[PATCH 29/33] spintrcritical21: Use T_interrupt_test()
Sebastian Huber
Tue Jul 21 15:04:46 UTC 2020
testsuites/sptests/Makefile.am | 3 +-
testsuites/sptests/spintrcritical21/init.c | 220 ++++++++++--------
.../spintrcritical21/spintrcritical21.scn | 27 ++-
testsuites/sptests/spintrcritical21/system.h | 39 ----
4 files changed, 149 insertions(+), 140 deletions(-)
delete mode 100644 testsuites/sptests/spintrcritical21/system.h
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 56e7da0462..78fe657051 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -1350,8 +1350,7 @@ if TEST_spintrcritical21
sp_tests += spintrcritical21
sp_screens += spintrcritical21/spintrcritical21.scn
sp_docs += spintrcritical21/spintrcritical21.doc
-spintrcritical21_SOURCES = spintrcritical21/init.c \
- spintrcritical_support/intrcritical.c
+spintrcritical21_SOURCES = spintrcritical21/init.c
spintrcritical21_CPPFLAGS = $(AM_CPPFLAGS) \
$(TEST_FLAGS_spintrcritical21) $(support_includes) \
-I$(top_srcdir)/spintrcritical_support
diff --git a/testsuites/sptests/spintrcritical21/init.c b/testsuites/sptests/spintrcritical21/init.c
index faa48f717c..b265d7b641 100644
--- a/testsuites/sptests/spintrcritical21/init.c
+++ b/testsuites/sptests/spintrcritical21/init.c
@@ -1,6 +1,8 @@
* Classic API Signal to Task from ISR
+ * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
* COPYRIGHT (c) 1989-2011.
* On-Line Applications Research Corporation (OAR).
@@ -13,67 +15,74 @@
#include "config.h"
#endif
-#define CONFIGURE_INIT
-#include "system.h"
-#include <intrcritical.h>
+#include <rtems/test.h>
+#include <rtems/simple-test.h>
#include <rtems/rtems/eventimpl.h>
const char rtems_test_name[] = "SPINTRCRITICAL 21";
- * ERROR CHECKING NOTE:
- * We are either at dispatch disable level 1 or 2. Either way, it is
- * safer not to check the dispatch level explicitly so we are using
- * fatal_directive_check_status_only() not directive_failed().
-static volatile bool case_hit;
+#define MAX_ITERATION_COUNT 10000
-static rtems_id main_task;
+typedef struct {
+ rtems_id main_task;
+ Thread_Control *main_thread;
+ rtems_id other_task;
+} test_context;
-static Thread_Control *main_thread;
-static rtems_id other_task;
+static bool is_blocked( Thread_Wait_flags flags )
+ return flags == ( THREAD_WAIT_CLASS_EVENT | THREAD_WAIT_STATE_BLOCKED );
-static bool is_case_hit( void )
+static bool interrupts_blocking_op( Thread_Wait_flags flags )
- return _Thread_Wait_flags_get( main_thread)
+ return flags
== ( THREAD_WAIT_CLASS_EVENT | THREAD_WAIT_STATE_INTEND_TO_BLOCK );
-static rtems_timer_service_routine test_event_from_isr(
- rtems_id timer,
- void *arg
+static T_interrupt_test_state event_from_isr_interrupt(
+ void *arg
- rtems_status_code status;
+ test_context *ctx;
+ T_interrupt_test_state state;
+ Thread_Wait_flags flags;
+ rtems_status_code status;
- if ( is_case_hit() ) {
+ ctx = arg;
+ flags = _Thread_Wait_flags_get( ctx->main_thread );
+ if ( interrupts_blocking_op( flags ) ) {
* This event send hits the critical section but sends to
* another task so doesn't impact this critical section.
- status = rtems_event_send( other_task, 0x02 );
- fatal_directive_check_status_only( status, RTEMS_SUCCESSFUL, "event send" );
+ status = rtems_event_send( ctx->other_task, 0x02 );
+ T_quiet_rsc_success( status );
* This event send hits the main task but doesn't satisfy
* it's blocking condition so it will still block
- status = rtems_event_send( main_task, 0x02 );
- case_hit = true;
+ status = rtems_event_send( ctx->main_task, 0x02 );
+ state = T_INTERRUPT_TEST_DONE;
+ } else if ( is_blocked( flags ) ) {
+ state = T_INTERRUPT_TEST_LATE;
+ } else {
+ state = T_INTERRUPT_TEST_EARLY;
- status = rtems_event_send( main_task, 0x01 );
+ status = rtems_event_send( ctx->main_task, 0x01 );
+ return state;
-static bool test_body_event_from_isr( void *arg )
+static void event_from_isr_action( void *arg )
rtems_event_set out;
@@ -81,30 +90,72 @@ static bool test_body_event_from_isr( void *arg )
(void) arg;
status = rtems_event_receive( 0x01, RTEMS_DEFAULT_OPTIONS, 0, &out );
- rtems_test_assert( status == RTEMS_SUCCESSFUL );
+static const T_interrupt_test_config event_from_isr_config = {
+ .action = event_from_isr_action,
+ .interrupt = event_from_isr_interrupt,
+ .max_iteration_count = MAX_ITERATION_COUNT
+T_TEST_CASE(EventFromISR)
+ test_context ctx;
+ ctx.main_task = rtems_task_self();
+ ctx.main_thread = _Thread_Get_executing();
+ status = rtems_task_create(
+ 0xa5a5a5a5,
+ 1,
+ RTEMS_MINIMUM_STACK_SIZE,
+ RTEMS_DEFAULT_MODES,
+ RTEMS_DEFAULT_ATTRIBUTES,
+ &ctx.other_task
+ T_assert_rsc_success( status );
+ state = T_interrupt_test( &event_from_isr_config, &ctx );
+ T_eq_int( state, T_INTERRUPT_TEST_DONE );
- return case_hit;
+ status = rtems_task_delete( ctx.other_task );
+ T_rsc_success( status );
-static rtems_timer_service_routine test_event_with_timeout_from_isr(
- rtems_id timer,
- void *arg
+static T_interrupt_test_state event_with_timeout_from_isr_interrupt(
+ void *arg
+ ctx = arg;
* We want to catch the task while it is blocking. Otherwise
* just send and make it happy.
- case_hit = true;
+ } else {
+ return state;
-static bool test_body_event_with_timeout_from_isr( void *arg )
+static void event_with_timeout_from_isr_action( void *arg )
@@ -112,69 +163,44 @@ static bool test_body_event_with_timeout_from_isr( void *arg )
(void) arg;
status = rtems_event_receive( 0x01, RTEMS_DEFAULT_OPTIONS, 1, &out );
- rtems_test_assert( status == RTEMS_SUCCESSFUL || status == RTEMS_TIMEOUT );
- return case_hit;
+ T_quiet_true( status == RTEMS_SUCCESSFUL || status == RTEMS_TIMEOUT );
-rtems_task Init(
- rtems_task_argument argument
- TEST_BEGIN();
+static const T_interrupt_test_config event_with_timeout_from_isr_config = {
+ .action = event_with_timeout_from_isr_action,
+ .interrupt = event_with_timeout_from_isr_interrupt,
- main_task = rtems_task_self();
- main_thread = _Thread_Get_executing();
+T_TEST_CASE( EventWithTimeoutFromISR )
+ test_context ctx;
- status = rtems_task_create(
- 0xa5a5a5a5,
- 1,
- RTEMS_MINIMUM_STACK_SIZE,
- RTEMS_DEFAULT_MODES,
- RTEMS_DEFAULT_ATTRIBUTES,
- &other_task
- directive_failed( status, "rtems_task_create" );
+ ctx.other_task = 0xdeadbeef;
- * Test Event send successful from ISR -- receive is forever
+ state = T_interrupt_test( &event_with_timeout_from_isr_config, &ctx );
- case_hit = false;
- interrupt_critical_section_test(
- test_body_event_from_isr,
- NULL,
- test_event_from_isr
+static rtems_task Init( rtems_task_argument argument )
+ rtems_test_run( argument, TEST_STATE );
- printf(
- "Event sent from ISR hitting synchronization point has %soccurred\n",
- case_hit ? "" : "NOT "
+#define CONFIGURE_INIT
- rtems_test_assert( case_hit );
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
- * Test Event send successful from ISR -- receive has timeout
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
- case_hit = false;
- test_body_event_with_timeout_from_isr,
- NULL,
- test_event_with_timeout_from_isr
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
- printf(
- "Event sent from ISR (with timeout) hitting synchronization "
- "point has %soccurred\n",
+#define CONFIGURE_MICROSECONDS_PER_TICK 1000
+#define CONFIGURE_MAXIMUM_TASKS 2
- TEST_END();
- rtems_test_exit( 0 );
+#include <rtems/confdefs.h>
diff --git a/testsuites/sptests/spintrcritical21/spintrcritical21.scn b/testsuites/sptests/spintrcritical21/spintrcritical21.scn
index d7a1998d0a..f20fff9b69 100644
--- a/testsuites/sptests/spintrcritical21/spintrcritical21.scn
+++ b/testsuites/sptests/spintrcritical21/spintrcritical21.scn
@@ -1,4 +1,27 @@
*** BEGIN OF TEST SPINTRCRITICAL 21 ***
-Event sent from ISR hitting synchronization point has occurred
-Event sent from ISR (with timeout) hitting synchronization point has occurred
+*** TEST VERSION: 6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD: RTEMS_DEBUG RTEMS_POSIX_API RTEMS_SMP
+*** TEST TOOLS: 10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+A:SPINTRCRITICAL 21
+S:Platform:RTEMS
+S:Compiler:10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+S:Version:6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+S:BSP:realview_pbx_a9_qemu
+S:RTEMS_DEBUG:1
+S:RTEMS_MULTIPROCESSING:0
+S:RTEMS_POSIX_API:1
+S:RTEMS_PROFILING:0
+S:RTEMS_SMP:1
+B:EventWithTimeoutFromISR
+P:0:0:UI1:init.c:185
+E:EventWithTimeoutFromISR:N:1:F:0:D:0.990057
+B:EventFromISR
+P:0:0:UI1:init.c:119
+P:1:0:UI1:init.c:122
+P:2:0:UI1:init.c:125
+E:EventFromISR:N:3:F:0:D:0.042543
+Z:SPINTRCRITICAL 21:C:2:N:4:F:0:D:1.034216
+Y:ReportHash:SHA256:64aa73f53f6e67b5eb349f0dcf4e2246ce87d7e3e8c201f9ee26ec4e3bfc30f6
*** END OF TEST SPINTRCRITICAL 21 ***
diff --git a/testsuites/sptests/spintrcritical21/system.h b/testsuites/sptests/spintrcritical21/system.h
deleted file mode 100644
index 04b9050598..0000000000
--- a/testsuites/sptests/spintrcritical21/system.h
+++ /dev/null
@@ -1,39 +0,0 @@
-/* system.h
- * This include file contains information that is included in every
- * function in the test set.
- * COPYRIGHT (c) 1989-2007.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#include <tmacros.h>
-/* functions */
-rtems_task Init(
-/* configuration information */
-#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_MICROSECONDS_PER_TICK 1000
-#define CONFIGURE_MAXIMUM_TASKS 2
-#define CONFIGURE_MAXIMUM_TIMERS 1
-#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
-#include <rtems/confdefs.h>
-/* end of include file */
2.26.2
