[PATCH 28/33] spintrcritical20: Use T_interrupt_test()
Sebastian Huber
Tue Jul 21 15:04:45 UTC 2020
testsuites/sptests/Makefile.am | 3 +-
testsuites/sptests/spintrcritical20/init.c | 145 +++++++++++-------
.../spintrcritical20/spintrcritical20.scn | 32 +++-
3 files changed, 121 insertions(+), 59 deletions(-)
diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
index 5df21b89af..56e7da0462 100644
--- a/testsuites/sptests/Makefile.am
+++ b/testsuites/sptests/Makefile.am
@@ -1340,8 +1340,7 @@ if TEST_spintrcritical20
sp_tests += spintrcritical20
sp_screens += spintrcritical20/spintrcritical20.scn
sp_docs += spintrcritical20/spintrcritical20.doc
-spintrcritical20_SOURCES = spintrcritical20/init.c \
- spintrcritical_support/intrcritical.c
+spintrcritical20_SOURCES = spintrcritical20/init.c
spintrcritical20_CPPFLAGS = $(AM_CPPFLAGS) \
$(TEST_FLAGS_spintrcritical20) $(support_includes) \
-I$(top_srcdir)/spintrcritical_support
diff --git a/testsuites/sptests/spintrcritical20/init.c b/testsuites/sptests/spintrcritical20/init.c
index 60af3adebd..0ab2e15698 100644
--- a/testsuites/sptests/spintrcritical20/init.c
+++ b/testsuites/sptests/spintrcritical20/init.c
@@ -1,11 +1,5 @@
- * Copyright (c) 2013 embedded brains GmbH. All rights reserved.
- * embedded brains GmbH
- * Dornierstr. 4
- * 82178 Puchheim
- * Germany
- * <rtems at embedded-brains.de>
+ * Copyright (C) 2013, 2020 embedded brains GmbH (http://www.embedded-brains.de)
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
@@ -16,8 +10,11 @@
#include "config.h"
#endif
-#include <tmacros.h>
-#include <intrcritical.h>
+#include <string.h>
+#include <rtems/test.h>
+#include <rtems/simple-test.h>
@@ -36,10 +33,10 @@ typedef struct {
bool thread_queue_was_null;
bool status_was_successful;
bool status_was_timeout;
+ volatile bool early;
+ volatile bool late;
} test_context;
-static test_context ctx_instance;
static void semaphore_task(rtems_task_argument arg)
test_context *ctx = (test_context *) arg;
@@ -52,37 +49,63 @@ static void semaphore_task(rtems_task_argument arg)
RTEMS_WAIT,
RTEMS_NO_TIMEOUT
- rtems_test_assert(sc == RTEMS_SUCCESSFUL || sc == RTEMS_TIMEOUT);
+ T_quiet_true(sc == RTEMS_SUCCESSFUL || sc == RTEMS_TIMEOUT);
+static T_interrupt_test_state interrupt(void *arg)
+ test_context *ctx = arg;
+ T_interrupt_test_state state;
+ rtems_status_code sc;
+ state = T_interrupt_test_change_state(
+ T_INTERRUPT_TEST_ACTION,
+ if (state != T_INTERRUPT_TEST_ACTION) {
+ return T_INTERRUPT_TEST_CONTINUE;
+ sc = rtems_semaphore_release(ctx->semaphore_id);
+ T_quiet_rsc_success(sc);
+ if ( ctx->early ) {
+ state = T_INTERRUPT_TEST_EARLY;
+ } else if ( ctx->late ) {
+ state = T_INTERRUPT_TEST_LATE;
+ } else if (
+ ctx->thread_queue_was_null
+ && ctx->status_was_successful
+ && ctx->status_was_timeout
+ state = T_INTERRUPT_TEST_DONE;
+ } else {
+ state = T_INTERRUPT_TEST_CONTINUE;
+ return state;
-static void release_semaphore(rtems_id timer, void *arg)
+static void prepare(void *arg)
- /* The arg is NULL */
- test_context *ctx = &ctx_instance;
- rtems_status_code sc = rtems_semaphore_release(ctx->semaphore_id);
- rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+ ctx->early = true;
+ ctx->late = false;
-static bool test_body(void *arg)
+static void action(void *arg)
- int busy;
Per_CPU_Control *cpu_self;
cpu_self = _Thread_Dispatch_disable();
+ ctx->early = false;
- _Thread_Wait_get_status( ctx->semaphore_task_tcb ) == STATUS_SUCCESSFUL
- * Spend some time to make it more likely that we hit the test condition
- * below.
- for (busy = 0; busy < 1000; ++busy) {
- __asm__ volatile ("");
+ T_quiet_rsc_success(_Thread_Wait_get_status( ctx->semaphore_task_tcb ));
if (ctx->semaphore_task_tcb->Wait.queue == NULL) {
ctx->thread_queue_was_null = true;
@@ -98,34 +121,42 @@ static bool test_body(void *arg)
ctx->status_was_timeout = true;
break;
default:
- rtems_test_assert(0);
+ T_unreachable();
break;
+ ctx->late = true;
_Thread_Dispatch_enable(cpu_self);
- return ctx->thread_queue_was_null
- && ctx->status_was_successful
- && ctx->status_was_timeout;
+ do {
+ state = T_interrupt_test_get_state();
+ } while (state == T_INTERRUPT_TEST_ACTION);
-static void Init(rtems_task_argument ignored)
+static const T_interrupt_test_config config = {
+ .prepare = prepare,
+ .action = action,
+ .interrupt = interrupt,
+ .max_iteration_count = 10000
+T_TEST_CASE(SemaphoreObtainTimeoutInterrupt)
+ test_context ctx;
- TEST_BEGIN();
- ctx->master_task = rtems_task_self();
+ memset(&ctx, 0, sizeof(ctx));
+ ctx.master_task = rtems_task_self();
sc = rtems_semaphore_create(
rtems_build_name('S', 'E', 'M', 'A'),
1,
RTEMS_COUNTING_SEMAPHORE,
0,
- &ctx->semaphore_id
+ &ctx.semaphore_id
+ T_assert_rsc_success(sc);
sc = rtems_task_create(
@@ -133,26 +164,34 @@ static void Init(rtems_task_argument ignored)
RTEMS_MINIMUM_STACK_SIZE,
RTEMS_DEFAULT_MODES,
RTEMS_DEFAULT_ATTRIBUTES,
- &ctx->semaphore_task
+ &ctx.semaphore_task
sc = rtems_task_start(
- ctx->semaphore_task,
+ ctx.semaphore_task,
semaphore_task,
- (rtems_task_argument) ctx
+ (rtems_task_argument) &ctx
- interrupt_critical_section_test(test_body, ctx, release_semaphore);
+ state = T_interrupt_test(&config, &ctx);
+ T_eq_int(state, T_INTERRUPT_TEST_DONE);
- rtems_test_assert(ctx->thread_queue_was_null);
- rtems_test_assert(ctx->status_was_successful);
- rtems_test_assert(ctx->status_was_timeout);
+ T_true(ctx.thread_queue_was_null);
+ T_true(ctx.status_was_successful);
+ T_true(ctx.status_was_timeout);
- TEST_END();
+ sc = rtems_task_delete(ctx.semaphore_task);
+ T_rsc_success(sc);
- rtems_test_exit(0);
+ sc = rtems_semaphore_delete(ctx.semaphore_id);
+static rtems_task Init(rtems_task_argument argument)
+ rtems_test_run(argument, TEST_STATE);
#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
@@ -162,8 +201,6 @@ static void Init(rtems_task_argument ignored)
#define CONFIGURE_MAXIMUM_SEMAPHORES 1
#define CONFIGURE_MAXIMUM_TASKS 2
-#define CONFIGURE_MAXIMUM_TIMERS 1
-#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
#define CONFIGURE_INIT_TASK_PRIORITY PRIORITY_MASTER
#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_DEFAULT_ATTRIBUTES
diff --git a/testsuites/sptests/spintrcritical20/spintrcritical20.scn b/testsuites/sptests/spintrcritical20/spintrcritical20.scn
index 867d2a26e3..7f5ec87aba 100644
--- a/testsuites/sptests/spintrcritical20/spintrcritical20.scn
+++ b/testsuites/sptests/spintrcritical20/spintrcritical20.scn
@@ -1,4 +1,30 @@
-*** TEST INTERRUPT CRITICAL SECTION 20 ***
+*** BEGIN OF TEST SPINTRCRITICAL 20 ***
+*** TEST VERSION: 6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+*** TEST STATE: EXPECTED_PASS
+*** TEST BUILD: RTEMS_DEBUG RTEMS_POSIX_API RTEMS_SMP
+*** TEST TOOLS: 10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+A:SPINTRCRITICAL 20
+S:Platform:RTEMS
+S:Compiler:10.0.1 20200406 (RTEMS 6, RSB bec88a6dd856892c3e66e4598252ea07d7a0d762, Newlib ece49e4)
+S:Version:6.0.0.929e49a54ab4d2d18c9fb8d03610614f63e25b8d
+S:BSP:realview_pbx_a9_qemu
+S:RTEMS_DEBUG:1
+S:RTEMS_MULTIPROCESSING:0
+S:RTEMS_POSIX_API:1
+S:RTEMS_PROFILING:0
+S:RTEMS_SMP:1
+B:SemaphoreObtainTimeoutInterrupt
+P:0:0:UI1:init.c:159
+P:1:0:UI1:init.c:169
+P:2:0:UI1:init.c:176
+P:3:0:UI1:init.c:179
+P:4:0:UI1:init.c:181
+P:5:0:UI1:init.c:182
+P:6:0:UI1:init.c:183
+P:7:0:UI1:init.c:186
+P:8:0:UI1:init.c:189
+E:SemaphoreObtainTimeoutInterrupt:N:9:F:0:D:0.105419
+Z:SPINTRCRITICAL 20:C:1:N:9:F:0:D:0.106593
+Y:ReportHash:SHA256:8429590b312ac9e661529a4a932470feefd05747f60d30afaee1486259d26972
-Support - rtems_timer_create - creating timer 1
-*** END OF TEST INTERRUPT CRITICAL SECTION 20 ***
+*** END OF TEST SPINTRCRITICAL 20 ***
2.26.2
