Doubt regarding thread creation in RTEMS
Wed Jul 22 14:16:53 UTC 2020
On 22/07/2020 15:36, Richi Dubey wrote:
> Threads that get created automatically when a CPU starts have their
> scheduler nodes with node->idle set to the thread itself, while the
> nodes that are created due to a task being created have NULL in their
> node->idle (If not using helper function atm).  Am I right?
> If yes, Why isn't the function _Scheduler_Set_idle_thread() called
> by _Thread_Create_idle_for_CPU?
> Trace:
> exinit.c -> _Thread_Create_idle -> _Thread_Create_idle_for_CPU
> -> _Scheduler_Start_idle -> _Scheduler_EDF_SMP_Start_idle
> -> _Scheduler_SMP_Do_start_idle ->_Scheduler_SMP_Release_idle_thread .
> I am asking this since _Scheduler_Set_idle_thread() is the only
> function that sets the node->idle value.
I think the description of this member is clear:
  * @brief Scheduler node for per-thread data.
struct Scheduler_Node {
    * @brief The idle thread claimed by this node in case the sticky
level is
    * greater than zero and the thread is block or is scheduled on another
    * scheduler instance.
    * This is necessary to ensure the priority ceiling protocols work across
    * scheduler boundaries.
   struct _Thread_Control *idle;
As I said before, the idle threads are normal threads. The only special
thing is that they execute no code which blocks. You really have to
distinguish between threads and scheduler nodes.
