Doubt regarding thread creation in RTEMS
Richi Dubey richidubey at gmail.com
Thu Jul 23 06:12:22 UTC 2020
Thank you for the clarification.
I am still having a hard time understanding this. What do you mean by no
code which blocks? Does the thread which executes our task (Say a
function Loop with 30k loops) block? What does block mean here?
On Wed, Jul 22, 2020 at 7:46 PM Sebastian Huber <
> On 22/07/2020 15:36, Richi Dubey wrote:
> > Threads that get created automatically when a CPU starts have their
> > scheduler nodes with node->idle set to the thread itself, while the
> > nodes that are created due to a task being created have NULL in their
> > node->idle (If not using helper function atm).  Am I right?
> > If yes, Why isn't the function _Scheduler_Set_idle_thread() called
> > by _Thread_Create_idle_for_CPU?
> > Trace:
> > exinit.c -> _Thread_Create_idle -> _Thread_Create_idle_for_CPU
> > -> _Scheduler_Start_idle -> _Scheduler_EDF_SMP_Start_idle
> > -> _Scheduler_SMP_Do_start_idle ->_Scheduler_SMP_Release_idle_thread .
> > I am asking this since _Scheduler_Set_idle_thread() is the only
> > function that sets the node->idle value.
> I think the description of this member is clear:
>   * @brief Scheduler node for per-thread data.
> struct Scheduler_Node {
>     * @brief The idle thread claimed by this node in case the sticky
> level is
>     * greater than zero and the thread is block or is scheduled on another
>     * scheduler instance.
>     * This is necessary to ensure the priority ceiling protocols work
> across
>     * scheduler boundaries.
>    struct _Thread_Control *idle;
> As I said before, the idle threads are normal threads. The only special
> thing is that they execute no code which blocks. You really have to
> distinguish between threads and scheduler nodes.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200723/ac859e37/attachment.html>
