[PATCH 05/33] libtest: Add T_make_runner()
Wed Jul 22 05:51:05 UTC 2020
On 22/7/20 3:10 pm, Sebastian Huber wrote:
> On 22/07/2020 07:04, Chris Johns wrote:
>> On 22/7/20 1:04 am, Sebastian Huber wrote:
>>> Update #3199.
>>>   cpukit/include/rtems/test.h |  2 ++
>>>   cpukit/libtest/t-test.c     | 10 ++++++++--
>>>   2 files changed, 10 insertions(+), 2 deletions(-)
>>> diff --git a/cpukit/include/rtems/test.h b/cpukit/include/rtems/test.h
>>> index b68f303e16..a1a976d7ff 100644
>>> --- a/cpukit/include/rtems/test.h
>>> +++ b/cpukit/include/rtems/test.h
>>> @@ -2209,6 +2209,8 @@ void T_putchar_default(int, void *);
>>>     int T_main(const T_config *);
>>>   +void T_make_runner(void);
>>>   bool T_is_runner(void);
>>>     void T_run_initialize(const T_config *);
>>> diff --git a/cpukit/libtest/t-test.c b/cpukit/libtest/t-test.c
>>> index 16018335c9..a0336fa461 100644
>>> --- a/cpukit/libtest/t-test.c
>>> +++ b/cpukit/libtest/t-test.c
>>> @@ -330,7 +330,7 @@ T_scope(char *buf)
>>>     static void
>>> -T_set_runner(T_context *ctx)
>>> +T_do_make_runner(T_context *ctx)
>>>   #ifdef __rtems__
>>>       ISR_Level level;
>> Indenting 4 or 2 spaces?
>>> @@ -353,6 +353,12 @@ T_set_runner(T_context *ctx)
>>>   #endif
>>>   +void
>>> +T_make_runner(void)
>>> +    T_do_make_runner(&T_instance);
>>>   int
>>>   T_printf(char const *fmt, ...)
>>> @@ -719,7 +725,7 @@ T_do_run_initialize(const T_config *config)
>>>       ctx->overall_steps = 0;
>>>       ctx->overall_failures = 0;
>>>   -    T_set_runner(ctx);
>>> +    T_do_make_runner(ctx);
>>>       T_actions_forward(config, T_EVENT_RUN_INITIALIZE_EARLY, config->name);
>>>       T_do_log(ctx, T_QUIET, "A:%s\n", config->name);
>>>       T_system(ctx);
>> Same here?
>> This comment is also for all the remaining files in touched by the patches. I
>> see a mix.
> The test framework uses the BSD coding style. The core implementation is done in
> C11 and is portable to FreeBSD, MSYS2, and Linux. The indentation level is one tab.
As in a real tab character?
