Is rtems available on a 4-cores cortex A72 (ARM-v8a) bsp?
smallphd at aliyun.com smallphd at aliyun.com
Fri Jul 24 08:28:36 UTC 2020
xilinx-zynqmp BSP has a ARM cortex A53 processor. Is it a ARMv8-A architeture?
Date: 2020-07-24 12:49
To: smallphd at aliyun.com; joel
CC: devel
Subject: Re: Is rtems available on a 4-cores cortex A72 (ARM-v8a) bsp?
On 24/07/2020 03:09, smallphd at aliyun.com wrote:
> 32-bit mode is OK.
> Does it fully support SMP and MMU in this bsp?
RTEMS supports SMP on ARMv7-A and in particular the xilinx-zynqmp BSP.
The MMU is statically set up. RTEMS doesn't support processes with
virtual memory.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20200724/3315d8cc/attachment.html>
