[PATCH 1/2] score: Add RTEMS_WEAK
Gedare Bloom
gedare at rtems.org
Thu Jul 23 17:19:08 UTC 2020
We don't have any specific rule, but all the examples in GCC docs put
the attributes near the end of the line rather than in the
start/middle. I mentioned this related to Christian's recent patch
with alignment attributes. It might be good for us to define some
conventions for consistency. I lean toward following the GNU
documentation.
ref: https://gcc.gnu.org/onlinedocs/gcc-4.7.2/gcc/Function-Attributes.html
On Thu, Jul 23, 2020 at 6:21 AM Sebastian Huber
> Update #4032.
> cpukit/include/rtems/score/basedefs.h | 12 +++++++
> testsuites/sptests/Makefile.am | 2 +-
> testsuites/sptests/spmisc01/init.c | 15 ++++++++
> testsuites/sptests/spmisc01/spmisc01.h | 45 ++++++++++++++++++++++++
> testsuites/sptests/spmisc01/strong.c | 47 ++++++++++++++++++++++++++
> 5 files changed, 120 insertions(+), 1 deletion(-)
> create mode 100644 testsuites/sptests/spmisc01/spmisc01.h
> create mode 100644 testsuites/sptests/spmisc01/strong.c
> diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
> index e301292375..a934507d80 100644
> --- a/cpukit/include/rtems/score/basedefs.h
> +++ b/cpukit/include/rtems/score/basedefs.h
> @@ -197,6 +197,18 @@
> #define RTEMS_ALIAS( _target )
> #endif
> + * @brief Instructs the compiler to define a weak function.
> + * Use this attribute for function definitions. Do not use it for function
> + * declarations.
> +#if defined(__GNUC__)
> + #define RTEMS_WEAK __attribute__((__weak__))
> +#else
> +#endif
> * @brief Instructs the compiler to generate a weak alias to the specified
> * target function.
> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
> index 5404ba4302..854ec3daf8 100644
> --- a/testsuites/sptests/Makefile.am
> +++ b/testsuites/sptests/Makefile.am
> @@ -1409,7 +1409,7 @@ if TEST_spmisc01
> sp_tests += spmisc01
> sp_screens += spmisc01/spmisc01.scn
> sp_docs += spmisc01/spmisc01.doc
> -spmisc01_SOURCES = spmisc01/init.c
> +spmisc01_SOURCES = spmisc01/init.c spmisc01/strong.c
> spmisc01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_spmisc01) \
> $(support_includes)
> endif
> diff --git a/testsuites/sptests/spmisc01/init.c b/testsuites/sptests/spmisc01/init.c
> index 9090069973..e64fa4e480 100644
> --- a/testsuites/sptests/spmisc01/init.c
> +++ b/testsuites/sptests/spmisc01/init.c
> @@ -21,6 +21,8 @@
> #include <tmacros.h>
> +#include "spmisc01.h"
> const char rtems_test_name[] = "SPMISC 1";
> RTEMS_INLINE_ROUTINE int inline_func(void)
> @@ -70,6 +72,16 @@ static int alias_func(void) RTEMS_ALIAS(noinline_func);
> int weak_alias_func(void) RTEMS_WEAK_ALIAS(noinline_func);
> +RTEMS_WEAK int weak_or_strong(void)
> + return 99;
> +RTEMS_WEAK int weak_2(void)
> + return 111;
> static char aligned_variable RTEMS_ALIGNED(64);
> typedef struct {
> @@ -205,6 +217,9 @@ static void Init(rtems_task_argument arg)
> rtems_test_assert(sizeof(packed_struct) == 5);
> rtems_test_assert(alias_func() == 14);
> rtems_test_assert(weak_alias_func() == 14);
> + pull_in_strong();
> + rtems_test_assert(weak_or_strong() == 77);
> + rtems_test_assert(weak_2() == 111);
> rtems_test_assert(((uintptr_t) &aligned_variable) % 64 == 0);
> rtems_test_assert(offsetof(aligned_member_struct, aligned_member) % 64 == 0);
> unreachable();
> diff --git a/testsuites/sptests/spmisc01/spmisc01.h b/testsuites/sptests/spmisc01/spmisc01.h
> new file mode 100644
> index 0000000000..6dbf9ca23c
> --- /dev/null
> +++ b/testsuites/sptests/spmisc01/spmisc01.h
> @@ -0,0 +1,45 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * Copyright (C) 2020 embedded brains GmbH (http://www.embedded-brains.de)
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _SPMISC01_H
> +#define _SPMISC01_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +int weak_or_strong(void);
> +void pull_in_strong(void);
> +int weak_2(void);
> +#ifdef __cplusplus
> +#endif
> +#endif /* _SPMISC01_H */
> diff --git a/testsuites/sptests/spmisc01/strong.c b/testsuites/sptests/spmisc01/strong.c
> index 0000000000..6341131b67
> --- /dev/null
> +++ b/testsuites/sptests/spmisc01/strong.c
> @@ -0,0 +1,47 @@
> + * are met:
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> + return 77;
> + /* Do nothing */
> + return 222;
> 2.26.2
> devel mailing list
> devel at rtems.org
