[PATCH 1/2] score: Add RTEMS_WEAK
Sebastian Huber
Thu Jul 23 17:54:04 UTC 2020
On 23/07/2020 19:19, Gedare Bloom wrote:
> We don't have any specific rule, but all the examples in GCC docs put
> the attributes near the end of the line rather than in the
> start/middle. I mentioned this related to Christian's recent patch
> with alignment attributes. It might be good for us to define some
> conventions for consistency. I lean toward following the GNU
> documentation.
> ref:https://gcc.gnu.org/onlinedocs/gcc-4.7.2/gcc/Function-Attributes.html
You can't put the attributes between the closing ) and the opening { in
a function definition.
https://gcc.gnu.org/onlinedocs/gcc-10.2.0/gcc/Attribute-Syntax.html#Attribute-Syntax
I tend to place them in front of the declarator. This is in line with C++11:
https://en.cppreference.com/w/cpp/language/attributes
This enables you to replace some GNU-specific attributes with C++
attributes for example.
Also the C11 _Noreturn is in front of the function declaration:
https://en.cppreference.com/w/c/language/_Noreturn
