_READY_AGAIN
+      T_quiet_eq(
+        _Thread_Wait_flags_get( ctx->thread ),
+        RATE_MONOTONIC_READY_AGAIN
-      case_hit = true;
+      state = T_INTERRUPT_TEST_DONE;
+    } else {
+      state = T_INTERRUPT_TEST_LATE;
+  } else {
+    if ( ctx->early ) {
+      state = T_INTERRUPT_TEST_EARLY;
+    } else if ( ctx->late ) {
+    } else {
+      state = T_INTERRUPT_TEST_CONTINUE;
+  return state;
-static bool test_body( void *arg )
+static void prepare( void *arg )
   rtems_status_code sc;
-  (void) arg;
+  ctx = arg;
+  ctx->early = true;
+  ctx->late = false;
-  sc = rtems_rate_monotonic_cancel( Period );
-  rtems_test_assert( sc == RTEMS_SUCCESSFUL );
+  sc = rtems_rate_monotonic_cancel( ctx->period );
+  T_quiet_rsc_success( sc );
-  sc = rtems_rate_monotonic_period( Period, 1 );
-  rtems_test_assert( sc == RTEMS_SUCCESSFUL || sc == RTEMS_TIMEOUT );
-  return case_hit;
+  sc = rtems_rate_monotonic_period( ctx->period, 1 );
-rtems_task Init(
-  rtems_task_argument ignored
+static void action( void *arg )
-  rtems_status_code     sc;
+  rtems_status_code sc;
-  TEST_BEGIN();
+  ctx = arg;
+  ctx->early = false;
+  sc = rtems_rate_monotonic_period( ctx->period, 2 );
+  ctx->late = true;
+  T_quiet_true( sc == RTEMS_SUCCESSFUL || sc == RTEMS_TIMEOUT );
-  puts( "Init - Trying to generate period ending while blocking" );
+  do {
+  } while (state == T_INTERRUPT_TEST_ACTION);
-  thread = _Thread_Get_executing();
+static const T_interrupt_test_config config = {
+  .prepare = prepare,
+  .action = action,
+  .interrupt = interrupt,
+  .max_iteration_count = 10000
+T_TEST_CASE(RateMonotonicPeriodInterrupt)
+  test_context ctx;
+  memset( &ctx, 0 , sizeof( ctx ) );
+  ctx.thread = _Thread_Get_executing();
-  puts( "Init - rtems_rate_monotonic_create - OK" );
   sc = rtems_rate_monotonic_create(
     rtems_build_name( 'P', 'E', 'R', '1' ),
-    &Period
+    &ctx.period
-  directive_failed( sc, "rtems_rate_monotonic_create" );
+  T_rsc_success( sc );
-  interrupt_critical_section_test( test_body, NULL, test_release_from_isr );
+  state = T_interrupt_test( &config, &ctx );
+  T_eq_int( state, T_INTERRUPT_TEST_DONE );
-  if ( case_hit ) {
-    puts( "Init - It appears the case has been hit" );
-    TEST_END();
-  } else
-    puts( "Init - Case not hit - ran too long" );
-  rtems_test_exit(0);
+  sc = rtems_rate_monotonic_delete( ctx.period );
+static rtems_task Init( rtems_task_argument argument )
+  rtems_test_run( argument, TEST_STATE );
 /* configuration information */
@@ -123,10 +172,8 @@ rtems_task Init(
 #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS       2
-#define CONFIGURE_MAXIMUM_TIMERS      1
+#define CONFIGURE_MAXIMUM_TASKS       1
 #define CONFIGURE_MAXIMUM_PERIODS     1
-#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
 #define CONFIGURE_MICROSECONDS_PER_TICK  1000
 #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
diff --git a/testsuites/sptests/spintrcritical08/spintrcritical08.scn b/testsuites/sptests/spintrcritical08/spintrcritical08.scn
index 86aa7fad54..c9791a9e42 100644
--- a/testsuites/sptests/spintrcritical08/spintrcritical08.scn
+++ b/testsuites/sptests/spintrcritical08/spintrcritical08.scn
@@ -1,6 +1,24 @@
-*** TEST INTERRUPT CRITICAL SECTION 08 ***
-Init - Trying to generate period ending while blocking
-Init - rtems_rate_monotonic_create - OK
-Support - rtems_timer_create - creating timer 1
-Init - It appears the case has been hit
-*** END OF TEST INTERRUPT CRITICAL SECTION 08 ***
+*** BEGIN OF TEST SPINTRCRITICAL 8 ***
+*** TEST VERSION: 6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD: RTEMS_DEBUG RTEMS_POSIX_API RTEMS_SMP
+*** TEST TOOLS: 10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+A:SPINTRCRITICAL 8
+S:Platform:RTEMS
+S:Compiler:10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+S:Version:6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+S:BSP:realview_pbx_a9_qemu
+S:RTEMS_DEBUG:1
+S:RTEMS_MULTIPROCESSING:0
+S:RTEMS_POSIX_API:1
+S:RTEMS_PROFILING:0
+S:RTEMS_SMP:1
+B:RateMonotonicPeriodInterrupt
+P:0:0:UI1:init.c:156
+P:1:0:UI1:init.c:159
+P:2:0:UI1:init.c:162
+E:RateMonotonicPeriodInterrupt:N:3:F:0:D:0.057652
+Z:SPINTRCRITICAL 8:C:1:N:3:F:0:D:0.058758
+Y:ReportHash:SHA256:381af5dc18c561d18b7b3ead593defa1aef4835f918df9edee7fe1ded0e089da
+*** END OF TEST SPINTRCRITICAL 8 ***
2.26.2
